2003 Mach 1
Pilot or Throw out?
not really sure which bearing is going out. The other night i was messing around with a heavily modded gt on the highway and when i slammed into fourth the tires chirped not barked. Never have had that happen before but i was pretty stoked! Now i have this noise in the tranny and it changes pitch and the almost goes away when the clutch is all the way in. It sounds like sandpaper on metal. Also when i have driven around a bit and everything has had a chance to warm up it almost seems like the noise completely goes away. The two bearings will only cost about 80 bucks (ford racing) but if it's the pilot bearing the install price goes up another 75 bucks on top of the 275 to put in a throw out bearing. Just trying to save money anyway i can. Christmas is coming up you know. Thanks for any input guys!!
03 Cobra
![]() iTrader: 1 reviews
The pilot bearing will not make a noise when the clutch is engaged because the input shaft is turning at the same speed as the crankshaft and the bearing isnt turning. Actually very rarely at all does a pilot even make noise when its bad you usually feel a light vibration because the clutch disk is not centered on the flywheel. If the car is stopped in gear with the clutch pedal depressed and you can still hear the noise it is definetly your throw out bearing.
MM Cobra Club #86 2003 Mineral Grey Cobra 2004 True Blue F-150 FX4 |
4V swapped '02 GT
(2v) 13.9@101
![]() ![]() ![]() ![]() iTrader: 10 reviews
that sounds like a throwout bearing to me man. especially cuz you mentioned that the noise goes away with the clutch in.
![]() BSD 100MPH Club YMR #8975 4v Swap and a little Purple Bottle ![]() MM Nitrous Club #7 MM Cobra Club #87 |
2005 trd tacoma sport
def the throw out bearing
2003 Mach 1
well i mean i doesn't completely go away but i mean when i even put the slightest amount of pressure on the clutch the amount of sound and pitch changes. And why would the sound almost go away when everything is warmed up? also what can happen if i wait to long to fix it? I know nothing good, but i want to know when i have reached the failure point. And, sorry, i might as well do the pilot as well while they are in there; which defeats the whole thread cause both will be replaced. Non the less i kind of want to know which one it actually is so i know in the future
#6 | |
03 Cobra
2003 Mach 1
Threads Similar to: Pilot or Throw out?
| Throw Out/Pilot Bearings | zak2006 | 99-04 | 16 | July 2nd, 2010 02:27 PM |
| is this pilot bearing ok? | PolishSasquatch | 5.0 Mustangs | 1 | July 30th, 2009 11:31 PM |
| Anybody here a pilot? | fogged306 | The Clubhouse | 8 | November 28th, 2008 08:55 AM |
| Pilot vrs Co Pilot | WAR-PARTY | The Clubhouse | 2 | November 23rd, 2008 11:03 AM |
