1998 svt cobra
13.00@104
5.4 wright ups?
hay guys im planing on trading my cobra well more like thinking about it. befor i say ok to a trade i was wondering if there were any 5.4 swap rightups. because if i keep this car i want to do a 5.4 with 4v heads off my cobra
Start with a navi engine. The have a forged crank and the same heads. Your cobra cams will swap in directly. The cheapest route for a good intake would be to use your cobra intake with spacers to fit the 5.4. Remember that the only good 5.4 block is the ford gt aluminum; the navi aluminum blocks are wap, good for a 700-800ish hp.
1998 Gt full pi swap -Dead and gone 1998 Mark VIII 4.30s, 125 shot, 93 d/s-Daily Driver 1998 BAB Cobra-Project |
MM's Orangest
2004 Mach 1 Mustang
The 5.4 will fit under your hood. You can't use your intake (unless you buy adapters) and you can't buy a longtube header unless it is custom. You're probably only going to see a little bit of a HP gain over the 4.6 but you'll get a nice torque increase. The best way to go is to buy a Sullivan intake or have an intake made custom.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
1998 svt cobra
13.00@104
thinking of making a intake and headers my self if i do swap
#5 | |
2003 gt
5.4 32v on the way
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
#6 | |
1998 svt cobra
13.00@104
2003 gt
5.4 32v on the way
not familiar with a NA 5.4 saleen or roush intake so I dont know. You would need to either get a 5.4 dohc manifold, or use adapters. Adapters and a cobra manifold are a cheap option that will work. Or you can hop over to corral.net and talk to birdman491, he sells 5.4 dohc kits that include an intake and everything fits under the stock hood.
1998 svt cobra
13.00@104
im not that good with the 5.4 will any intake used of a 5.4 fit any 5.4 engine like could i use a f250 intake on the navi 5.4 motor
2003 gt
5.4 32v on the way
one of the hardest parts of a 5.4 swap is the manifold. You can get a sullivan manifold for the 5.4. They discontinued it will be harder to find new, even used it might not be easy to find. Even harder to find would be to get a boss290/boss260 manifold, made in australia for 5.4 dohc motors in cars they get that we dont. The cheapest option would be to get a proper set of adapter plates that make a 4.6 manifold fit.
#10 | |
MM's Orangest
2004 Mach 1 Mustang
2003 gt
5.4 32v on the way
im not sure what all comes with the kit, but 2500 or so for everything you need to make a 5.4 a direct swap isnt too bad.
1998 svt cobra
13.00@104
no its not a bad price for the swap. i did do some rechearch on the adaper plates for the motor i might just have to go with a 2v or a 3v swap in stead of the 4v and on the other note i dont think it would be very hard to build a custom intake or do some heavy modding to the stock intake depending on what it looks like. and dose any one have a picture of the 5.4 in the navi
MM's Orangest
2004 Mach 1 Mustang
I'd rather have a 4.6 4V than a 5.4 2V.
2003 gt
5.4 32v on the way
Yeah if you are going to swap in a 5.4, go 4v. The intake part isnt easy, just join multiple forums and watch the classifieds. The stock navi intake is way way too big to work with, it wont come close to fitting under the hood.
2004 SVT Cobra
why not just keep the 4.6? jw.. 5.4 seems like a lot of hastle when you can pull great power out of a 4.6. but hey if you do do it props to you!
Garage: http://www.moddedmustangs.com/forums...e-member-9480/ 04 Cobra - STOCK for now
1998 svt cobra
13.00@104
i would keep the 4.6 if it dident caust a arm and a leg to build
2003 gt
5.4 32v on the way
A stock navigator with the swap kit from birdman makes decent power, with a chunk more tq than you are likely to get out of any combo using a 4.6.
![]() If you swapped over your 98 cobra intake cams and degreed it properly, it would probably make a solid 25hp+ more.
1998 svt cobra
13.00@104
+1 thanks for the info its starting to suck im havin a hard time finding a 5.4 4v
2003 gt
5.4 32v on the way
Just look around for navigator motors, the 5.4 4v should be found in navigators from 99-04, and can be had for 1000-2500. Car-Part.com--Used Auto Parts Market is a great place to start, it searches through places that part out cars, and you should be able to find a motor thats not too far away.
1998 svt cobra
13.00@104
i found a few really close to me what do you think about stacks on the 5.4 i think it would look sick and more like a race car but thats just me how hard would it be to make stacks
Threads Similar to: 5.4 wright ups?
| Why you should like you UPS... | supermachone | The Clubhouse | 64 | August 27th, 2010 01:56 AM |
| F*** Ups | mcqueen | The Clubhouse | 17 | June 10th, 2010 04:37 PM |
| Thank You UPS! | Aaron07GT | 2005 - 2010 | 21 | February 25th, 2010 02:03 PM |
| UPS!!! | mustangjeff1997 | The Clubhouse | 4 | November 9th, 2008 11:42 PM |
| ups | raceruler03 | The Clubhouse | 21 | October 4th, 2007 07:37 AM |
