Starting to collect parts and planning for engine overhaul and temporary build
Old October 19th, 2010, 09:37 PM   #1
brharris777's Avatar
1998 Mustang Cobra
brharris777 will become famous soon enoughbrharris777 will become famous soon enough
Ok so as soon as a see a snowflake i am gonna start ripping the 140000 mile 4 valve out of my cobra. It needs the valve seals replaced and i know the heads can stay on the car for it but i need a winter project too. I want to disassemble, inspect, re ring, do the appropriate head work, possibly find a set of affordable used N/A cams that are in good shape, and maybe a set of flat top pistons. I want to go blown eventually but its not gonna be in the cards for a while and im not sure exactly what i want to do so for now id like to pick up a few horses and refresh this motor. Anyone have any suggestions about other stuff i should do while im in there?
" When in doubt, go flat out"- Colin McRae
MM Cobra Club #76
MM Cleavage Club #14
285 CREW #8
Old October 19th, 2010, 10:52 PM   #2
98Cobra_sleeper's Avatar
1998 mustang cobra
98Cobra_sleeper is on a distinguished road
i would just send the heads away to have them fully rebuilt and ported. i paid 2300 for full rebuild and a raceport. prolly the best money i spent. high end pull was great. only regret i didnt do was cams. possinbly port the lower intake?
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup)
comin soon...ON3 turbo kit, PTE7175
Old October 20th, 2010, 01:54 AM   #3
majorownage is on a distinguished road
get an mmr oversize valves, bronze valve guides, and Beryllium Copper valve seats.
If you have an oven, you can do alot of the hard work yourself. Heat to 400-500 and use a properly sized punch to remove the guides. The reverse is about the same, except it helps to use some N_2 to cool the guides down. They slip into place.
Seats and valves will have to be installed by a shop. Make sure they use sunnen machines.
Then blend the seats into the runner yourself.
An easy 20-30rwhp
1998 Gt full pi swap -Dead and gone
1998 Mark VIII 4.30s, 125 shot, 93 d/s-Daily Driver
1998 BAB Cobra-Project
Old October 20th, 2010, 10:56 AM   #4
1998 Mustang Cobra
ill be doing the headwork at school, we are only allowed to do "repair" work and cant do any porting, i can do the guides, seals, seats, springs, and retainers. Then i figured i would do a mild porting on the heads and port match the exhaust port to my longtubes. Porting the lower intake sounds like it would probably be a worthwhile mod. How about throuttle body and upper intake porting?
MM Cobra Club #76
285 CREW #8
Old October 20th, 2010, 12:17 PM   #5
Tb porting isn't really worth it unless you have a kennebell or whipple.
head work (not porting) is easy hp
porting is a wee bit harder especially if you have never done it before; very easy to go overboard
Old October 20th, 2010, 07:08 PM   #6
1998 Mustang Cobra
ok so skip the throttle body porting. Im going to have a local machine shop do the porting on the heads and the lower intake, so i have someone to blame if things go bad.
MM Cobra Club #76
285 CREW #8
Old October 20th, 2010, 09:44 PM   #7
vita's Avatar
1999 Mustang Cobra
vita has a spectacular aura aboutvita has a spectacular aura aboutvita has a spectacular aura about
Send a message via AIM to vita Send a message via Skype™ to vita
btw, I got your text. Mod on... if you need help you know where to find me!
Originally Posted by mrsinister2424 View Post
... I roll up with my retarded exhaust setting off car alarms and wetting panties for miles.
MM Cobra Club Member #51
Threads Similar to: Starting to collect parts and planning for engine overhaul and temporary build
Starting the paint planning WAR-PARTY The Clubhouse 7 October 19th, 2010 03:47 PM
Starting to collect parts for build, need help Cincy6er V6 Mustangs 14 October 17th, 2009 09:40 AM
Planning a build Weeble 5.0 Mustangs 26 March 19th, 2009 04:57 AM
Have some questions on an engine build I'm planning Mike Johnson 5.0 Mustangs 20 February 21st, 2008 08:09 PM
Starting my 306 engine build shurb125 5.0 Mustangs 48 February 9th, 2008 01:41 PM
