5 mustang build(th400 03 cobra swap)
hey guys id figure id post up a thread showing the progression of my build..
i bought this car for 400 bucks as a v6 as a great project car!!!!! ![]() ![]() ![]() ![]() NOW FOR THE PROGRESS ![]() ![]() ![]() ![]() ![]() few pics of parts that will be installed this week ![]() ![]() ![]() ![]()
sorry for the dusty suspension.. was doing bodywork on the quarters
![]() finally starting to look like an engine bay ![]()
1998 Mustang Cobra
we can has more info about what youre doing with it?
![]() " When in doubt, go flat out"- Colin McRae MM Cobra Club #76 MM Cleavage Club #14 285 CREW #8 |
since you started from scratch i would go ahead and do a tuck on all those ugly ass wires...will look 100% better.. or at least the ones on the passenger side..
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
#5 | |
what do you mean? doing as far as what?
i was gonna do this but i never had a chance to plug up all the holes in the bay so im just gonna leave it. looks kinda ugly with all them holes and no wires. what i am gonna do tho is simplify the harness.. iwont be using abs so imma remove the connector and wires..same goes for all other things i wont be using... ie: washer fluid pump, cruies control, wiper motor... also gonna be relocating the battery Last edited by terminated95svt; October 4th, 2010 at 12:17 PM. |
#8 | |
03 cobra motor comp cams upper lower pully w/idler set posi race port kooks long tubes still has stock pos rear but once car is all running it will be getting a mini tub with a moser m9 rear... 4:54 gears.... as for the trans i have a jw th400 kit..th400 trans will be rebuilt by ziggy's. they are based out of nj and i hear the do great work!!! |
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
Curious as to why you put all that MM stuff on there if it's going to be a drag car. There's a lot of stuff out there that's a lot cheaper, a lot lighter, and a lot more geared towards drag racing.
Do the Right Thing, Cook. ~Zip. |
#11 | |
purchased the full kit for 500 bucks at a swap meet... couldnt pass that deal up.. i also didnt want a full drag setup.... depending on what coil spring rate i install i can have it set up for drag or road course.also went with this one cuz this car will be driven on the street and i would like some kind of streetable drivability.. wasnt looking for the lightest kit out there either.. so far from what i can see.. the mm k member, control arms, and cc plates are made verry well.... Last edited by terminated95svt; October 4th, 2010 at 04:57 PM. |
$500 for all that, well worth it. Good find! Good luck with the rest of the build
1998 Mustang Cobra
yeah i would definately paid that much for it. Good luck with the build. I shall continue to follow.
Threads Similar to: 5 mustang build(th400 03 cobra swap)
| Motor Swap 4v Build Thread... | ZoomZoomMFer | The Clubhouse | 107 | August 9th, 2010 10:39 AM |
| 1995 5.0L Cobra Mustang 5.4L Engine Swap | 1995CobraSvtMaddux | 94-95 | 16 | August 3rd, 2009 09:01 PM |
| Cobra engine swap/build | Reloaded | 4V / SVT | 18 | April 27th, 2009 08:20 AM |
| Swap and Build | Kirko | 94-95 | 12 | July 19th, 2007 05:52 PM |
| Motor Build And Swap | 5.0mustang9509 | 5.0 Mustangs | 2 | November 8th, 2006 09:25 PM |
