2003 Mach 1
Poor Gas Mileage
I feel like my gas mileage has dropped significantly since i bought the car. I seafoamed it at the end of summer and i feel like im putting in 10 dollars a day. I need a oil change, but what else should i get looked at and changed while im doing this to improve mileage. Ive also got full exhaust intake and no tune.
97GT & 97Snake & 00L
T.B.A
clean your maf, clean your air filter and oil it up thats if its a knn, etc.
change your fuel filter, also if you have never changed your spark plugs, do it.
![]() 97 Cobra & 00 Lightning Beauty & The Beast I rev next to hybrids so they can hear me kill the environment ![]() MM Cobra Club Member #77 MM Lightning Club Founder |
No tune may be your issue too... Start with cleaning er up and go from there
Black and White Crew ![]() Crew Member # 3 centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie |
Noob Slayer
13.82 @ 101.09
what they said + check your tire pressure.
![]() 2003 Black Cobra 10th Anniversary 2.8 Kenne Bell Mammoth LC - Built SRA - T56 - E85 - Spray - Stock Longblock - True Forged Mach 5s 2004 Silver GT 5 speed - SOLD MM Cobra Club Member# 97 |
2003 Mach 1
all good ideas.....i would first try taking your right foot off the floor!! lol do not get the e3 plugs by the way my car ran light sh!t with them. and i went back to autolight +2s i believe and it fixed everything. with the e3's it felt as if the motor was backfiring and you could see it shake really badly via shaker. This was under a light load too. I would say do all those things listed also change your trans and diff while you are at it cause you bought it used and you don't know when it was done last and that can affect your gas mileage too. Also go to your local oil change place and ask them how they do a complete fuel injection service. Just have them show you. They will have this bottle with a tube coming out of it and it is attached to a flow control valve. make one and put half a bottle of seafoam in your tank and the other half in the bottle you made or bought. Connect the line to a vacuum line leading to the top of the intake manifold and what you need to do is run the seafoam as slow as possible through the intake manifold, so a clear inlet tube would be good to by so you can see your flow. run the bottle dry. when done raise the rpms to 2k and hold it for about 30 secs. if the car dies when you fist give it gas that's ok just restarted and be ready to give it gas to get it started. now that it's cold outside your are going to see alot more white smoke than you would in the summer. this is ok too. and it's going to smell too. after hold the gas at 2k for a bit, quick rev it to about 5k a couple of times to get the rest of the chemical out. it may smoke and smell for up to a week after that be it's ok. What you have done is clean all the carbon deposits in the upper intake, runners, back of your vavles, and helped clean more of you combustion chamber too. Do that about every 15k. NO E3'S
2000 GT 'vert
how many miles? Maybe o2 sensors?
1. keep your foot out of the gas
2. Keep your air pressure to at least what the recommended pressure is. 3. Alignment 4. low viscosity oil 5. OEM plugs or hotter 6. Air filter Seafoam is spectacular... but really doesn't do that much. Think about this: carbon buildup would increase your compression ratio, therefore increasing your efficiency. Most of that smoke comes from your cats anyway...not your engine.
1998 Gt full pi swap -Dead and gone 1998 Mark VIII 4.30s, 125 shot, 93 d/s-Daily Driver 1998 BAB Cobra-Project |
Because Racecar
2012 Mustang GT Premium
So for my Black 03 Mach 1 (Nice car BTW!) Should I use autolight +2 as well? Money isn't a factor.
2003 Mach 1
Because Racecar
Also, Majorownage. You DON'T want carbon deposits in your engine. No matter what. It creates hot spot and once you see a hole in a piston from excessive heat then you'll change your mind about keeping your engine clean.
We were talking about efficiency here. Of course carbon build up is unwanted.
2003 Mach 1
I bought the car with 33000 miles, it now just rolled over 50. I just had the O2 sensors changed. Bought some new plugs, fuel filter and MAF cleaner and im going to wash out my filter when im doin all of the above.
Hopefully it works, I havnt been driving aggressively but my fuel gauge fluctuates with how the car sits and it drives me fucking crazy.
#13 | |
2003 Mach 1
2003 Mach 1
you guessed it, i came from a grand marquis.
Threads Similar to: Poor Gas Mileage
| Poor Fuel Mileage | madmike223 | 99-04 | 11 | November 12th, 2010 03:23 PM |
| 99 Escort getting poor gas mileage | kay15ace | All Other Vehicles | 3 | August 25th, 2010 01:49 PM |
| piss poor gas mileage | akatagyourit | 2.3 Mustangs | 71 | August 16th, 2007 11:37 AM |
