Engine slip under boost
Lately when I boost my 03 cobra, the engine slips considerably. Its almost the same effect as losing traction for a second (but ive got brand new eagle f1s on the back so I know that aint it)...any thoughts?
Safud: MM's Resident Hadji
Maybe the clutch?
2004 Cobra
7.4@97 Eaton
Yep, check your clutch adjuster which is on the driver side attached to the firewall. Turn it in.
![]() NEW NUMBERS: 609/543 Last edited by Jobra; November 26th, 2010 at 12:29 AM. |
2000 gt
ya sounds like clutch slip
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tqHARDCORE CREW BRIGHT ATLANTIC BLUE CREW #1 MEMBER |
How can it be clutch slip when the clutch is not engaged
2004 Cobra
7.4@97 Eaton
To me, the clutch is OPEN when your foot is down, and ENGAGED when your driving in gear. If your driving along and you punch it and the rpms spike but your not losing traction, that is a slipping clutch.
![]() NEW NUMBERS: 609/543 |
I cant even see down therr therrs so much shit in the enginene compartment, wgat does tge adjuster look like and where exactly is it
2004 Cobra
7.4@97 Eaton
Mine is aftermarket, but it looks like this:
![]() ![]() If your adjuster is all STOCK, look here: How To Adjust Clutch Cable - SVTPerformance
03 Cobra
Think he meant drivers side.
MM Cobra Club #86 2003 Mineral Grey Cobra 2004 True Blue F-150 FX4 |
03 Cobra
Usually when your clutch starts to slip its not an adjustment issue. Its more than likely a sign of wear or contamination and will have to be replaced.
2004 Cobra
7.4@97 Eaton
Doh lol oops
Yep usually. I remember trying to adjust mine and randomly one night i had bad slip and it came lose some how, I turned it way back in and it fixed my issue.
engine slip?? do you mean belt slip? im 99.9% its your clutch slipping.
#13 | |
03 Cobra
I think I know what belt slipping means..i said engine because im having trouble with my idle which im sure is due to my tps, my air filter needs to be recharged and the pulley shroud cracked away from its arm that bolts to the blower..meaning it could be one of several different things causing it..furthermore, im not having any problem at all with my clutch without boost..which leads me to believe the clutch isnt the problem..cause this wasnt a slow progression..it started happening out of nowhere..ill take it to a fucken mechanic you guys are usless
#15 | |
Second its not the boost. When you accel harder your clutch is put through more stress so it slips. Seriously its not fricken rocket science and i suggest you tone down the attitude if you want to maintain a membership around here. Do you know anything about cars at all? Difference between a oil dipstick and a transmission? That isn't a insult either, Just trying to give you the best advice. If you dont then i would probably take it to a dealer. Last edited by WhiteVenom; November 27th, 2010 at 05:45 PM. |
BWAL Is My Hero
2003 F150 S-Crew 5.4 FX4
Filter recharge probably means he has a K&N and he wants to get a recharge kit for it so he can ruin his MAF sensor....
Also, OP, just because your clutch is not slipping out of boost doesn't mean its not the clutch. The more load, the more likely it is to slip. Just like WhiteVenom said... Neggg'd. |
Also for your "idle issue" clean your IAC. (idle are control motor) Im pretty sure theres 2 8mm bolts to take it off, takes 5 mins.
Thats what it looks like. Take your time, Dont break the gasket, Use wd40, carb cleaner, silcon spray etc.
#18 | |
2003 Mustang GT
Repped
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
#19 | |
03 Cobra
MM Cobra Club #86 2003 Mineral Grey Cobra 2004 True Blue F-150 FX4 Last edited by 4valvegt; November 28th, 2010 at 04:13 PM. |
Threads Similar to: Engine slip under boost
| She let it slip. | Dansby | The Clubhouse | 16 | August 5th, 2009 12:25 AM |
| boost psi on stock engine | mustangjl | 99-04 | 35 | November 8th, 2008 07:58 AM |
| How much boost for stock engine | Lauri | 5.0 Mustangs | 19 | February 23rd, 2008 08:36 PM |
| Turbo Boost vs Super Boost | droppedbass87 | General Tech | 12 | October 16th, 2006 09:56 AM |
| Limited Slip | JRubin2000 | 99-04 | 6 | September 21st, 2006 04:59 PM |
