2003 mustang mach 1
Mach 1 driveshaft
Is it worth is to upgrade to the ford racing aluminum driveshaft? Not sure how the stock one is one the 2003 mach 1 but was wondering if it was worth the money. Also want to upgrade to 4.10 gears, anyone have any before and after quarter mile times with their upgraded gears? Thanks in advance!!
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
you'll get mixed reviews on the d/s, that mod is up to you. as for the gearing, 4.10's are good all around gear. if i were in a 4v n/a car, i personally would do 4.30's.
It's in the details Mod!
01 Cobra Vert
Nov 09/10 ROTM!
No times unfortunately, but I can say it is a worthwhile mod. Brought my car to life.
As for the drive shaft, everyone has a different opinion on that. If I keep my car it will probably be one of my next mods. I want to find out for myself if it is worth it or not. I have been told that it will help smooth out the ride of the vehicle by cutting down vibrations, but not do really anything in the way of speed.
![]() Pinup in signature by loish.net Modded Mustangs Cobra Club#007 Military Crew E5 VOTED MM's BEST SIGNATURE 2010. THANKS STANGGTR07 |
MM's Orangest
2004 Mach 1 Mustang
Definitely do 4.30s. You won't feel the difference in the driveshaft like you will the gears. But weight loss is weight loss any way you look at it.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
2003 mustang mach 1
The only thing about going to 4.30's is this is my DD for the summers, so how bad will this hurt my gas mileage? And thanks for the advice on the driveshaft, i think i'll hold off on that for a while and spend that money on something different!
I have 4.10s and I wouldn't go 4.30s just because of where it will sit on the hwy however if you don't drive the interstate a lot like I do I bet 4.30s would be a blast.
MM's Orangest
2004 Mach 1 Mustang
My Mach is my DD year round. I wish I would have went 4.30s even before I got the T56 and I don't even race the thing. The T56's gearing is even worse so now I'm thinking 4.56s. MPG difference will be negligible if you could even tell a difference.
2003 mustang mach 1
Well to be honest, i really dont care that much about gas mileage because when i bought the car, i went from a v6 to this and its better on gas then the v6, so that doesnt really worry me. But, if i go with 4.30's i heard i would have to change them out if i ever supercharge it, which i am planning on doing eventually. Is this true, or can the 4.30's handle it? As far as highway driving goes, i drive the highway a total of like 7 hours every month, not very much at all.
MM's Orangest
2004 Mach 1 Mustang
You're probably going to have to change out the gears if you go with 4.10s if you supercharge it. And in the relative scheme of things gears aren't that expensive and the labor isn't either if you shop around, relatively speaking.
MM's Orangest
2004 Mach 1 Mustang
If you go with 4.10s you'll love them for about a month and then you're going to kick yourself in the balls for not going with 4.30s.
Threads Similar to: Mach 1 driveshaft
| Driveshaft...... | Ztaylor92 | V6 Mustangs | 8 | August 1st, 2010 04:21 PM |
| Driveshaft help! | Bushy | 5.0 Mustangs | 1 | December 16th, 2009 09:55 PM |
| Driveshaft | JASonic | V6 Mustangs | 11 | July 16th, 2007 01:15 PM |
| DriveShaft | sctravis77 | 99-04 | 1 | August 31st, 2006 02:36 PM |
