Turned the Key after a fresh build...Now i have questions - Page 2
Old November 24th, 2010, 06:18 PM   #21
jjj0923 is on a distinguished road
what kind of break-in oil/additive are you using?
ps: great looking car and engine!
Old November 25th, 2010, 11:03 AM   #22
bigz5000's Avatar
1998 Mustang Cobra
bigz5000 will become famous soon enough
Just using a conventional oil with no additive. I'm at 50 miles and am going to change it tomorrow, anything special I should be using? The autozone here has royal purple break-in oil but its like 10 a qt
MMR Built Short Block, Vortech V1 Supercharger, AIS Methanol Injection, BBK LT's, X Pipe, Flowmasters, Steeda Springs, Tokico Shocks, Spec 2+ Clutch, Tri Ax shifter, 4:10's, SCT Tuner
Old November 25th, 2010, 12:54 PM   #23
that's great. Conventional oil is perfect. I have used some zinc additives in the past on rebuilt engines...but long term I saw no advantage over just regular oil. I do use Royal Purple in my engines. yea, it's expensive but a lack of problems for me over the years speaks for itself. I also like Royal Purple's water wetter to drop the water temp too in my cars.
Using Royal Purple in my BBC Blown boat engines drops my oil temp 20 degrees over conventional motor oil - which normally run anywhere from 190 to 220 degrees (oil temp). The engines run stone cold (100 to 115) because they're fresh water cooled.
Old November 30th, 2010, 01:55 PM   #24
bigz5000's Avatar
1998 Mustang Cobra
just drove the car for the first time last night since last weeks posts. Changed the oil last night, then took it out and let it get to temp. After that made 7-8 good pulls on it taking it up to about 6k in different gears giving it anywhere from 3-6lbs of boost. Does this sound suffiecient. I dont think it is smoking at all, but my dipstick tube isnt in all the way so it is leaking abit of oil and still has the buring oil smell. It is at the local dealership today getting the dipstick tube fixed. Easiest part of the new motor and yes i took it to the dealership. figured it was worth the hr or so of labor not to have to mess with it.
going to drive it another 400 miles or so then worry about the tune redone. Hoping to be at 450+. Now if i can just figure out how to keep the ass end on the ground...
Threads Similar to: Turned the Key after a fresh build...Now i have questions
2v build questions mustanginky 99-04 26 November 11th, 2010 09:43 PM
4.6 2v build questions Mustang02gt 99-04 25 July 18th, 2010 11:42 AM
95 GT Vert fresh build advice Pyro_123 94-95 5 November 18th, 2009 06:47 AM
a few questions on my build up lostchild 2.3 Mustangs 3 February 21st, 2009 02:57 PM
Broken Key Cylinder removal - Key will not turn, Ideas? Murago 5.0 Mustangs 6 June 21st, 2006 10:35 PM
