2003 Mustang GT
03/04 Mach 1 Block limit?
I found a great deal on an 04 Mach 1 longblock, everything from fuel rails to oil pan. Has knock, And I plan on building a motor this winter. So I figured this would be a great platform to start with. Steel crank, 4V heads, Aluminum etc..
So my question/s are, whats the limits on the block itself? Not the rods/pistons, the block? I was thinking like 800hp? Also, I dont need the ECU right? Its pretty much drop in and connect right? Thanks guys Shaun
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
2001 Cobra
14.2@102 (I suck)
Not sure on the hp rating but im sure I read somewhere that switching from 2v to 4v requires an ECU swap as well. Hopefully someone will chime in to correct/agree with me
![]() 2001 Cobra with SRA swap, modded for twisties ![]() MM Cobra Club Member #76 |
Threads Similar to: 03/04 Mach 1 Block limit?
| 03 Gt Block Vs 03 Mach 1 Block | lethal-mach1 | General Tech | 1 | August 31st, 2010 12:30 PM |
| What is the limit for the GT 500 as far as the boost on stock block | navyman8903 | 2005 - 2010 | 16 | January 2nd, 2009 12:20 AM |
| stock block on mach | zinc02GT | 4V / SVT | 26 | June 15th, 2008 02:10 AM |
| stock mach 1 block | Saleenwolf720 | 99-04 | 68 | September 2nd, 2007 03:32 PM |
| GT block vs Mach 1 block | 02MiNeRaLgRaYGT | 99-04 | 3 | August 3rd, 2007 04:17 PM |
