2007 Shelby GT500
Best Value Here???
Here's the deal, I currently own a 2008 GT 5 spd which I have up for sale. I am considering buying a cobra/mach/something somewhere in the 5-50k miles range with the intentions of slapping on a kenne bell or possibly a turbo kit at my local speed shop that I trust. I want to keep the cost of the car at 20k or less so no new 5.0 suggestions please.
With that said I am really looking for a good platform meaning a good motor to handle the extra power, a strong rear end, strong trans, upgraded brakes would be a bonus. Clearly I know I will have to make some of these adjustments on my own dime, I know that part. My question is which one carries the best value to buy and start a 600-700hp project with?? 1999 Cobra 2001 Cobra 03-04 Cobra 03-04 Mach 1 It appears the 01 may be the best option given I would plan to blower swap an 03-04 anyhow if I bought that - what do you think? |
2003 Cobra
www.slow.com
I vote 03-04 cobra... Terminator can handle the most power out of those choices. IDK what you want to build it into, but SRA swap would be fitting on a 700rwhp termi or keep the IRS, brace it, and pray.
so my vote is terminator with kenne bell + supporting mods.... but with your parameters (5-50k miles and total cost under $20k i doubt this is possible)... so Mach 1? |
2007 Shelby GT500
well i was trying to budget $20k for the car plus on a guess $10-12k for shop time/parts ... in theory i could go higher up into the budget if necessary but would like to avoid getting 50 deep into a mustang haha
2003 Cobra
www.slow.com
MM's Orangest
2004 Mach 1 Mustang
The Terminator is going to be the best buy. If you take into account the motor rebuild and transmission swap/rebuild (to make it on par with a Termi) you're going to make up the difference really quick. You can swap with another Mustang owner for their SRA at probably no cost to you except some time.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
97 Mustang GT
slower than the speed of smell
^ummmm no to what these guys said. a motor rebuild depending on what you do to it can cost as little as 1k and if you start with 10-15k of a car and get an aluminum engine i would have to say that the cheaper route is better....
if youre going to build it yourself then the internals dont really matter as much as much as the quality of the block. iron<aluminum in almost EVERY case also with the 99/01 cobras you also get SRA which is better for drag racing and can just handle more power without breaking. basically, buy the car that has the best of what you ARENT replacing because everything else doesnt matter. |
#7 | |
2003 SVT Cobra
And I really don't see how you can build a 99/01 motor up to hold 700 horsepower for $1,000. The price of 03/04 Cobras are dropping drastically. 04's with decent miles are showing up with asking prices of $18K and less.
![]() 03 Cobra-Slow 02 SS, 00 Z/28-Gone Rest In Peace Travis Billings
#8 | |
MM's Orangest
2004 Mach 1 Mustang
2007 Shelby GT500
please take note, i said i had a budget of 10,000 to 12,000 to allow for parts and labor at the shop...
#10 | |
2007 Shelby GT500
#11 | |
97 Mustang GT
sorry i thought the 99/01 was SRA my bad. guess thats only 96-98 |
Buy an 93/04 Cobra, slap a Whipple on it and call it a day.
I would think a MACH 1 would be the best bet since you are going to slap on a new super or turbocharger. Isn't the engine in the MACH 1 the same engine minus the eaton as is in the 03/04 cobra?
RIP 06 Mustang GT New Ride 04 GTO K&N intake, Dynatech Long Tube Headers, Magnaflow catted X, Flow 40s, MS3 Cam and dynotuned by Texas Speed. |
2003 gt
5.4 32v on the way
Id say get an auto mach, then swap in a forged rotating assembly for a turbo. The auto will take a lot of power, you start with a solid rear, and you should be able to do the rotating assembly for less than the difference between the mach and termie. If you wanted an easy 400-500 id say go with a termie, but because you are talking about doing a 600-700 turbo car a mach isnt a bad choice.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
for 700hp I wouldn't worry about iron or alum b/c both will hold it fine. Alum is nice b/c it's lighter.
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
Noob Slayer
13.82 @ 101.09
its scary how much misinformation there is about the different models. thanks rk and machboy for clearing it up lol
![]() 2003 Black Cobra 10th Anniversary 2.8 Kenne Bell Mammoth LC - Built SRA - T56 - E85 - Spray - Stock Longblock - True Forged Mach 5s 2004 Silver GT 5 speed - SOLD MM Cobra Club Member# 97 |
BYAHHHH!
2001 Mustang GT
13.874
the compression it higher on the Mach1
2003 SVT Cobra
Not to mention the rods aren't nearly as strong in the Mach1. I don't think I've ever seen a Mach make more than 500 rwhp and last very long on the stock bottem end. Not saying it can't be done but it's an everyday thing for Terminators to make that kind of power.
Also, Mach1's have an alluminum block and solid axle. So a lighter platform.
#20 | |
2003 SVT Cobra
And either way, if you get a Mach1 or a Cobra, you better plan on upgrading at least the rear end if you are aiming for 700hp.
