How hard should it be to turn the crank?
LinkBack (1) Thread Tools
Old September 9th, 2010, 01:57 PM   1 links from elsewhere to this Post. Click to view. #1
97 cobra/94 integra
Kimo will become famous soon enough
Ok so, When i bought the cobra the guy told me that the motor was locked up and his mechanic told him he couldnt turn it over-
When you try to start it, it JOLTS like a hard clank sound-
Well yesterday i Got out a ratchet and a breaker bar, and i can turn the motor over by hand- its not easy (not really alot of room to work with either) but its doable- it turns over-
I took the starter out (which is in a shitty location might i add lol) took it to get tested, and it "passes" the test, but sounds horrible, the auto parts place said "i wouldnt put it back in"
Im starting to have the slightest hope that the starter might just be bad-
Should the motor be that hard to turn over by hand? (note the spark plugs are still in)
The Integra V8 build on Facebook!!
V8 Integra- Mus-tegra | Facebook
Old September 9th, 2010, 03:38 PM   #2
majorownage is on a distinguished road
a little piece of my heart died when that cobra got hacked up
Check the oil...if it has shiny metal shit...you're sol...other than that i would say you are good to go.
Old September 9th, 2010, 04:07 PM   #3
97 cobra/94 integra
no metal shavings on the dip stick0-- but i have not pulled the oil pan
Old September 9th, 2010, 06:08 PM   #4
manolith's Avatar
11 Mustang GT
Track times coming soon.
manolith will become famous soon enoughmanolith will become famous soon enough
the motor is kind of hard to turn over.. it takes about 45 to 50 ftlbs of torque to turn it. i tell you this because this is the first torque i applied to the flywheel bolts and at 45ft lbs it started to spin and i had to buy the tool to hold the flywheel.
2011 Mustang GT MT. Ford Racing K springs, Boss intake manifold, JLT Cold air intake, BBR O/R Xpipe, Ford Racing 4.10 gears, TA Rear End Girdle, VMP E85 Tune/BBR 93 Tune.
Old September 9th, 2010, 06:21 PM   #5
Funny story
when i was taking the Jesus Bolt off (harmonic balancer bolt), I was having serious trouble getting it lose. With the the parking break set and in 5ith gear, i was still spinning the tires.
I finally used a pipe on a breaker bar and a hammer...fixed the problem
Old September 9th, 2010, 06:23 PM   #6
manolith's Avatar
11 Mustang GT
Originally Posted by majorownage View Post
Funny story
your rear brakes must be bad LOL... but yeah that bolt is a PITA
Old September 9th, 2010, 09:48 PM   #7
97 cobra/94 integra
Ok got it started today... then the rod came out of the block hahahahah
Old September 10th, 2010, 01:18 AM   #8
WOW great....one less teksid block...and cobra
Old September 10th, 2010, 01:23 AM   #9
your engine can over come your brakes any day.... nothing wrong with my brakes
Old September 10th, 2010, 08:58 PM   #10
mrmarrone's Avatar
03 SVT Cobra
mrmarrone is on a distinguished road
i had to take the pulley off with the motor on an engine stand. i was a PITA. took a 1/2 inch breaker bar and a 6 foot steel poll for torque. even w that it was still pretty tough.
Old September 10th, 2010, 09:02 PM   #11
mrmarrone's Avatar
03 SVT Cobra
*threw a bolt through the flywheel that got caught on the engine stand so the crank wouldnt turn.
ovcourse i was lucky enough to find tons of shavings in the oil pan. (spun 2 rod bearings and crank got torn up) ... at least its re build time
Old September 12th, 2010, 09:25 AM   #12
On Probation
Houston mustang guy HMG's Avatar
My sister
Faster Then My Mom
Houston mustang guy HMG Houston mustang guy HMG Houston mustang guy HMG Houston mustang guy HMG Houston mustang guy HMG Houston mustang guy HMG Houston mustang guy HMG Houston mustang guy HMG Houston mustang guy HMG Houston mustang guy HMG Houston mustang guy HMG
Thats all there is to it. 1 big box of 100 dollar bills.
Old September 13th, 2010, 01:39 AM   #13
forcefedcobra's Avatar
2003 SVT Cobra
forcefedcobra will become famous soon enough
I know you already found out that the rod didnt want to stay in the block but just to answer your question..............with the plugs still in the motor will be stiff to turn by hand.............with the plugs out so you arent fighting the compression it will spin much easier.
I buy car mods for the stickers, and I have ALOT of stickers!
Travis Billings
May 6, 1982 - July 5, 2011
Rest In Peace brother, you will be missed.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/182674-how-hard-should-turn-crank.html
Turn the Crank - internet discussions | BoardReader This thread Refback September 10th, 2010 09:58 PM
Threads Similar to: How hard should it be to turn the crank?
You know how all the accessories turn off when you crank the starter? asiansensation78 99-04 4 June 30th, 2010 02:48 PM
Turn on my high beams...and my fogs turn off...? trueblue02GT 99-04 24 January 28th, 2010 04:54 PM
motor is super hard to turn over. whats wrong? Dolbs4082 99-04 7 January 23rd, 2010 02:05 PM
how hard is the under drive crank pulley to install? navyman8903 2005 - 2010 20 January 11th, 2009 09:36 PM
how hard should the a/c pulley be to turn? hardhitter 99-04 23 June 14th, 2008 11:14 PM
