Broken header bolt
Old September 22nd, 2010, 01:23 AM   #1
Hourofpain's Avatar
2005 Torrid Red GTO m6
Hourofpain will become famous soon enough
Broken header bolt
Went to uninstall the h pipe and snapped the lower manifold flange bolt off on the passenger side.
It is not however a clean snap so theres room to work.
is there any way i can put a nut on and back the bolt out of there?
or use an easy out.
I really dont want to pull the exhaust manifold.
Cant afford to right now and i cant stand this horrific exhaust leak.
The cobra is running like shit right now because of it.
HELP!
1996 Cobra
To be sold...
2005 M6 Twin Turbo GTO Torrid Red
Fully Forged LS2 Block Built to handle 1000RWHP. Fully ported Dart Heads. Edelbrock Jr Intake. Custom cut upper intake plenum. APS twin Turbo System with APS twin Fuel pumps.
Old September 22nd, 2010, 07:44 AM   #2
Hourofpain's Avatar
what if i grinded down part of the flange and that gave me just enough room to slip a nut on and torque it down?
1996 Cobra
To be sold...
Old September 22nd, 2010, 08:10 AM   #3
CobraStang161's Avatar
4V twin turbo 2000 GT
I live my life a quarter mile at a time xD
CobraStang161 will become famous soon enoughCobraStang161 will become famous soon enough
Is there enough room to get a vise grip in there? If so just clamp the vise grip down really hard and just turn it counterclockwise. It should come out with ease. My suggestion is invest in some stage 8 locking header bolts. Their like 40$ from dagostino racing and they are very strong, and won't loosen up over time.
Built 4V Motor with Sullivan Single Plane Intake
Custom 66MM BB TT kit
Borla XR-1 Dumped before rear
Moser built 9" Rear
35 spline WaveTrac Diff with 3.75s
35 spline Moser axles
14PT roll cage and minitubbed
Old September 22nd, 2010, 08:36 AM   #4
Hourofpain's Avatar
there is noooo room for a vice.
1996 Cobra
To be sold...
Old September 22nd, 2010, 09:30 AM   #5
I would suggest welding a nut on it then and removing it that way.
Moser built 9" Rear
Old September 22nd, 2010, 10:42 AM   #6
Trick Tuners's Avatar
KB'd GT
If you can get a small pipe wrench on there it will get it out. The pipe wrench is a great tool for getting out the shafts of broken bolts, as long as it sticks out about 1/2" or more. It its sticking out 1/4" you might give it a shot, but welding a nut on may be a better option in that case.
Old September 22nd, 2010, 11:28 AM   #7
Hourofpain's Avatar
So you guys are saying that i can in fact be backed out?
1996 Cobra
To be sold...
Old September 22nd, 2010, 11:43 AM   #8
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
yes^
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old September 22nd, 2010, 11:44 AM   #9
Hourofpain's Avatar
it can come out the direction facing the deck.
Not the overhead?
1996 Cobra
To be sold...
Old September 22nd, 2010, 11:50 AM   #10
Hourofpain's Avatar
can i not just put a nut on there and turn the impact to tighten and just pull it out that way?
1996 Cobra
To be sold...
Old September 22nd, 2010, 12:15 PM   #11
KB'd GT
no, that is a bad idea and might break off the last bit. I don't see any way to use a nut without welding it on there.
Old September 22nd, 2010, 12:30 PM   #12
Hourofpain's Avatar
so if i understand correctly there isnt a top to this stud.
as in nothing secures it on the engine side to the flange?
1996 Cobra
To be sold...
Old September 22nd, 2010, 12:36 PM   #13
no, its just a stud.
Moser built 9" Rear
Old September 22nd, 2010, 12:49 PM   #14
Hourofpain's Avatar
then how does it stay secure inside the flange and why would screwing a nut on to back it out be a bad idea?
1996 Cobra
To be sold...
Old September 22nd, 2010, 12:49 PM   #15
zigbigadoru's Avatar
97 Mustang GT
slower than the speed of smell
zigbigadoru will become famous soon enoughzigbigadoru will become famous soon enough
....what are you guys TALKING about? it has to be connected at BOTH ends or it would just fall out...
if its a stud you can turn it counter clockwise and it will back out....if its a bolt then you should be able to rip it out the other end or turn it clockwise (counterclockwise for the bolt) and it should come out
Originally Posted by XTCNAGT View Post
That's what you get for excercising.
You think my lungs and chest hurt when I drive down the road for a triple baconator? No. You know why? Cause I'm smart.
Time for a nap.
Old September 22nd, 2010, 12:53 PM   #16
Hourofpain's Avatar
1996 Cobra
To be sold...
Old September 22nd, 2010, 01:02 PM   #17
Hourofpain's Avatar
I have no access to a welder or a placed to take it off and weld a nut on. its why i ask if i could just grind down the flange enough to fit a nut on the stud.
1996 Cobra
To be sold...
Old September 22nd, 2010, 01:11 PM   #18
Hourofpain's Avatar
I called a shop and was told it would be around 200 dollars just to weld a nut on and pull the stud out
1996 Cobra
To be sold...
Old September 22nd, 2010, 01:13 PM   #19
cc250r is on a distinguished road
use alot of jb weld jk if you cant get it out just drill it out and re thread it
Bassani o/r x, lm1, H&R JLT RAI, tinted head and tails, HID's
http://www.youtube.com/watch?v=nDlg5wLgGIg
03 f350-8" lift, moto metal 951's, toyo m/t 37/13.50/17, no cat borla,20% all aroud
MM cobra club #121
Old September 22nd, 2010, 01:22 PM   #20
Hourofpain's Avatar
there is no room in there for a drill
1996 Cobra
To be sold...
Threads Similar to: Broken header bolt
pinion shaft lock bolt broken GTVert00 99-04 5 July 3rd, 2009 01:19 AM
Best way to get a broken bolt out? Zatrekaz V6 Mustangs 34 May 30th, 2009 08:26 AM
broken bolt !!!!!!!! armymike63b 4V / SVT 4 March 10th, 2008 11:05 PM
Broken bolt in brake caliper smoke-em 99-04 14 July 31st, 2007 05:25 PM
Broken Valve cover bolt kinghack 2005 - 2010 6 February 21st, 2007 05:45 PM
