Coils for rear suspension
Old December 23rd, 2010, 05:39 PM   #1
1999cobra92's Avatar
1999 mustang cobra
1999cobra92 will become famous soon enough
alright so sometime next month im going to buy coil overs for my IRS. Also i dont care about ride quality all i want is near supercar. Here is my question what do you guys think i should get as for the coils and shocks. I was thinking 575lb coils with cobra R rear shocks from maximum motor sports
Black and White Crew
Crew Member # 5
Check garage for mods and pics
if you Los Angeles and want to ride send me a text (323) 270-6827
0% Wheel hop, 0% broken parts, 100% wheel spin
Old December 23rd, 2010, 06:46 PM   #2
1999 mustang cobra
anyone
Crew Member # 5
Old December 23rd, 2010, 10:15 PM   #3
1999 mustang cobra
Any body with a coil over suspension that takes there car to the track???
Crew Member # 5
Old December 24th, 2010, 02:07 AM   #4
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
that would be a good starting point. depending on how much you track it (strait/twisty's) will be deciding point of spring rate. if you want to get a little more over steer, you will want to go up a little more.
Old December 24th, 2010, 12:37 PM   #5
1999 mustang cobra
What would be the ideal spring rate for a track\weekend car
Crew Member # 5
Old December 24th, 2010, 05:16 PM   #6
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
strait line? or curve's? if striat ine, the 575 is fine.
Old December 24th, 2010, 07:40 PM   #7
1999 mustang cobra
alittle bit of both straight and curves. but im more focused on curves
Crew Member # 5
Old December 24th, 2010, 11:15 PM   #8
WhiteVenom's Avatar
99 Cobra :p
12.36@119.35
WhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really niceWhiteVenom is just really nice
Send a message via AIM to WhiteVenom
Screw the IRS! Mine is on the floor in my garage for sale. SRA FTW! (unless your into autox i guess..)
MM COBRA CLUB #80
SRA SWAP WRITE UP!
Old December 26th, 2010, 08:39 PM   #9
1999 mustang cobra
alright im going to be going with 625lb springs with cobraR shocks and maximum motor sports coil over kit
any suggestions
Crew Member # 5
Old December 27th, 2010, 04:55 AM   #10
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
with going for curves as well, a little stiffer spring will be better.
Old January 1st, 2011, 09:46 AM   #11
mustangman57 is on a distinguished road
be careful using too stiff of a spring/shock you can actually break the eyelit off of the lower control arm. here is a thread that i was directed to with VERY useful info
http://www.svtperformance.com/forums...-red-pill.html
96 mystic Cobra, 96 block, .20 over CP forged flat tops (9.5:1 comp), Manly Rods, 03 Cobra crank, Comp Stg2 Blower Cams, Ported B-heads, Spec Fly Wheel, Spec Stage 3 clutch (soon to be a stage 4 ), T-trim @15 Psi, Front Mount, 537 with belt slip
Threads Similar to: Coils for rear suspension
rear end and suspension papemilio V6 Mustangs 12 June 24th, 2010 03:08 PM
rear suspension ? brianm 2005 - 2010 9 May 15th, 2010 01:43 AM
rear suspension bigtom 4V / SVT 16 September 3rd, 2009 06:48 PM
Good rear shocks if I'm doing kmember/coils in front? SDYC00GT 99-04 16 March 18th, 2009 09:16 PM
a few ?s about rear suspension GoodOleBoyzRacin 5.0 Mustangs 4 August 3rd, 2008 03:06 PM
