Built rear check list and suggestions
Old September 1st, 2010, 09:49 PM   #1
04MachOne's Avatar
2004 Mach 1
04MachOne is on a distinguished road
I'm about to go ahead order a few of the parts I need to build the rear but just want to make sure before ordering anything I know exactly what I need. I'm not doing anything intense with it. No clutch dumping at 6k rpms I might drag race a few times next summer and next summer I want to install 100 shot of NX and spray every once and a while but other than that just a DD.
Here's what I believe I need:
31spline differential. (This one ok?)
31 spline axles. (Are mosers fine?)
Girdle. (Is this one good?)
Bearing Kit. (here)
Tuner
4.30s
Now with that differential there was that one in the link and another 10 dollars cheaper with carbon discs which one do I need?
Also please if there is a brand that you suggest in place of one of these I have linked please let me know. Also anything else that you can think of that I need let me know or anything I'm getting that would be a waste then let me know. Thanks guys!
Old September 1st, 2010, 11:04 PM   #2
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
looks good
Old September 2nd, 2010, 08:56 AM   #3
CobraStang161's Avatar
4V twin turbo 2000 GT
I live my life a quarter mile at a time xD
CobraStang161 will become famous soon enoughCobraStang161 will become famous soon enough
Differential garbage
Axles good
Bearing kit ok
gears good
dont get any diff with clutches in it, itll burn out. Get a Eaton TrueTrac
Built 4V Motor with Sullivan Single Plane Intake
Custom 66MM BB TT kit
Borla XR-1 Dumped before rear
Moser built 9" Rear
35 spline WaveTrac Diff with 3.75s
35 spline Moser axles
14PT roll cage and minitubbed
Old September 2nd, 2010, 09:33 AM   #4
04MachOne's Avatar
2004 Mach 1
Axles good
Bearing kit ok
gears good
Even for what I'm going to be using it for? I feel like that's pretty expensive for only drag racing a few times. Is there a cheaper alternative that doesn't have clutches but isn't a fortune or should I just go ahead and get the eaton?
Old September 2nd, 2010, 09:50 AM   #5
04MachOne's Avatar
2004 Mach 1
Cheapest place I can find the eaton is lethal and that's like 525 any links to somewhere cheaper?
Old September 2nd, 2010, 10:08 AM   #6
manolith's Avatar
11 Mustang GT
Track times coming soon.
manolith will become famous soon enoughmanolith will become famous soon enough
Clutch style differentials burn out eventualy just like the clutch in your drive train. It will last longer than cobrastang thinks. They are also very quiet.
2011 Mustang GT MT. Ford Racing K springs, Boss intake manifold, JLT Cold air intake, BBR O/R Xpipe, Ford Racing 4.10 gears, TA Rear End Girdle, VMP E85 Tune/BBR 93 Tune.
Old September 2nd, 2010, 11:15 AM   #7
http://cgi.ebay.com/ebaymotors/FORD-...Q5fAccessories
Moser built 9" Rear
Old September 2nd, 2010, 11:17 AM   #8
there is no timeframe for when a clutch diff will go out, people have burned out new ones at the track after just a few passes, since the truetrac has worm gears they do not wear and can handle 800+ hp, so if in the future you want to get a power adder, you will not have to rip out the diff to get a stronger one
Moser built 9" Rear
Old September 2nd, 2010, 11:22 AM   #9
ponygrrl's Avatar
2003 Mustang GT
ponygrrl has a spectacular aura aboutponygrrl has a spectacular aura about
Send a message via AIM to ponygrrl
Axles good
Bearing kit ok
gears good
Agreed. Don't forget wheel studs.
The TrueTrac is worth the money. I, as well as many friends, run that diff with no issues.
03 GT|boss330 forged shortblock|steen racing stage 3 heads|vt stage 2 blower cams|i/h/e|detriot trutrac|moser 31 splines|125 shot
May it R.I.P.
New whip: 1953 Ford Mainline Coupe... let the games begin!
Old September 2nd, 2010, 12:02 PM   #10
97mustanggt's Avatar
97GT & 97Snake & 00L
T.B.A
97mustanggt will become famous soon enough
and just for good measure, a trick flow diff. cover for easy diff. oil changes.
97 Cobra & 00 Lightning
Beauty & The Beast
I rev next to hybrids so they can hear me kill the environment
MM Cobra Club Member #77
MM Lightning Club Founder
Old September 2nd, 2010, 12:39 PM   #11
04MachOne's Avatar
2004 Mach 1
Wheel studs? Any links to some good ones to get? I haven't even heard of these and that I'd need them to beef up the rear.
But I guess TruTrac it is. I'd rather spend a little extra and not have to worry about it then not.
The diff. cover is the same thing as a girdle right?
Old September 2nd, 2010, 01:22 PM   #12
T.B.A
yea it is
Beauty & The Beast
Old September 2nd, 2010, 01:49 PM   #13
ponygrrl's Avatar
2003 Mustang GT
Moser axles use press in wheel studs. You can get Moser studs, or ARP or Moroso. They're pretty inexpensive. You'll also need a set of open-ended lugnuts. Your local auto parts store should have those.
May it R.I.P.
Old September 3rd, 2010, 06:43 PM   #14
04MachOne's Avatar
2004 Mach 1
Last question about this. Since I'm getting a whole new differential and girdle and all that do I still need a bearing kit?
Old September 3rd, 2010, 06:59 PM   #15
manolith's Avatar
11 Mustang GT
yes. just get a master kit. btw what diff are you going to get finaly? this is what i have and it works great for me. http://www.americanmuscle.com/eaton-...-posi-lsd.html
Old September 3rd, 2010, 08:55 PM   #16
04MachOne's Avatar
2004 Mach 1
I thought I was gonna get the Eaton Tru-trac, but the guys over at the registry told me for what I was going to use it for a clutch style frpp 31 spline one will work just fine and a lot of guys over there run them and have no problems. So I'm going with that one, it's the one out of the 03/04 terminators, and it's only 190 from the guy on modularfords that works at tously ford or something like that.
Old September 4th, 2010, 09:06 AM   #17
manolith's Avatar
11 Mustang GT
yeah thats cool.. i have seen terminators with 500whp destroy the stock diff tho.
Old September 4th, 2010, 03:28 PM   #18
04MachOne's Avatar
2004 Mach 1
Yeah, I won't have that much hp though and it'll only be mid-high 400rwtq every once and a while when I decide to spray so I should be fine.
Old September 4th, 2010, 06:04 PM   #19
manolith's Avatar
11 Mustang GT
cool... the only place that you will really damage anything is at the drag strip with super sticky tires. you should be good.
Threads Similar to: Built rear check list and suggestions
Built 5.4 suggestions??? quiksilver225 99-04 84 December 18th, 2009 08:25 AM
List of Planned Mods...Suggestions? NinetySixVert 96-98 7 April 25th, 2008 03:57 PM
My Mod List! Any suggestions 02stang6 V6 Mustangs 31 February 1st, 2008 04:26 PM
MOD list suggestions for exhaust. drakkon84 V6 Mustangs 3 November 6th, 2007 05:16 PM
parts suggestions list laserstang2 96-98 3 February 10th, 2007 11:44 PM
