Kenne Bell tunes GOOD or BAD ?????
Old September 12th, 2010, 02:05 PM   #1
Cobra GT's Avatar
1997 Cobra
Cobra GT is on a distinguished road
I am fixing to buy a Kenne Bell 2.1 L blower for my 97 Cobra, and am looking for anybody who has or has had this blower on there car. I am wondering about the particulars of set ups. E.g. what tune to use Kenne Bell’s chip or have it costumed tuned, Boost- a-pump from KB or Walbro pump, what size MAF, what size injectors are you running? Fuel management, KB FMU, Spark, Boost-a-spark and the way KB says to set your car up. On there website they pretty much say leave the tuning to them with there blower and I kind of agree with them due to the quality of testing equipment they use in there R&D when they create these tunes. Far better metering and deal with a lot more parameters than the local tuner that just tweaks timing curves and things of that nature. I have the usual mods, long tube Kooks headers 1 ¾ to 3in collector, 3 in Kooks off road X-pipe, MagnaFlow exhaust w/ no cats, JLT cai, March udp’s, and a X-Cal 3 w/ a custom tune and 410 gears and other stuff. Can anybody give me some insight on this car and blower, thanks in advance? Please feel free to chime in I know this is a broad subject but any insight will help, thanks.
96 GT (sold)
97 Cobra
93 Ranger
03/04 Cobra (needed)
Old September 12th, 2010, 09:52 PM   #2
majorownage is on a distinguished road
dont buy a kb..
Old September 12th, 2010, 10:51 PM   #3
Cobra GT's Avatar
1997 Cobra
why????
96 GT (sold)
97 Cobra
93 Ranger
Old September 13th, 2010, 12:02 AM   #4
why????
too high compression
*maybe* 6-7 pounds (why spend almost 3k on 100ish horses?)
and im 98% sure nobody makes an intake for b headed cobras.
you are dead set on supercharging a stock block, get a procharger
Old September 13th, 2010, 10:56 AM   #5
I.D.G.A.F.
futureMACH1racer's Avatar
2009 John Deere 9670
futureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud of
Send a message via AIM to futureMACH1racer Send a message via MSN to futureMACH1racer Send a message via Yahoo to futureMACH1racer Send a message via Skype™ to futureMACH1racer
Do you have anymore evidence to support your statement? It seems like a pretty opinionated one at that.
RIP Travis Bilings 5/6/1982-7/5/2011
Be polite. Be professional. But have a plan to kill everyone you meet.
Old September 13th, 2010, 11:17 AM   #6
XectriK's Avatar
2000 Ford Mustang GT
XectriK is just really niceXectriK is just really niceXectriK is just really niceXectriK is just really niceXectriK is just really nice
The KB replaces the intake...
What my recommendation on the tune is this. Use the KB tune and then drive it to a dyno so they can run some diagnostics on it. They might be able to get a few more ponies out of it but the KB tune is pretty solid. I don't know what the compression ratio is on a 97 cobra but if you run longtubes that lowers the boost by about 1 psi. Remember that when choosing your boost. You won't need boost-a-spark unless your going over 10psi (which is what KB recommends). You'll also be fine with just the KB BAP. Unless you're planning something crazy.
With any supercharger your UDPs will be useless.
Old September 13th, 2010, 11:22 AM   #7
incorrect.
Sean Hyland agrees too
A 97 cobra has a compression ratio around 9.8;1
KB's make boost from low to high rpm, and this is bad with high compression.
Anything over 6-7 pounds and you will have major detonation problems below 3k ish rpms.
The only way to solve this would be to run race fuel, or ethanol.
Centrifigual s/c's only make boost at higher rpms.
Old September 13th, 2010, 11:25 AM   #8
Baddbullitt's Avatar
2001 Bullitt
Baddbullitt is on a distinguished road
My KB kicks ass. I run 10 pounds, Intercooled, with the boost a pump. No issues..
I didn't get the tune that it came with, I got an SCT instead when I got her dyno tuned..
Only reason why was cause they short shipped the damn thing... But I probably would have gotten the SCT anyway, but there's nothing wrong with the KB chips!! Just make sure the car gets put on a dyno to tune it properly..
Bullitt Crew #16
MM + Cleavage Club #16
http://www.youtube.com/watch?v=NviuotZgIgg
Originally Posted by philly78 View Post
^^ is my Bestest MM buddy!!
Old September 13th, 2010, 11:28 AM   #9
the long tubes help evacuation of the cylinders, letting more fresh air fuel mixture in.
Theoretically, it would actually detonate more because you have more of a charge in the cylinders.
stock manifolds act like a passive egr
but then you also have to factor in a cooler charge tempreture because of the lower boost pressure.
It would be interesting dynoing for these factors...
Old September 13th, 2010, 11:31 AM   #10
btw do you have your bullitt intake?
Interested )))
Old September 13th, 2010, 01:47 PM   #11
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
People boost KB's on Mach 1 and thats a 10.1:1 CR...so you can do it on a Cobra. Just get the intercooled version.
Old September 13th, 2010, 10:36 PM   #12
doesn't mean it's an efficient way for more power.
yes, it will be better with an i/c, but it will severely be limited by the compression ratio.
Old September 13th, 2010, 10:42 PM   #13
BYAHHHH!
2001 Mustang GT
13.874
yes true..but higher compression is actually good. Just the stock internals are to weak for it. With the higher compression you can make more power and less psi and have a better throttle response.
Old September 13th, 2010, 11:39 PM   #14
Actually with pump gas, you will not make more horsepower with higher compression.
To run higher boost with high compression, you gotta have e85 or race fuel.
You most defiantly will hit detonation before you endanger your bottom end with pump gas.
Old September 14th, 2010, 01:23 AM   #15
BYAHHHH!
2001 Mustang GT
13.874
i know you need higher octane with the CR being higher.
Timing is also a big factor in that
Old September 14th, 2010, 08:01 AM   #16
2001 Bullitt
Interested )))
Of course I have my Bullitt intake!! Unfortunately it's promised to someone
Bullitt Crew #16
Old September 14th, 2010, 11:14 AM   #17
Trick Tuners's Avatar
KB'd GT
You seem to be forgetting timings role in detonation. I agree with your statements, but you can reduce the timing and it will not be an issue at low boost (<10psi). Then if you put in some race gas it will make tons of power!
Old September 14th, 2010, 12:22 PM   #18
TRMach1's Avatar
2003 Mustang Mach 1
TRMach1 is on a distinguished road
You can run 8-10psi on either an intercooled Eaton or twin screw blower on a stock 10.1:1cr Mach 1 bottom end without any issues, provided the tune is dead on. And by that, I mean pulling about 17-18 degrees of timing, and an A/F ratio of 11.5.
To be on topic, I wasn't aware KB even made an intercooled 2.1 for the '97 Cobra, but I guess I never really looked for one. I wouldn't use a KB tune for anything more than starting up the car to get it to a dyno for a proper tune!
2003 Torch Red Ford Mustang Mach 1 5-speed
657 RWHP 635 RWTQ
My Mods
My Car
MODS: Yeah, it's got mods.
August 2012 AmericanMuscle.Com Calendar Centerfold!
Old September 14th, 2010, 01:11 PM   #19
I.D.G.A.F.
incorrect.
I'm incorrect by asking for evidence to what you have said?
I was correct by saying what I have said. Sean Hyland is not the end all be all for Modular engines. Just because he believes something doesn't mean it's the only way.
Old September 14th, 2010, 01:52 PM   #20
Cobra GT's Avatar
1997 Cobra
There is no inter cooler for the new 2.1L KB, I think the 1.7L or the 1.5L (older kits) had i/c set ups. I am running 6-7 psi of boost with 93 or better octane and will be fine. I will update my custom tune after the s/c install. If I had a totally stock motor and no other mods I would fell safe using there tune, but would do some pull just to see the numbers. I am going to run 42# injectors, 90mm MAF, KB’s FMU & Boost-a-pump, Walbro 255lph fuel pimp, I don’t think it will be starving for fuel. I will get a custom tune with wideband I will post some numbers after it is done, thanks fellas.
96 GT (sold)
97 Cobra
93 Ranger
Threads Similar to: Kenne Bell tunes GOOD or BAD ?????
Kenne bell 2v here. SCREWd2V New Members Introductions 48 July 15th, 2010 02:11 AM
Where is a good place to sell Kenne Bell Supercharger??? tjf9389 94-95 11 June 29th, 2010 10:53 AM
Kenne Bell on a 2v thepizzle44 99-04 24 February 14th, 2009 12:02 AM
kenne bell mustangjl 99-04 4 February 7th, 2008 07:02 PM
