Where to look?
Old December 13th, 2010, 10:29 AM   #1
03blackmach1's Avatar
2003 mustang mach 1
03blackmach1 is on a distinguished road
Where to look?
I'm looking for a set of Cams for my 03 mach 1 and i was wondering from others experiences where they got them from and what's a good price for everything?
Old December 14th, 2010, 06:17 PM   #2
rst1523's Avatar
2003 Mach 1
rst1523 is on a distinguished road
i was looking on americanmuscle.com and i think they were like 3k with springs and retainers. That was for stage 2 CompCams XE-R cams
Old December 14th, 2010, 08:45 PM   #3
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Are you getting a blower in the future? Can you do the work yourself?
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old December 14th, 2010, 09:10 PM   #4
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
what kind of cams are you looking for?
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Old December 15th, 2010, 03:36 PM   #5
2003 mustang mach 1
My plans right now are to stay N/A. As for doing the work, i would take it to a shop around town since i dont have the proper tools or time to do a job like this.
Old December 15th, 2010, 08:30 PM   #6
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
A lot of guys like running the Comp Cams 106400. They are a stage 2 cam grind so they are still streetable if that's what you are looking for.
Look to spend $1200 for cams alone. Then you'll have to add springs, retainers, and labor in with that. It'll be in the neighborhood of $3000 for everything. Usually cams are the last thing you want to do though to finish up your build. So if you have bigger plans than just cams I'd do those first.
Old December 15th, 2010, 09:04 PM   #7
2003 gt
5.4 32v on the way
or you could be cheap and pick up 96-98 cobra intake cams for under 200 easily and gain 15-20hp.
Old December 16th, 2010, 01:04 PM   #8
rst1523's Avatar
2003 Mach 1
explain. and why not both cams?
Old December 16th, 2010, 01:28 PM   #9
2003 gt
5.4 32v on the way
96-98 cobra cams have more duration on the intake, exhaust cams are pretty much the same.
Old December 16th, 2010, 01:49 PM   #10
rst1523's Avatar
2003 Mach 1
im assuming just put them in and tune? Are you sure they will work on a mach
Old December 16th, 2010, 01:57 PM   #11
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
They are a direct swap. The only thing is, is it really worth it to you to drop in $100 cams, that give maybe 10hp, when you will be paying over $1000 probably closer to $1500 for the labor? That's why I asked if you could do it or not. If you can do the work yourself then yeah 96-98 Cobra intake cams are a good/cheap alternative. If you can't it's best just to save your money and get the best bang for your buck otherwise it will be a huge waste of money IMO.
Old December 16th, 2010, 02:04 PM   #12
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
15-20 with a ported intake. You'll be in the 325-340 range with Cobra cams and a ported intake vs 355-370 with aftermarket cams and that number will be higher on that range or into the 370s with a ported intake.
Old December 16th, 2010, 05:31 PM   #13
2003 gt
5.4 32v on the way
Or you can go over to svtperformance.com and get some used gt500 cams for 200-300 bucks. I believe those have more lift as well as a little more duration.
Old December 16th, 2010, 09:42 PM   #14
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Don't those cams have the same profiles as the Ford GT? If that's the case it's still not worth the labor cost for what little you gain IMO.
Old December 17th, 2010, 02:00 AM   #15
2003 gt
5.4 32v on the way
Yeah I guess if you pay to have cams done you might as well go for larger gains. What are typical gains from a decent set of cams for a 4v?
Old December 17th, 2010, 01:48 PM   #16
2003 mustang mach 1
So basically i should save up 3000 for both parts and labour and buy the better cam? Its not worth it in my books to spend 1500 for like 10-15 ponies...
Old December 17th, 2010, 05:08 PM   #17
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
I was at 300rwhp even when I had my motor rebuilt. I had to buy new cams because mine were busted, but I didn't have the money to go with a great aftermarket cam. I added LTs, ported intake and the FR500 cam kit and picked up 60hp and roughly 25tq. If I would have had the money to get a great cam as opposed to the rather mild FR500 I would have picked up another 10-15. So roughly I gained somewhere in the neighborhood of 30-40hp on just the cams.
Yep. Now you know why people just go blower on these cars. Once you get that 3,000 saved up your pretty close to having a blower paid for and you'll make more power.
Old December 17th, 2010, 05:14 PM   #18
2003 mustang mach 1
Yeah cams hardly seem worth it when you look at it that way...blower sounds like the better bang for your buck deal
