Broken header bolt - Page 2
Old September 22nd, 2010, 01:25 PM   #21
Trick Tuners's Avatar
KB'd GT
Is that one of the welded studs on the header to midpipe flange connector? You could drill it out and use a regular bolt, but it will be a pain to hold the other side.
Old September 22nd, 2010, 01:30 PM   #22
Hourofpain's Avatar
2005 Torrid Red GTO m6
Hourofpain will become famous soon enough
Im not sure if it is welded or not.
1996 Cobra
To be sold...
2005 M6 Twin Turbo GTO Torrid Red
Fully Forged LS2 Block Built to handle 1000RWHP. Fully ported Dart Heads. Edelbrock Jr Intake. Custom cut upper intake plenum. APS twin Turbo System with APS twin Fuel pumps.
Old September 22nd, 2010, 01:38 PM   #23
KB'd GT
My JBA headers have one welded stud.
Old September 22nd, 2010, 01:40 PM   #24
Hourofpain's Avatar
If i grind down the bottom portion of the flange about half way there shouldnt be any side affect right?
1996 Cobra
To be sold...
Old September 22nd, 2010, 01:45 PM   #25
KB'd GT
I wouldn't do that. It may make it weak, then it will bend and you wont get a good seal. Is the midpipe removed? Its hard to tell in that picture. You can remove the headers too. Its a pain, but its not that bad.
Old September 22nd, 2010, 01:50 PM   #26
Assistant to the Manager
Smoothgrandmama's Avatar
12 GT
8.46@88 1/8
Smoothgrandmama is just really niceSmoothgrandmama is just really niceSmoothgrandmama is just really niceSmoothgrandmama is just really nice
iTrader: 6 reviews
Send a message via AIM to Smoothgrandmama Send a message via Yahoo to Smoothgrandmama
Torch
Join The MM Facebook:
Modded Mustangs Facebook
Vote For Modded Mustangs Ride of the Month
Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal, 101Fng
Old September 22nd, 2010, 01:55 PM   #27
Hourofpain's Avatar
it is a very thick flange though and it would only be outside the nut. id leave most of the rest intact
1996 Cobra
To be sold...
Old October 4th, 2010, 05:55 PM   #28
Hourofpain's Avatar
alright went to ford to order a new stud.
apparently it is actually a bolt.
i just gotta figure out how to get it out.
I cant really afford to not have my car for more than a day on the weekend.
and every shop i called wants to put it on a lift first to look at it.
i figure someone has had to back one of these fuckers out.
i have access to a lift and every tool except for a welder on base.
i have 8 hours to do it on a sunday.
someone suggested putting nuts on it to back it out.
Could that even work wouldnt it tighten it in?
1996 Cobra
To be sold...
Old October 6th, 2010, 07:56 PM   #29
Look Ma! My First Post!
1984 Mustang GT
NA
Fox4v is on a distinguished road
Are they stock manifolds? Can you buy a set on ebay and replace the bad one? Then fix the one you have now a sell the set.
Threads Similar to: Broken header bolt
pinion shaft lock bolt broken GTVert00 99-04 5 July 3rd, 2009 01:19 AM
Best way to get a broken bolt out? Zatrekaz V6 Mustangs 34 May 30th, 2009 08:26 AM
broken bolt !!!!!!!! armymike63b 4V / SVT 4 March 10th, 2008 11:05 PM
Broken bolt in brake caliper smoke-em 99-04 14 July 31st, 2007 05:25 PM
Broken Valve cover bolt kinghack 2005 - 2010 6 February 21st, 2007 05:45 PM
