oil on spark plugs.
i went to change my plugs and i noticed on one of them i looked down in there and there was oil sittin at the bottom by the plug. could anyone tell me what this could be maybe piston rings or head gaskets?
#2 | |
Stick the plugs in, USE anti-sieze, and start her up! If blue smoke starts pouring out, then come and get some help
4V twin turbo 2000 GT
I live my life a quarter mile at a time xD
Spark plug tube seals on the valve cover/head are bad.
2000 Mustang GT Built 4V Motor with Sullivan Single Plane Intake Custom 66MM BB TT kit Borla XR-1 Dumped before rear Moser built 9" Rear 35 spline WaveTrac Diff with 3.75s 35 spline Moser axles 14PT roll cage and minitubbed
1996 gt 97cobra boltons
+1 replace your valve cover gaskets and tube seals. there a little difficult
MM Cobra Club Member #32 |
97GT & 97Snake & 00L
T.B.A
i notice that to when i changed my spark plugs well just on one, is it really that hard to change our the gaskets?
![]() 97 Cobra & 00 Lightning Beauty & The Beast I rev next to hybrids so they can hear me kill the environment ![]() MM Cobra Club Member #77 MM Lightning Club Founder |
ya i only had it in my number 1 chamber every other one was just fine
yea almost 2hours and a few frustrations later and the passenger side was done ha
T.B.A
any tips or ideas, anything we can do to make it easier seeing as u did it already.
Just pull the valve covers off and replace. Felpro sells a valve cover gasket kit which has everything needed. Just make sure you use a good amount of Indian head gasket sealer.
make sure you put good rtv in the creases of the valve cover where it seals to the head and let that rtv dry for an hour or so also make sure NOT to pinch the gasket up against the firewall under the fuel disconnects its hard to reach back there and it binds up the gasket....
Indian cement is stronger than regular RTV for the spark plug seals.
T.B.A
good info thanx
i didnt do anything for my tube seals i read alldata and it said nothing about it..
It doesn't say to but you really should for something that sees a lot of oil.
KB'd GT
I'd run a compression check to determine the rings sealing ability.
i redynoed at 272rwhp and 280rwtq
T.B.A
what mods are done to your cobra?
100% stock minus 2 flowmaster mufflers just extremely well maintained..
T.B.A
wow not bad for just flowmaster, not bad at all.
thanks i think so to.. its been well maintaind
Threads Similar to: oil on spark plugs.
| Spark Plugs Gap for Colder Plugs | Matt. | V6 Mustangs | 5 | April 10th, 2010 11:48 AM |
| 94 mustang gt oil on spark plugs | gtstangrunner | 94-95 | 11 | May 12th, 2009 08:38 PM |
| Oil on the spark plugs? | 1997Stang | 4V / SVT | 17 | May 6th, 2009 01:21 PM |
| Oil on spark plugs | jim.munoz | V6 Mustangs | 7 | March 29th, 2009 02:37 PM |
| Spark plugs,antifreeze, oil and power steering fluid questions for the guys who know | CODEBLUE | 99-04 | 5 | February 25th, 2008 04:12 PM |
