head cooling mod
Old September 8th, 2010, 08:12 PM   #1
1999cobra92's Avatar
1999 mustang cobra
1999cobra92 will become famous soon enough
head cooling mod
im doing the head cooling mod on my cobra and i dont know exactly how to take out the freeze plug
its the evenflow generation 2 the one that hooks up next to the intake manifold
Old September 9th, 2010, 09:12 AM   #2
CobraStang161's Avatar
4V twin turbo 2000 GT
I live my life a quarter mile at a time xD
CobraStang161 will become famous soon enoughCobraStang161 will become famous soon enough
With a small chisel, right on the lip of the freeze plug at 9 o'clock hit it, the bottom should push into the head and the top should be sticking out. Take a pair of pliers and remove. Done
Built 4V Motor with Sullivan Single Plane Intake
Custom 66MM BB TT kit
Borla XR-1 Dumped before rear
Moser built 9" Rear
35 spline WaveTrac Diff with 3.75s
35 spline Moser axles
14PT roll cage and minitubbed
Old September 10th, 2010, 08:54 PM   #3
mrmarrone's Avatar
03 SVT Cobra
mrmarrone is on a distinguished road
i just did the mod tonight. i unfortunately tapped the plug down the bore. so i drilled a hole in it, threaded a screw in and pried it right out. came out pretty easy.
Old September 10th, 2010, 11:53 PM   #4
mystk96's Avatar
2005 trd tacoma sport
mystk96 will become famous soon enough
can this be done on b head cobras
Old September 11th, 2010, 02:53 AM   #5
majorownage is on a distinguished road
doesnt need it. only early 03 cobras really have problems
Old September 11th, 2010, 10:18 AM   #6
mrmarrone's Avatar
03 SVT Cobra
^what he said
Old September 11th, 2010, 10:47 AM   #7
mystk96's Avatar
how do i get mine to run cool when sitting it likes to run hot when sitting in traffic
Old September 11th, 2010, 01:02 PM   #8
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Put a new thermostat in.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old September 11th, 2010, 04:53 PM   #9
rst1523's Avatar
2003 Mach 1
rst1523 is on a distinguished road
what about 03 machs? do they need this?
Old September 11th, 2010, 07:01 PM   #10
If it is stock, you don't
With a poweradder, they have the same problem as 03 cobras.
Sometime I want to try Evan's Coolant....its a non water coolant and boils at a higher temp....
Old September 11th, 2010, 07:02 PM   #11
why are you getting hot in traffic? Is your cobra stock?
Old September 12th, 2010, 01:50 AM   #12
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
03 Machs and Cobras have the same exact heads. But since the Mach is putting down less power it's not usually a problem like it is with the Terminator.
Old September 12th, 2010, 09:58 AM   #13
mystk96's Avatar
stock you mean stock cooling system yes is it fi no... just suspension geared and exhaust
Old September 12th, 2010, 10:53 AM   #14
JTs03v6's Avatar
2003 mustang
7.48x1.56=11.67
JTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura aboutJTs03v6 has a spectacular aura about
Try the weter water from advance auto and run 160* stat.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic
http://photobucket.com/JTsTurboBuild
http://youtube.com/user/JTsStang
Old September 14th, 2010, 11:37 PM   #15
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
dont go to a 160 without a tune or if you drive the car in the cold.
Old September 15th, 2010, 12:55 AM   #16
mystk96's Avatar
why so
Old September 15th, 2010, 01:14 AM   #17
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
tune and fan work together with temp settings. if too cold, fan wont work right, engine wont run right because out of parameters.
Old September 15th, 2010, 03:58 AM   #18
It might actually be better....the ecu will enrich the a/f mixture.
Could be a ghetto way to more horsepower.
Dodge truck homos do that same thing by moving the temperature gauge to cooler coolant.
I would predict 5-10 hp more.
Old September 15th, 2010, 05:07 AM   #19
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
uh, no. if too cool the ecu will not allow for OL operations or wont let it work correctly. the mopar guys dont move the gauge, they change stat and do the "power wire" mod. the little more fuel from tricking the computer comes from messing with the IAT. that is the power wire mod guys do, some guys do it on the mustangs as well. the mopars are worse than the fords when they are too cool to run OL operations, but do have a lower setting on temp where they will allow for it. i have a dodge truck, know them things pretty well too.
Old September 15th, 2010, 05:39 AM   #20
brharris777's Avatar
1998 Mustang Cobra
brharris777 will become famous soon enoughbrharris777 will become famous soon enough
if you are having problems with cooling and arent running incredibly high compression or at rediculously high rpms you have other issues. Ford designed these cooling systems and chose the oem spec thermostat for a reason, engines have a sweet spot in their operating temperatures and the thermostat is designed to keep it in that range. Opening the thermostat too soon can cause over cooling in the block and heads which has the potential to make even more problems than over heating. Wetter water is a joke and some of the trace additives can actually cause corrosion problems in your heater core and radiator but mostly its dyed ethylene glycol mixed with water which in the everyday terms is 50/50 coolant. If youre overheating in traffic, check your fan circuits, and test your cooling system for 1. antifreeze to water ratio, the money spot for coolant boiling point and freeze protection is exactly 50/50. 2. pressure, if youre surge tank cap isnt holding the spec 15 psi. then your venting out slow boil coolant vapors and slowly losing coolant. and pressure test the system for leaks, that ones pretty obvious.
sorry i ranted, just finished going over this stuff in school last week.
" When in doubt, go flat out"- Colin McRae
MM Cobra Club #76
MM Cleavage Club #14
285 CREW #8
Threads Similar to: head cooling mod
will a blower head unit for a 5.0 work on a 4.6 mod motor? Imran 99-04 9 March 10th, 2010 02:26 AM
Cooling mod revamped? jivepepper 99-04 34 March 6th, 2009 06:06 PM
Head Cooling. In need of Enlightenment. 96Snaker 4V / SVT 11 January 24th, 2009 02:45 AM
head coolimg mod 03snakeminated 4V / SVT 24 September 3rd, 2008 07:36 PM
