#21 | |
Most of the fuel is still burning when it leaves these cylinders, which makes the headers/exhaust manifolds glow. This will lead to premature weld failures and/or engine overheating. |
#22 | |
I am pulling facts out here. Call MMR up. They agree with sean as well. |
#23 |
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
less timing it not a big mistake at all.
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
#24 |
KB'd GT
There is a limit on that end too, as you mentioned. Running 20 lbs of boost and 2* of timing is a very bad way to keep detonation in check. Its all about the balance. If you keep the timing over about 12* at WOT you shouldn't have too many issues. If you plan on high speed texas mile runs, you would want less boost and more timing.
#25 |
BYAHHHH!
2001 Mustang GT
13.874
i was running 13* of timing and 10-10psi on my car. Car good and was safe for a stock motor.
#26 | |
prochargedI plan on running 13.5cc dishes on a 5.0 stroker to make my compression around 9.3:1 and read to be procharged. This is in agreement with mmr's salt flat mustang (I can't remember who they built it for). Drag racers can run more compression especially with a centrifugal supercharger |
#27 |
BYAHHHH!
2001 Mustang GT
13.874
I know of a car with a 10.1:1 CR with a t8847 turbo and running 25plus psi. Its a drag car.
So are do you suggest for timing with your CR and what type of boost?
#28 | |
I'm not understanding the question correctly. Are you asking how much timing I would want to run? Probably at redline wot upper teens. Don't get me wrong, you can run a centrifugal supercharged cobra @ 10:1 compression and above on pump gas. Just don't take it out on an open road and run 6 miles wot. moreover, timing is based on a variable amount of factors, so these are just numbers thrown out in the dark |
#29 | |
BYAHHHH!
2001 Mustang GT
13.874
I am wondering/asking. I am going to be doin my own tuning on my car this spring and learning when I can. I mean I have people to help but I am wanting to try and do it myself.
#30 | |
only paying for dyno time is a heck of a lot cheaper than paying the tooner as well... What software will you be using? |
#31 |
n/a
i would use the KB tunes to drive to the dyno.. then I would have someone dyno the car.
TRUE BLUE CREW MEMBER #4
#32 | |
BYAHHHH!
2001 Mustang GT
13.874
Sct software
#33 |
1997 Cobra
![]() iTrader: 1 reviews
i am going to skip the KB tune, i will have to trailer it to Baton Rouge there are no tuners in New Orleans that i am familiar with, thanks for the info, peace.
96 GT (sold) ![]() 97 Cobra ![]() 93 Ranger 03/04 Cobra (needed) |
#34 |
KB'd GT
Go to TPS. They are a bunch of cool guys.
Threads Similar to: Kenne Bell tunes GOOD or BAD ?????
| Kenne bell 2v here. | SCREWd2V | New Members Introductions | 48 | July 15th, 2010 02:11 AM |
| Where is a good place to sell Kenne Bell Supercharger??? | tjf9389 | 94-95 | 11 | June 29th, 2010 10:53 AM |
| Kenne Bell on a 2v | thepizzle44 | 99-04 | 24 | February 14th, 2009 12:02 AM |
| kenne bell | mustangjl | 99-04 | 4 | February 7th, 2008 07:02 PM |
