which cams for a 5.4 navi build?
Old December 27th, 2010, 02:54 PM   #1
scp616's Avatar
scp616 is on a distinguished road
sold one of my cobra motors, and finally got my 5.4 navi motor taken apart and cleaned at the machine shop. The cam journals on the heads are a little rough, but salvageable, and now that christmas is past I plan on ordering everything to get the 5.4 built and put in my car. I decided to run around 9.5 compression so i can spray it later, but I still need to figure out which cams to use. I have a set of mach 1 cams (out of an aviator) and then the ones that came out of the navigator. Ive heard that they're similar. Another option Ive been looking at was the high lift cam kit from ford Ford Racing M-6550-T46 Ford Racing 4.6L DOHC 4V Camshaft Kit
has anyone used this kit? it's got a ton of duration, but idk about the lift
02 GT --> long tube headers w/ x pipe and flow masters, throttle body w/ intake plenum, cold air intake, short throw, 255 nitto 555's all around, 373 diff gears, 2 inch lowering kit w/caster camber plates, sony radio working with stock system
Old December 27th, 2010, 02:56 PM   #2
slow02gt's Avatar
2002 mustang gt
11.38@119
slow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the rough
Send a message via AIM to slow02gt
if your going to spray it go with a lil higher compression...and if you want cams in it go with some custom cams
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
Old December 27th, 2010, 02:56 PM   #3
scp616's Avatar
oops, 12mm lift... so .47 inches. Still not sure if the followers are a different ratio though
Old December 27th, 2010, 03:02 PM   #4
scp616's Avatar
I also wanted to have the option of running a centrifugal supercharger. I've heard of people running 9.8, but my engine dyno software didn't seem to make a huge difference past 9.5 and i'd rather play it safe. If i go the centrifugal route i'll probably use methanol injection as well
Old December 27th, 2010, 03:47 PM   #5
slow02gt's Avatar
2002 mustang gt
11.38@119
go with some comp or crower cams
Old December 27th, 2010, 04:03 PM   #6
scp616's Avatar
i've been looking at comp and lunati, i'll check on crowers.
Anyone know the lift on stock navigator cams?
Old December 28th, 2010, 09:24 PM   #7
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
I believe the navi cams are the same as the mach/marauder/aviator/cobra. Those cams are way too small for a 5.4 build. I am going with crower stage 3 blower cams, but if you aren't going to rev real high and whatnot something with similar specs to the crower stage 2 blower cam will probably work pretty well for you. The fr500 kit you link to isnt a bad kit for NA, but is less than ideal for a supercharger. If I were you id ditch the navi heads and go for some 04/05 c heads so you have better intake options. What intake are you going with?
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Old December 29th, 2010, 08:22 AM   #8
slow02gt's Avatar
2002 mustang gt
11.38@119
i have some stage 2 ported 03/04 cobra heads i will cut you a deal on was ported by foxlake
Old December 29th, 2010, 11:51 AM   #9
scp616's Avatar
Thanks man, but I already have a set of tumbeport heads I was working on porting. What sucks is that I spent like 5 hours porting the 4.6 intake =P
Thanks DickH, I'll look into crower cams, so far I was going to go with lunati. Do those blower cams require valve springs? Also, hows the street performance (idle, drive ability, gas mileage)? This car is my daily driver other than my bike, so i need something practical.
As far as intakes go, I'm probably going to cut the flanges with the injector boss's off the stock navigator intake and use 2" aluminum tubing to form short runners. Then just a box for the upper and probably the dual blade throttle body of the navi.
Hate to go to all the trouble, but it doesn't look like i have many options =P
Old December 29th, 2010, 12:02 PM   #10
scp616's Avatar
found the specs for the stage 2 blower cams on crower's site... they look about what I was wanting as far as duration and lift, but they do recommend valve springs. Did you buy valve springs from them as well? or have your factory ones held up?
Old December 29th, 2010, 12:20 PM   #11
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Most stage 2 cams from any dealer require upgrades. The stage 1s use stock components.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old December 29th, 2010, 02:29 PM   #12
2003 gt
5.4 32v on the way
You are going to need springs with any decent cam, I am lucky and got my hands on a fr500 cam kit for cheap and then sold the cams so I have the springs and valves from that. Also a navi lower intake is far from ideal, you will lose a chunk of low and mid range, and you probably wont rev it high enough for the short runners to give you any top end. You would probably be better off just getting adapter plates and using a cobra/mach intake.
Old December 29th, 2010, 02:45 PM   #13
scp616's Avatar
Ats That's what I figured, I'll look around and see who has a good deal on springs.
I don't plan on using the lower manifold, just the flanges off it (as opposed to adapter plates) I'll use them for the base and build a sheet metal intake from that
Old January 1st, 2011, 09:37 AM   #14
mustangman57 is on a distinguished road
crower stage 3 blower cams. at-least that is what im saving up for.
96 mystic Cobra, 96 block, .20 over CP forged flat tops (9.5:1 comp), Manly Rods, 03 Cobra crank, Comp Stg2 Blower Cams, Ported B-heads, Spec Fly Wheel, Spec Stage 3 clutch (soon to be a stage 4 ), T-trim @15 Psi, Front Mount, 537 with belt slip
Old January 2nd, 2011, 11:34 AM   #15
scp616's Avatar
idk if i want to go stage 3 with it being my daily driver and poly motor mounts... it already shakes the car a bit at idle lol
So another question... what do ya'll do about tuning? I was thinking sniper and then i read the ONLY review on their site that said it advanced his timing too much and blew his engine... but it could just be some dumbass that didn't know what he was doing
Old January 2nd, 2011, 12:05 PM   #16
only one tuner in my book. Tony Ganyon at Tuners Inc. in Orange Park Fl. 1-904-276-7223 it is a little bit of a ride for you nut more than worth it.
Old January 3rd, 2011, 05:13 PM   #17
scp616's Avatar
I was looking more at tuning software to do it yourself, but I haven't decided on anything yet. been looking at sniper and sct
Old January 3rd, 2011, 06:14 PM   #18
2003 gt
5.4 32v on the way
I haven't had any experience with either, but from what little I have read it seems like if you are going to do it yourself the sniper is the better option. I plan on tuning mine with a sniper when its all ready for it so ill have to wait and find out how easy it is to work with.
Old January 3rd, 2011, 07:41 PM   #19
scp616's Avatar
yeah sniper seems pretty decent, i just wish I knew someone that had used it before. If i decide on sniper, i'll post a thread on what i think about it
Threads Similar to: which cams for a 5.4 navi build?
what heads are on a 5.4 4v navi... BakerFX4 99-04 19 November 2nd, 2010 01:44 AM
Ordering Cams for Build Steeda187 99-04 27 October 4th, 2010 02:22 PM
more questions about the navi motor? 93HatchsBFF 5.0 Mustangs 1 April 15th, 2009 08:37 PM
4v/5.4L (Navi) Potential? tomzac Modular Mustangs 9 November 30th, 2007 11:29 AM
