Burp valve Help!!!
Hi i recentley bought a cobra and the guy who owned it before put water in all the cooling parts and so i need to drain it and i need to know what tool removes the burp valve becasue its too tight for a socket
MM's Orangest
2004 Mach 1 Mustang
Vise grips if you can't get it to open with a socket. Just tap it loose don't try to muscle it open.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
i already tried the socket and it snaped so i was thinking about trying to heat it up to make it expand and then it should be easier to come off but i dont know what to heat it with and how would vise grips do it?
Threads Similar to: Burp valve Help!!!
| 2-Valve to 3-Valve swap | Krich677 | 99-04 | 3 | March 25th, 2010 11:14 AM |
| bypass valve and blow off valve difference | xXJayManZXx17 | 99-04 | 32 | March 6th, 2010 11:30 PM |
| Will 2 valve headers bolt up on 4 valve? | 4valvegt | 99-04 | 19 | October 9th, 2009 12:32 AM |
| The Gurgle Burp | Fluffy The Rhino | The Clubhouse | 7 | April 7th, 2009 11:36 PM |
| Egr Valve And Pcv Valve Delete? | Jeffery9508 | V6 Mustangs | 16 | January 28th, 2008 09:45 PM |
