i want to build a new 4v motor and dont know what to get
Old December 16th, 2010, 11:29 PM   #1
cc250r is on a distinguished road
my 4v motor threw a rod 2 years ago and the motor was fixed but it still has oil just dissapearing sometimes so im thinking over the next year or so ill save up my $ and buy a new block,cams,maybe heads if i need them,pistons etc
i need help picking what to get i wAnt to buy a kenne bell one day so if i was building a motor i want all forged parts what block would be the strongest, what pistons,rods and crankshaft to go with id like to make the motor a 5.0 also. do i need new heads or can i use my stock 4v 01 cobra heads. and last i would like to buy comp stage 2 cams.
so i just need you guys to tell me what i should/should not get thanks.
Bassani o/r x, lm1, H&R JLT RAI, tinted head and tails, HID's
http://www.youtube.com/watch?v=nDlg5wLgGIg
03 f350-8" lift, moto metal 951's, toyo m/t 37/13.50/17, no cat borla,20% all aroud
MM cobra club #121
Old December 17th, 2010, 04:26 AM   #2
majorownage is on a distinguished road
teksid block or the 05-09 aluminum 4.6
JE pistons
oliver rods
heads are optional 03/04 cobra and 03/04/05 aviator heads are optimal
1998 Gt full pi swap -Dead and gone
1998 Mark VIII 4.30s, 125 shot, 93 d/s-Daily Driver
1998 BAB Cobra-Project
Old December 17th, 2010, 06:53 AM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
just reuse your stock block, yout stock forged crank, and have your heads worked on.
for rods and pistons, get brand of your your preference, and do a set of cams that are made more for boost. comp cams are decent, but not really made fo a PD blower. for a 5.0, you will have to resleeve your block, buy big bore block, or stroke it.
Old December 17th, 2010, 08:35 AM   #4
or buy my shortblock for 3000...
5.1 stroker all forged
brand new, still on the crate. Was 3500 when I purchased it XD
Rated at 1000+ horses
Old December 17th, 2010, 10:10 AM   #5
boduke0220 is on a distinguished road
Stock crank
Modmax rods
CP pistons
see if you have a teskid, if so, use that.
Old December 17th, 2010, 05:30 PM   #6
i dont know if i should use the stock crank because
1. i dont know if the 99-01 cobras had forged cranks
2.i dont know if i trust the crank i have now my brother threw a rod with this crank(unless the dealership changed the crank which i dont think they did)
MM cobra club #121
Old December 17th, 2010, 06:31 PM   #7
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
Look into the boss 5.0 big bore block and work off of that. it will get you 5.0L of displacement and is a pretty strong block. If you go that way you just need the larger 3.7inch pistons and then you can use stock sized rods and crank.
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Old December 17th, 2010, 09:51 PM   #8
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Are you wanting to build a motor cheap?
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old December 18th, 2010, 03:18 AM   #9
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
if the crank isnt cracked or broke, its fine. no matter if its cast or forged. this is where magnaflux is handy, that will tell the tale of its worth. all 96-04 cobras recieved forged cranks as well.
Threads Similar to: i want to build a new 4v motor and dont know what to get
Motor Build Q oldironfixer94 5.0 Mustangs 9 December 12th, 2010 11:17 PM
motor build 99blkcobra 4V / SVT 1 November 10th, 2008 07:28 PM
2v motor build wtbastang 96-98 10 February 4th, 2008 03:03 PM
motor build quickstang281 96-98 0 November 7th, 2007 07:34 PM
Motor Build up GT 849 General Tech 7 December 18th, 2006 11:46 PM
