New Mach 1 Transmission Woes
Old September 10th, 2010, 03:32 PM   #1
98mustang is on a distinguished road
Hey guys, just picked up a Mach 1 (white) and I am having trouble with the transmission. They guy I purchased it from said the transmission was replaced 500 miles ago ( he reused the old clutch and flywheel). When the car is rolling it shifts and goes into gear perfect, when at a dead stop the car refuses to go into gear. Not one gear will let you in, its so frustrating especially when backing into a parking space, or when you forget and pop it on to neutral at a stop light. I have to turn the car off and put it in gear and crank it up to get it back into gear. Any help or ideas would be appreciated!!! Oh yeah and the car has an adjustable clutch cable installed when he put the "new" transmission in.
I ordered a new Ford clutch cable along with the MM quadrant and adjuster, awaiting their arrival to see if it is a linkage issue.
Another tip a friend gave me was, they may have put synthetic fluid in the trans and apparently the 3650 hates synthetic? Any support on that claim?
Anyways anyone with similar experience, I would really appreciate it! I just don't understand the car shift smooth otherwise!
Old September 10th, 2010, 08:06 PM   #2
bump
Old September 10th, 2010, 08:07 PM   #3
Wyatt's #1 Slut
B's04gt's Avatar
N/A
B's04gt is a name known to allB's04gt is a name known to allB's04gt is a name known to allB's04gt is a name known to allB's04gt is a name known to allB's04gt is a name known to all
Seems like this is happening to me.. Except only with first and in my 04gt.. it'd be nice if someone came in with an answer.
Old September 11th, 2010, 12:50 PM   #4
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Start w/ a fluid flush.
Old September 11th, 2010, 07:51 PM   #5
majorownage is on a distinguished road
if it's not the cable, it can only be one other thing:
throw out bearing.
I would seek a refund/lawsuit
if it is a brand new tranny it would have had a brand new throw out bearing.
Old September 11th, 2010, 07:57 PM   #6
manolith's Avatar
11 Mustang GT
Track times coming soon.
manolith will become famous soon enoughmanolith will become famous soon enough
hey majorownage
do you even know what a manual transmission is? the guy told him that he reused the old clutch.. the throw out bearing is not included in a new transmission. even some clutch kits dont have the throw out bearing in it. and how did you jump into saying that it is the throw out bearing????? wtf
back to op.. try to adjust the clutch cable that you have on there now.. is the clutch grabing low or high? i dont think is the throw out bearing...
as for the oil.. when i got my transmission built the guy at promotion powertrain told me not to use syntetic oils of any kind. but ive seen guys running royal purple all the time.. i myself have regular automatic transmission fluid and a quart of friction modifier. if the oil that they used does not have a friction modifier then that could cause the transmission to not want to shift because the syncos are just slipping.
2011 Mustang GT MT. Ford Racing K springs, Boss intake manifold, JLT Cold air intake, BBR O/R Xpipe, Ford Racing 4.10 gears, TA Rear End Girdle, VMP E85 Tune/BBR 93 Tune.
Old September 11th, 2010, 08:58 PM   #7
Originally Posted by manolith View Post
hey majorownage
Yeah, I don't believe its the TOB either......
I have the new Ford cable MM adjuster and Quadrant coming Monday so I will try adjusting all that stuff then. I am going to try a fluid change if the cable adjuster and quadrant don't fix the problem. Thanks for the input, it's kinda just a waiting game till Monday night. I'll me sure to post up if that was the fix.
Thanks,
Andrew
Old September 11th, 2010, 09:12 PM   #8
manolith's Avatar
11 Mustang GT
hope it works
Old September 11th, 2010, 10:42 PM   #9
hey majorownage
rebuilt/new trannies include a throwbearing.....its PART of the transmission.
Old September 11th, 2010, 10:46 PM   #10
hope it works
plus, these are the EXACT symptoms of a bad throw out bearing.
Old September 11th, 2010, 11:06 PM   #11
manolith's Avatar
11 Mustang GT
you have no clue.
Old September 12th, 2010, 12:39 AM   #12
you have no clue.
bud do you even know how to take a tranny out?
of course when you buy a clutch it doesn't come with a tob....
but a band new tranny SHOULD ALWAYS has a new tob
Old September 12th, 2010, 10:05 PM   #13
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
It's part of the clutch.
Threads Similar to: New Mach 1 Transmission Woes
Mach Transmission 02v6staang 4V / SVT 4 May 7th, 2010 08:19 PM
starter woes.. superbean 5.0 Mustangs 14 May 1st, 2009 04:50 PM
My woes zinc02GT The Clubhouse 26 December 26th, 2008 08:11 PM
Mach 1 transmission question. Mistertribal 4V / SVT 30 July 16th, 2008 01:57 PM
Nitrous woes zerofx150 99-04 7 April 25th, 2008 01:48 PM
