mach one fan temp
Old September 6th, 2010, 09:34 PM   #1
Bad02gt is on a distinguished road
mach one fan temp
i need to know what temp a stock mach 1 fan kicks on. because mine is kicking on at 216 degrees. and that seems a little high
Old September 7th, 2010, 08:33 AM   #2
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
216* F? Yes that's way high. That's even pushing the threshold for the motor running a bit hot. I'm having an intermittent overheating issue as well, but my fan's kick in properly at the correct degree. Give me some time here and I'll look up the specs.
Old September 7th, 2010, 11:36 AM   #3
Ya and i can figure out why my motor is running so hot. Ive changed thermostat to 170deg and water pump is fine
Old September 7th, 2010, 11:39 AM   #4
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Dude I'm there with you. Mine hits up too 235-240. I'm spending the whole evening tonight tearing apart the entire cooling system, flushing it, replacing the ECT, new hoses, new t-stat (for the 4th time), new reservoir cap (for the 2nd time). Then I'll be purging it/burping it for a while. The cooling system on these 4V motors are a PITA.
Old September 7th, 2010, 08:34 PM   #5
Dam man i thought mine was high haha. I was told to chdck my head gaskets. And im gonna flush my stuff out tomorrow to. You should let me know how urs runs after u do it tonight
Old September 7th, 2010, 10:11 PM   #6
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Already checked the headgasket when the issue was first happening. That's the first thing I checked. Was praying to god it wasn't it lol. Thank god it wasn't.
Didn't get a chance to do all the work tonight. Going down to the shop tomorrow night instead. I want to throw her up on the lift and replace the fuel filler neck gasket anyways.
Threads Similar to: mach one fan temp
temp sensor/fan switch hockey 2.3 Mustangs 7 July 28th, 2010 03:10 PM
Electric Fan Temp Sensor dennislv 5.0 Mustangs 7 November 12th, 2009 09:07 AM
wiring diagram for a taurus 2 speed fan, relay, temp sensor 78mach1 5.0 Mustangs 3 July 3rd, 2009 09:37 PM
engine temp and oil temp off Reset? warrior86 V6 Mustangs 3 November 29th, 2008 01:48 PM
Taurus fan vs Mark vlll fan black88 5.0 Mustangs 1 September 20th, 2007 07:57 PM
