2004 Mustang SVT Cobra
resevior under shifter?
A while back I replaced the stock shifter with an MGW(awesome shifter by the way). My question is, the resevior that the shifter gets bolted into looked almost as if it had very little fluid in it. When I replaced the shifter on my GT it was almost full. Common sense tells me that I need to put fluid in that resevior but cannot find anywhere on how much fluid or if that is even where it gets filled or what type of fluid goes there. My guess would be ATF but am not sure. My shifter doesnt want to go into gear very easily( especially reverse) So I'm kinda hurtin for an answer.
The only stupid question is the one not asked(in most cases) |
i use amsoil synchromesh...amsoil makes the best fluids bar none....and your tranny holds 3.7 quarts....i run it half a quart low because i was getting a crunch from 2nd to 3rd...i read on here to try running itr low and it worked
Black and White Crew ![]() Crew Member # 3 centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie |
so its filled through the plug under the tranny? I'll run it a little low as well but theres like nothin in there.
ya but there is a lil plug higher up...remove it and stick your finger in...if you can feel fluid your good
cool beans. thnx much
Priest of the Car Gods
What you're looking at is your tranny fluid. There's not a separate reservoir for the shifter.
If you're having difficulty shifting, check the fluid level, or maybe replace it with something different. I know T45s love GM synchromesh, but I'm not sure if T56s are the same. Either way, there's two plugs on the side of the transmission, one high and one low. The low one is the drain, the high one is the fill. Fluid should be up to the bottom of the fill hole (idea is you pump it in until it flows out). It's usually a lot easier to fill the tranny from the shifter hole than it is to fill it via the fill plug.
nice!! Thnx guys!! Very big help!!
Threads Similar to: resevior under shifter?
| Shifter Boot for MGW Shifter ? ? ? | liche | 5.0 Mustangs | 0 | August 4th, 2010 08:32 AM |
| Best Short Throw Shifter, especially for bringing the shifter further back? | jonwrong | 99-04 | 25 | March 9th, 2010 03:03 AM |
| Shifter moves when going over bumps with the rear (stock shifter poly bushings) | Avengence | 2005 - 2010 | 5 | September 3rd, 2009 10:42 PM |
| Hurst shifter rattle on new shifter | Odin | 2005 - 2010 | 8 | January 11th, 2009 12:18 AM |
| Shifter? | jamesbwhite | 2005 - 2010 | 26 | February 17th, 2008 10:43 PM |
