Squeaky '03 Termi
Old December 30th, 2010, 01:58 AM   #1
Venomus's Avatar
2003 Cobra
www.slow.com
Venomus is on a distinguished road
Squeaky '03 Termi
So my Cobra started squeaking like a son of a gun about a week ago. Really high pitched squeak about 30 seconds after I fire it up then goes away when the engine is fully warmed up. It's really loud and embarassing. Could this be my problem Metco Double Bearing Idler Pulleys
Do I need double bearing pulleys due to the extra boost?
My best college buddy - "I think God made me then he thought to himself, 'Let's make another guy with the same personality but tall, not fat, and with better dick giving abilities' and he made you"
Old December 30th, 2010, 10:28 AM   #2
03 Mach 1 03 SVT Cobra
76 Cobra 2
76Cobra2 is on a distinguished road
On my Eaton it is usually the blower pulley bearings squeaking take it off and re-grease the pulley bearings and the noise should go away. I'm running 16 lbs of boost and it needs redone every year just about.
Old December 30th, 2010, 07:35 PM   #3
Jobra's Avatar
2004 Cobra
7.4@97 Eaton
Jobra has a spectacular aura aboutJobra has a spectacular aura about
Check the idlers and the quality of the belt.
NEW NUMBERS: 609/543
Old December 31st, 2010, 12:34 AM   #4
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
weems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud of
idlers.
Old December 31st, 2010, 02:06 AM   #5
Venomus's Avatar
2003 Cobra
www.slow.com
I will try this. I'm running the same boost on the ported Eaton. Thank you!
Any other ideas out there?
Old December 31st, 2010, 02:09 AM   #6
Venomus's Avatar
2003 Cobra
www.slow.com
Both are new... ?????
Ill try greasing the bearings
Old December 31st, 2010, 03:28 AM   #7
Jobra's Avatar
2004 Cobra
7.4@97 Eaton
If your pullied and your idlers are stock then just replace the idlers anyways because its basically a necessity when your spinning the blower faster all the time.
Old December 31st, 2010, 09:44 AM   #8
99 GT Vert 35th Limited
RideTheSquirrel is on a distinguished road
I had the same problem and believe it or not it turned out to just be the belt. And my belt looked new. Ever since I replaced it everything went back to sounding fantastic.
Old January 1st, 2011, 09:29 AM   #9
mustangman57 is on a distinguished road
most likely the belt (they take a serious beating under boost) but i have seen a lot of 4.6 2v cars at work (im a lead technician at tires plus in ocala fl.) come in with belt squeel/chirp and it turns out to be the harmonic balancer separating, the rubber dries out and causes the pully to separate from the hub
96 mystic Cobra, 96 block, .20 over CP forged flat tops (9.5:1 comp), Manly Rods, 03 Cobra crank, Comp Stg2 Blower Cams, Ported B-heads, Spec Fly Wheel, Spec Stage 3 clutch (soon to be a stage 4 ), T-trim @15 Psi, Front Mount, 537 with belt slip
Old January 1st, 2011, 09:30 AM   #10
i know there is a big difference between a 2v car and a terminator but it is a good thing to check
Old January 2nd, 2011, 12:38 PM   #11
Venomus's Avatar
2003 Cobra
www.slow.com
Ill take it into a Terminator shop and get a diagnosis. I will mention the bearings, idlers, belt, and harmonic balancer. But will mention the idlers and belt are new.
Thanks to all. If there are any other suggestions please let me know.
And does anyone know if this issue is robbing me of any power?
Threads Similar to: Squeaky '03 Termi
Squeaky Front End Paulnhbtx 99-04 26 March 4th, 2009 10:00 PM
ocean city and we got a termi down, we got a termi down. 07stanggt 2005 - 2010 16 October 14th, 2008 05:04 PM
termi vert VS termi coupe mikeGTmurr46 4V / SVT 35 February 8th, 2008 10:57 PM
Squeaky... whtpny 99-04 14 November 12th, 2007 12:27 AM
Squeaky crazyjones V6 Mustangs 1 November 3rd, 2007 12:35 AM
