Help replacing my front pads
My 03 cobras brake pads are down to nothing..i have new pada but when I tried to renove those caliper bolts I couldnt even begin to budge them, its hard to leverage them from this position but I was wondering if I even needed to do it that way..is there a way to take the pads out without removing the whole assembly? Am I missing something I mean do thr caliper bolts go in counterclockwise or something?
1999 mustang cobra
![]() iTrader: 1 reviews
the bolts have a C-clip you pull out from the opposite side than after removing the clip you pull the bolt straight out also putting some pressure on the caliper so the bolt will slide out easilly then you lift up the part were the bolt was at and the caliper should slide out
Black and White Crew Crew Member # 5 Check garage for mods and pics if you Los Angeles and want to ride send me a text (323) 270-6827 0% Wheel hop, 0% broken parts, 100% wheel spin |
1999 mustang cobra
also get some good brake pads
Thats what I needes thanks! I figured that little knob and rod on the one end of the caliper was made for this..i have duralast gold, theyre semi metallic pads from autozone I couldnt find motorcraft in stock
Threads Similar to: Help replacing my front pads
| Front Rotors & Pads | 07 Boss | 2005 - 2010 | 17 | June 12th, 2010 12:29 PM |
| Changing Front Pads | TyCouey2000GT | 99-04 | 2 | October 15th, 2008 05:48 PM |
| i need new brake pads in the front | XPLICITSTANG | 99-04 | 4 | October 10th, 2008 07:30 PM |
| Replacing the Brake Pads | stangstrip | 99-04 | 2 | July 15th, 2008 06:47 PM |
| Replacing rear brake pads | OcOnnor220 | 99-04 | 3 | June 16th, 2007 02:25 PM |
