Mark VIII engine question
So I dropped the 460 82 fox build to stuff a 95 mark VIII 4.6 in it instead. I'm trying to figure what gears to run right now. I'll be using the 4R70w that came with the markVIII. My question is, On a stock 4.6 dohc what rpm do they stop making power? The engine is going to be stock for a while w/only full exhaust.
Thanks.
Cars Dont Power The Front Wheels, They Lift Them 4v teksid block w/2v heads FINISHED 14 April 2010 2003 vert gt 2v teskid build 12.7 @ 107 (SOLD) ![]() 1989 mustang lx |
1970 Mercury Cougar.
Peak power usually arrives at 5500RPM and peak torque at around 4800RPM. You really have to spin these suckers. Run a 4.10 gear minimum. Are you going to be running the Mark VIII computer?
1970 Cougar. |
4V swapped '02 GT
(2v) 13.9@101
![]() ![]() ![]() ![]() iTrader: 10 reviews
you get the most power out of the B heads revving the piss out of them, the problem in the Mark VIII's are the cams. they arent as aggressive as the 96-98 Cobra's and i believe will make the most power down a little lower. i know my Mark VIII motor untuned in my car does make GREAT power from 3000rpm up until redline (6000rpm) when i ahve my car dyno'd (hopefully by the spring) i will post the graphs.
![]() BSD 100MPH Club YMR #8975 4v Swap and a little Purple Bottle ![]() MM Nitrous Club #7 MM Cobra Club #87 |
#5 | |
My sister has a 96 Mark VIII with functioning IMRC's and it has plenty of power below 3K, even with the 3.08 gears.
1970 Cougar. |
Its going to be as stock as stock can be minus LT headers. I'll be running the mark ecu and harness, well both ecu's. I was trying to decide between 4.10's and 4.30 gears. Leaning more toward the 4.10s now. Then Spraying 100shot of nitrous. The engine has 90k on it.
Another vote for 4.10's.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
4V swapped '02 GT
(2v) 13.9@101
yes sir, i agree. it feels about the same as my 2v down lower in the rpm's. when i have it tuned im gonna have a bit of timing added (just a few degrees so i can still be Nitrous-Safe) to help with the lack of IMRC's and then the 4.10 gears should help out alot with that too. looking back on it, i'm thinking i maybe should have looked around a bit more for a set of 4.30 gears because i am having the redline moved up to 7,000 rpm on this motor.
![]() BSD 100MPH Club YMR #8975 4v Swap and a little Purple Bottle ![]() MM Nitrous Club #7 MM Cobra Club #87 Last edited by LGHTNG02GT; October 2nd, 2010 at 03:27 AM. |
4.10's and please don't run nitrous on a stock block and window it
=D
1998 Gt full pi swap -Dead and gone 1998 Mark VIII 4.30s, 125 shot, 93 d/s-Daily Driver 1998 BAB Cobra-Project |
#10 | ||
Stock block can take a 100 shot just fine.
1970 Cougar. |
Threads Similar to: Mark VIII engine question
| quick question. fuel rail question on mark viii swap | Speedy1221 | 99-04 | 7 | October 12th, 2011 11:02 PM |
| few mark viii swap question. | Speedy1221 | 99-04 | 12 | July 23rd, 2010 05:02 PM |
| engine swap from 99 v6 - 1993 lincoln mark viii v8 4.6 ? | Horseyxpowered | V6 Mustangs | 6 | June 21st, 2010 11:10 PM |
| Mark viii engine vs Mach 1 engine | Project_Mustang | 99-04 | 24 | February 27th, 2010 06:58 PM |
| Engine swap question. mark viii | Project_Mustang | 99-04 | 5 | February 16th, 2010 10:21 AM |
