TPS Voltage
Old September 30th, 2010, 03:33 PM   #1
Villain123's Avatar
2003 Just A GT
Villain123 is on a distinguished road
TPS Voltage
So I have a friend with a 99 Cobra that has been having issues with the way his car idles and after talking to him I found out that he replaced the TPS on his car but never set the voltage and I had told him that when I replaced my throttlebody and plenum I had to adjust the tps to get the voltage at .98 to get my car to idle correctly. I have followed the same steps I did with my 2003 GT but can not get a voltage reading of any sort from his. Any ideas or thoughts would be appreciated. I have even had him hold the ground wire on my volt meter to the ground on his battery and tried to get any sort of signal from all three wires. The process I used to adjust mine was stuck a pin through the grey wire with white stripe and the grey wire with red stripe, turned the ignition to the on position and place the volt meter on DC, touched the red wire to the grey/white and black to grey/red, twisted the tps to where the volt meter read .98 and then tighted the two screws back down and mine has been perfect since.
Old September 30th, 2010, 04:28 PM   #2
Villain123's Avatar
2003 Just A GT
Nevermind, I figured it out! Thanks for looking any way!
Threads Similar to: TPS Voltage
TPS Voltage question ZenMGT 99-04 6 September 21st, 2010 11:19 AM
no voltage. crazyredneck 5.0 Mustangs 2 September 1st, 2010 08:11 PM
O2 Voltage Roush00 99-04 4 March 16th, 2010 11:29 PM
Zex TPS compared to NX TPS for our cars 06Black5spdGT 2005 - 2010 8 December 22nd, 2009 02:22 PM
what is stock voltage on TPS tryingtobebest 5.0 Mustangs 8 January 14th, 2009 10:50 PM
