cooling system problem(need help)
Old October 11th, 2010, 09:07 AM   #1
rob madison is on a distinguished road
I have a 98 cobra, put a brand new radiator, water pump, and thermostat in and its still overheating. What else could cause it to over heat?
Old October 11th, 2010, 09:10 AM   #2
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Is the car stock? Is the fan operating correctly (both high and low speeds)? How high are the coolant temps reaching?
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old October 11th, 2010, 09:11 AM   #3
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Headgasket, electrolysis, collapsing hoses, air in the system, etc.
We need more info...
As soon as you fire it up, does it start overheating?
I would first try purging the system of air as usually this is the most common first problem.
Old October 11th, 2010, 09:18 AM   #4
the car is all stock, when i fire it up and its at a idle speed, the temp gauge goes from cold to have way. I drove it up the street and the temp gauge started going towards hot as the car heated up more. My fan is working fine.
Old October 11th, 2010, 09:22 AM   #5
Tang Stang's Avatar
Did it just start doing this? I'd recommend installing a "real" gauge or using a handheld tuner to datalog coolant temps to see what the actual temps are. Halfway on the stock gauge doesn't tell you anything.
Old October 11th, 2010, 09:29 AM   #6
yeah, couple a weeks ago was on the highway with the a.c. on, noticed my last radiator was cracked on the side. So i took it out put the new one in with the pump and stat, and started having this problem. Do you think the radiator having a crack could have let in air in the system?
Old October 11th, 2010, 09:30 AM   #7
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
weems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud of
I'm not real familiar with SN95 cars but you might have to burp it.
Old October 11th, 2010, 10:35 AM   #8
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Yeah, Ryan, it's nearly the same procedure to burp it.
Old October 11th, 2010, 01:24 PM   #9
2003 SVT Cobra
11.70 @ 121
Then he definitely needs to do so, you can't just add water and go.
Threads Similar to: cooling system problem(need help)
Draining the cooling system 07 Boss 2005 - 2010 12 January 22nd, 2010 02:08 AM
Cooling system question snosourfur 5.0 Mustangs 6 July 31st, 2009 02:44 PM
Cooling System Issue prosbloom225 V6 Mustangs 8 April 14th, 2009 07:51 PM
cooling system? competition orange 99-04 8 March 26th, 2009 08:28 AM
Problem With Cooling System Baby96 All Other Vehicles 7 January 11th, 2008 10:44 AM
