highest boost in 07 gt500
LinkBack (1) Thread Tools
Old August 31st, 2010, 01:46 PM   1 links from elsewhere to this Post. Click to view. #1
sj408 will become famous soon enough
hey guys wondering whats the highest boost you can run in an 07 gt500? thinking bout tossing a smaller supercharger pulley and an overdrive pulley for the crank just want to be safe while doing it
Old August 31st, 2010, 02:24 PM   #2
CammedMysticCobra's Avatar
Mustang MystiqueCobra2004
CammedMysticCobra can only hope to improve
Send a message via AIM to CammedMysticCobra
18 to 20psi is the flow and rotor limit on that blower. If you want the badest ported charger and 600hp Steigemeier sells the Snake bite kit for the Shelby with 18psi on 2.2 upper pulley which is 2593 its not cheap but it is the the medium ground between Kenne Bell sinse its 5k for 2.8 Kenne. I have stage 5 ported steigy and I made 520hp with stock plenum and tb with bad 02s no CAI and rich tune. If I would have had the Acufab tb and plenum I would have easily made 560hp which is what Iam missing on my setup.
Stiegemeier Porting Services, LLC - Supercharger Rebuild and Repair
Full bolt ons Fully built Teksid Block Custom Comp Stage 10s missing JLT, Acufab TB and 2.8 Kenne
http://www.youtube.com/user/MysticCobra04
Sold not lost and will never be forgotten.
Old September 1st, 2010, 10:18 PM   #3
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
weems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud of
Don't worry about boost numbers. Get you a POSI port, a 2.65 upper, and a lower if you really want to crank it, and be happy with 600 horses.
Old September 2nd, 2010, 11:25 AM   #4
Jobra's Avatar
2004 Cobra
7.4@97 Eaton
Jobra has a spectacular aura aboutJobra has a spectacular aura about
Your not going to see 560 rwhp by adding an aftermarket tb/plenum. 40 RWHP for that? Erm..... Id say you could see 535rwhp at most.
+1. That's what I would do.
NEW NUMBERS: 609/543
Old September 6th, 2010, 01:53 AM   #5
Of course he shouldnt worry about boost numbers RIGHT cuz boost only equals the amount of power you want to make. Dude how about you stop posting shit talking garbage for one and stop trying to give people advice on things you obviously know nothing about. Sure tell him to put a 2.65 with a port which only would give you 3 psi on top of the stock 13 which is 16psi and would only give you maybe 560hp which you would still missing the extra 2 psi to get up to 600hp, but your not talking in account that when you port the charger your boost goes down retard which is why Steigmeir needs to use a 2.2 upper to get up 18psi which like I said is the limit of the rotors and flow of the charger and can than get the 600hp which he is looking for. Since he clearly aksed what is the maximum amount of boost you go with the Stock charger. And its not like Stiegmier doesnt know what they are doing right they have only been porting eatons since the day 03 04 Cobra first came out.
VMP "stock look" 2.65" upper pulley & idler combo for GT500 stock & TVS blowers
Old September 6th, 2010, 02:00 AM   #6
Wow sounds like you just as smart as weems. First off yes I would becuase like I said I have stage 5 ported Stiegy which people have reached to 550 with Acufab ported Plenum and Tb wihout the biggest custom Comps cams that you can fit a 4.6 hence my sn and signature, which I have and will give me the extra 40 to 45 horse power combined with the Acufab Plenum and Tb. Not to mention again like I said I dont even have CAI and made 520hp with bad 02s, rich tune, and intercooler leak. So yes I would have seen 560hp with the tb and pleum since my cams are asking for air they are getting and add a JLT on top of that I would easily been able to even get up to 580hp.
Please read previous posts before posting your self.
Old September 6th, 2010, 02:23 AM   #7
BadBlackGT's Avatar
13.82@100.26
BadBlackGT is a jewel in the roughBadBlackGT is a jewel in the roughBadBlackGT is a jewel in the roughBadBlackGT is a jewel in the rough
Of course he shouldnt worry about boost numbers RIGHT cuz boost only equals the amount of power you want to make. your not talking in account that when you port the charger your boost goes down retard which is why Steigmeir needs to use a 2.2 upper to get up 18psi which like I said is the limit of the rotors and flow of the charger and can than get the 600hp which he is looking for.
Yeah, but porting it will make it flow much better which will make you not need as much boost to yield better gains. Think about having a small straw. You have to put more force to get a lot of air through it. Not take a bigger straw, its easier to move just as much or more air through there with less effort. PSI numbers don't mean shit really. A car that has great flowing heads and intake with 3 psi would put out more power with the same type of car with stock heads and intake running say 9 psi.
If its got titts or tires, it's gonna give you problems.
Originally Posted by navyman8903 View Post
He has a 500rwhp 1990 5.0L with a cam who's lope takes virginity.
Originally Posted by Towelly View Post
Go find some Chill biscuits, dip them in some Calm the Fuck down sauce and chill the fuck out.
Old September 6th, 2010, 03:07 AM   #8
2003 SVT Cobra
11.70 @ 121
You are so fucking retarded its unbelievable. Boost DOES NOT dictate power, boost is only a measurement of restriction. If you add headers and a port you will lose boost, but will you lose power? FUCK NO. End of story, do you really want to keep getting into it with me about shit like this?
OP, do not take advice from this guy, his rep speaks wonders.
Old September 6th, 2010, 03:08 AM   #9
2003 SVT Cobra
11.70 @ 121
lmao.
Old September 6th, 2010, 03:10 AM   #10
2003 SVT Cobra
11.70 @ 121
BTW Cammed, still waiting on your response to where you got proven wrong here. stock eaton with 2.9" pulley
Old September 8th, 2010, 12:58 PM   #11
termin8er03's Avatar
2003 Mustang SVT Cobra
termin8er03 is on a distinguished road
Boost psi does not always reflect power. I have a 2.93 upper and 6lb lower with steggy stage 4 and stock tb and jlt cold air and stock exaust manifolds and I make 18 lbs of boost. I am right at 500 hp. Mine was tuned with an 4r70w and now has the six speed. Guy I know has a kenne bell 2.4 and he made less boost but had longtubes and made 592.
<img src=http://i967.photobucket.com/albums/ae159/Termin8or03/1279056717-1-1-1.jpg border=0 alt= />
MM Cobra Club member #20
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/181451-highest-boost-07-gt500.html
Thread how much will GT500 hold up to? | Forums at Modded Mustangs | BoardReader This thread Refback March 15th, 2012 01:18 AM
Threads Similar to: highest boost in 07 gt500
highest boost in gt500? sj408 2005 - 2010 8 August 31st, 2010 02:51 PM
Boost-A-Pump or GT500 Fuel Pump? stanglifemike 2005 - 2010 64 September 21st, 2009 01:17 PM
Highest boost level..Whipple HO kit...? ulev1st 2005 - 2010 2 February 21st, 2008 05:27 PM
Highest HP S/C 4.6 2v Out? SWEET2KSTANG 99-04 12 November 29th, 2007 01:07 AM
What the highest milage 5.0 ever ??? Casper98GT The Clubhouse 16 October 11th, 2007 11:01 AM
