P&P TB and Plenum
Old November 24th, 2010, 01:58 PM   #1
Willy Mo's Avatar
Willy Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really nice
P&P TB and Plenum
Is there a write up on the proper way to P&P a cobra throttlebody and plenum? I have searched and come up with nothing.
Old November 24th, 2010, 02:07 PM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
well, you wont find anything on that since the cobra's dont have a plenum. the t/b, not sure if there is an actuall write up for that.
Old November 24th, 2010, 03:34 PM   #3
Willy Mo's Avatar
terminators do have a plenum, between the Tb and the blower. I know I could just take teh dremel to them but i would like to know if there are certian things to watch out for like the IAC port, the IAC mounting knobs, ect.
Old November 24th, 2010, 03:48 PM   #4
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
oh, for some reason i was thinking you were looking into the 99-01 cobra's only. i can do a write up, but it will probably be kind of vague unless i took more pics than i thought. are you welding it up or just porting whats there?
Old November 24th, 2010, 03:51 PM   #5
Willy Mo's Avatar
may do both. I have a small build underway (making a new sheetmetal intake plenum for my kenne bell) and am debating using the 03/04 plenum, or just make it all out of sheet metal and just use an 03/03 style TB. I am porting the TB for sure. I may just sell the plenums.
But a write up on both porting and welding up the plenum would be nice.
Old November 24th, 2010, 03:55 PM   #6
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
i tig my plenum's up, so thats what i have as far as finished pics are. if you have time and ability to tig, you can modify the stock plenum to get fairly close to accufab or dragon. the short side benefits from a little tig and work no matter if its stock or aftermarket. depending on how much boost you are going to push, then the stock t/b will be next choking point.
Old November 24th, 2010, 03:59 PM   #7
Willy Mo's Avatar
at teh moment Im peaking at 11lbs. but hoping the new plenum will free up a little bit. Im thinking I am just gonna delete the plenum and make it all sheet metal. Would make it easier and have less parts. BUt still want to port the TB.
Old November 24th, 2010, 04:01 PM   #8
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
i dont have any pics of a stock plenum, just pics of tig and finished product. as for the t/b, i only have finished pics of them as well.
Old November 24th, 2010, 04:24 PM   #9
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
tig'd plenum
this is about as far as you can go before you bust thru
and
Old November 24th, 2010, 04:38 PM   #10
Willy Mo's Avatar
Thanks for the pics. That helps. what kind of bits do you use? the last tike i ported a cylinder head my bits grenaded.
Old November 24th, 2010, 04:46 PM   #11
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
i have a decent amount of money wrapped up in my porting stuff. i have a small cabinet that houses my porting grinders (still go more grinders to buy), cartridge rolls, mandrels, carbide bits, head stand, etc. i do quiet a bit of porting, so i constantly buying something to make porting easier on myself.
Old November 25th, 2010, 03:02 PM   #12
Willy Mo's Avatar
Yeah I would like to do more porting, but I dot have all of the right tools.
Old November 25th, 2010, 08:42 PM   #13
cc250r is on a distinguished road
what did u tig weld? were there holes there or something?
Bassani o/r x, lm1, H&R JLT RAI, tinted head and tails, HID's
http://www.youtube.com/watch?v=nDlg5wLgGIg
03 f350-8" lift, moto metal 951's, toyo m/t 37/13.50/17, no cat borla,20% all aroud
MM cobra club #121
Old November 26th, 2010, 03:00 PM   #14
Willy Mo's Avatar
If you look through a stock plenum. You can see dips in the casting that partrude into the inside of the plenum. You fill the dips on the outside by tig welding them. Then you can remove the restriction from the inside.
Old November 26th, 2010, 03:06 PM   #15
2000 gt
Everett will become famous soon enoughEverett will become famous soon enough
i have read alot about gasket matching to remove material for more volume and better flow...i have started on my gt but have found i should buy stock in carbide grinding bits cause you can time the life of them on a stopwatch
Black and White Crew
Crew Member # 3
centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie
Old November 27th, 2010, 12:12 AM   #16
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
you must have either cheap bits or just hardened bits. i dont have many go dull very often, but i also spend a decent amount of money on mine.
Old November 27th, 2010, 03:54 PM   #17
Willy Mo's Avatar
sweet where do you buy your bits from?
Old November 28th, 2010, 12:08 AM   #18
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
fastenal if i need something quick, goodson, chs, and bout to buy some mondello bits soon.
Old November 28th, 2010, 12:38 AM   #19
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
nice porting Sweet.
Old November 28th, 2010, 12:40 AM   #20
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
thanks man. wait till you see some of the work i have rolling out for a certain someone
Threads Similar to: P&P TB and Plenum
C&L Plenum vs BBK 78mm throttle body/plenum rider4life350 99-04 29 October 25th, 2009 05:25 PM
P&P t/b and plenum? DeMello 99-04 73 June 30th, 2008 07:24 PM
