1992 Mustang LX
13.0 @ 105
650rwhp advice
In a Mach one. Help!
I'm not sure what to do for internals/compression. With the right rotating assembly, what can this block hold?? And I would like a turbo. What brand do you reccomend? And what boost levels will get me there.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
block will hold over 1000. so your fine there.
1992 Mustang LX
13.0 @ 105
Really?? Damn, they make a rotating assembly to handle that as well right? My dream was to get a boss302 block for my fox, boost it, and run 9's....But I have to sell it
And I've always loved the mach 1's, so I plan on grabbing one and turboing it
yes the BLOCK itself will hold over 1000 no problem, its the internals that wont!!
1992 Mustang LX
13.0 @ 105
I was just wondering about the actual block. I'm sure they make internals strong enough to withstand what I want
I want to be able to up the boost if I want and make even more power.
keep your car running---leave your current block in your car and drive it as is while you build a monster.
if you try and use iron, you probably will have issues at high hp (+900) Find a mark viii aluminum block...tear it down, and dig in! oh and go with je, mahle, or diamond. manley is just repackaged chinease crap
1998 Gt full pi swap -Dead and gone 1998 Mark VIII 4.30s, 125 shot, 93 d/s-Daily Driver 1998 BAB Cobra-Project |
1999 mustang cobra
![]() iTrader: 1 reviews
Compression you can't go bad with 8.5 and 16lb of boost
Black and White Crew Crew Member # 5 Check garage for mods and pics if you Los Angeles and want to ride send me a text (323) 270-6827 0% Wheel hop, 0% broken parts, 100% wheel spin |
Lol 8.5?
Bud, you need 10:1 and twenty pounds of boost to live
2001 Mustang SVT Cobra
Get a last production aluminum block, 8:5.1 compression and manley rods , JE pistons. 18-19 pounds will get you over that goal easy. I went with a Hellion Kit and is going in just in time for thxgiving. I'll post the results once complete.
To whoever said up there that Manley are just repacked chinese crap, what exactly do you drive and what base do you have for such an idiotic comment? Don't forget about fuel supply, tranny/clutch upgrade and such. Eventually, if you go for it, be prepared to spend big money.
Slow, really slow Cobra. Wanna see?![]() MM Cobra Club Member #81 "TAMPA BAY AREA CREW"
Are you serious?! Recipe for disaster.
#11 | |
8.5:1 comp is insanity. 10:1 with proper quench and a good piston, and you will still be able to run pump gas. Lots of torque in and out of boost. No compromise.
Agree to disagree. High compression and high boost don't work very well on the 4.6. Been there, done that.
Manley's are still excellent rods and products. They still have a name and tradition to protect.
#13 | |
"Been there done that"...on a stock block! =D Its been proven that high compression and boost go together... you just need very nice parts. 13 psi and 700whp? Sounds like impossible? Think again
noo you got it backwards, high comp and high boost doesnt go together, theres a reason you can only boost like 6-7 psi on the stock mach 1 comp...
Trust me, I don't know where this guy gets his facts from.
me either he has it completely backwards lol..
i might sound crazy as a fox but listen.
The import crowd has been turboing high comp engines for years. I wish I could say it was my idea, but it isn't. Many folks over at ModularFords have done high comp, high boost builds. Including a 10.7:1 2.3L whipple'd build. Haha I don't know what else to say.
#18 | |
Or be prepared to run race fuel and not have a daily driver.
KB'd GT
[quote=majorownage;3312073]
Its been proven that high compression and boost go together... you just need very nice parts. /QUOTE] Exactly. high compression and high boost make great numbers, but will require race gas for sure. For max power on pump gas you want low compression and high boost. You will loose off boost performance and mpg, but who cares! |
Threads Similar to: 650rwhp advice
| Tummy Pudge on GF.. need some advice .. Female advice as well!! | Dolbs4082 | The Clubhouse | 35 | January 1st, 2012 11:47 PM |
| need some advice | mustangmatt5 | V6 Mustangs | 11 | July 20th, 2010 11:54 PM |
| I need some advice?? | SCREAMPUFF87GT | 5.0 Mustangs | 0 | July 12th, 2010 06:07 PM |
| need some advice. | jat | 5.0 Mustangs | 38 | December 17th, 2008 09:45 PM |
| advice | mustang1072 | The Clubhouse | 11 | October 8th, 2007 10:40 PM |
