2003 Mach 1 susp. and brake questions
Old November 17th, 2010, 09:10 AM   #1
2003 Mach 1
Black03Mach is on a distinguished road
Hi all, Im lookin to beef up the suspension for more handling than anything, of course the car will run the 1/4 but that is not my main concern. More than likely it will see a road course more often. I will be buying weld in subframes when i do this. Also I want to upgrade my brakes (both front and back) but I cannot find kits with both the front and the back. Im looking to go bigger than stock.
Thanks for the help
Edit= I have H&R SS springs but the ride quality blows.
Old November 17th, 2010, 09:30 AM   #2
2003 Mach 1
Coil-Over Package, 1994-04 Mustang [COP-52] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
Looking at this
Old November 17th, 2010, 08:42 PM   #3
Blk01ponyGT's Avatar
2004 SVT Cobra
Blk01ponyGT is on a distinguished road
if your looking at coil overs those are great! if your not looking at going coil overs id say keep the H&R's and get a set of tokico D spec adjustables. they are great and can be adjusted for any kind of conditions. and ofcourse all of the other typical suspension mods. maximum motorsports stuff is great and ive had great experience with a lot of it. as for breaks if i were you id get the 2000 cobra R brembo front kit and call it done. the 4 piston calipers and slotted rotors will provide MUCH better breaking than stock and are great for the road course
Garage: http://www.moddedmustangs.com/forums...e-member-9480/
04 Cobra - STOCK for now
Old November 19th, 2010, 12:24 PM   #4
2003 Mach 1
im gonna go ahead and get the coils, do i still retain the springs/ shocks and struts or do i get rid of them entirely?
Old November 19th, 2010, 02:43 PM   #5
maverick2000 is on a distinguished road
There is really no reason for bigger brakes. What comes stock is fine. However, if you insist on bigger brakes, the most cost effective route, would be gt500 brakes.
Old November 19th, 2010, 02:53 PM   #6
Authorized Vendor
BMR Tech's Avatar
BMR Tech will become famous soon enough
If you are referring to the coilover kit, you will be getting rid of your H&R's.
The struts and shocks that come in the kit, will replace your current struts and shocks.
So yes, the kit you have linked....will replace everything you currently have as far as Springs/Shocks/Struts/Cast Camber Plates.
Kelly Aiken "The Ford Guy"
BMR Suspension Inc
kelly@bmrsuspension.com
813.986.9302
CLICK IF YOU LIKE BMR SUSPENSION
Old November 22nd, 2010, 12:32 AM   #7
ArDavis is on a distinguished road
Anything from MM is quality and would perform well but don't cheap out and not get your car set up right.
Old November 22nd, 2010, 06:33 PM   #8
2003 Mach 1
of course, i wouldnt be installing these my self or with friends. When i put my springs on one of my friends didnt torque my lugs after claiming he did. Luckily I caught the problem before anything serious happened. never again
Threads Similar to: 2003 Mach 1 susp. and brake questions
My Car vs a 2003 Mach 1 04GTNAustin 99-04 44 July 20th, 2010 11:28 PM
first 4v! 2003 mach 1!! 94pacecarSVT 4V / SVT 6 November 11th, 2009 11:22 AM
New stang susp. questions Chuck Strobeck 5.0 Mustangs 13 September 9th, 2008 11:18 PM
