3.8 to 4.6 DOHC swap (making sure I have everything)
LinkBack (1) Thread Tools
Old January 2nd, 2011, 08:16 PM   1 links from elsewhere to this Post. Click to view. #1
2004 mustang
tommyboy2008 is an unknown quantity at this point
Exclamation
Anyone that has done a 3.8 to 4.6 DOHC, I'd like to go over what I have ready to go in and make sure Im not going to need anything else before I start...
First off the car is a 2004 base model mustang with the 3.8 auto...
The motor im swaping in is a fully dressed 1999 Cobra with a T-45 on the k-member ready to install
I have-
ALL wires from a 1999 cobra. (nose to tail)
1999 cobra speedometer
1999 cobra ecu
clutch pedal assembly
hydroboost system
driveshaft from a GT that had the T-45
mishimoto alluminum radiator
8.8 rear w/ 4:30 gears
Sniper tuner to turn off PATS and get a tune
I have some extras like bbk long tubes, bbk catted h-pipe, flowmasters, line lock, steeda short throw shifter, spec alluminum flywheel w/ Luk pro gold clutch kit, bbk clutch cable and quadrant, some cooling mods ect..
It appears I can use the stock fuel pump. I checked the part number and its the same and the emissions appear to me like I can just run my vac lines from the engine into the emissions that is already on my car. That about it. I just want to see if anyone that has done this ran into any suprises. Thanks for any input.
Old January 2nd, 2011, 08:26 PM   #2
2004 mustang
oh, one other question...the abs? my abs says v6 and the cobra says "cobra". Do I need the "cobra" abs umm, thinga ma jig the abs control doodad or can I use my v6 abs control box?
Old January 3rd, 2011, 12:02 AM   #3
zippeewannabee
ZoomZoomMFer's Avatar
06' Mazda Speed6
ZoomZoomMFer has a spectacular aura aboutZoomZoomMFer has a spectacular aura aboutZoomZoomMFer has a spectacular aura about
iTrader: 17 reviews
Send a message via AIM to ZoomZoomMFer
the abs should be fine as far as i know. And from the looks of it, you should have everything you need.
Cobb SRI | Eibach ProKit | JBR Short Shift Plate | JBR Rear Motor Mount
Old January 3rd, 2011, 12:18 AM   #4
fastpony's Avatar
1998 ford mustang gtclone
fastpony is on a distinguished road
Send a message via AIM to fastpony
I would swap fuel pumps if i were you. you dont wanna run the chance of going lean.
Old January 3rd, 2011, 01:48 AM   #5
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
southfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of light
Send a message via AIM to southfour! Send a message via MSN to southfour!
Im pretty sure 99 cobra/v6/gt's all use the same fuel pump
H/C/I V6
BMC Member: 12521
Old January 3rd, 2011, 01:55 AM   #6
fastpony's Avatar
ok, just checking....
Old January 3rd, 2011, 01:58 AM   #7
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
im about 90% sure, i think i remember reading that somewhere
H/C/I V6
BMC Member: 12521
Old January 3rd, 2011, 08:05 PM   #8
2004 mustang
hey thanks guys, i guess im ready to get started
heres a link to my facebook photos if anyone cares to follow along with the build. I didnt start the tear down yet. hopefully this weekend
My Cobra project | Facebook
Old January 4th, 2011, 01:02 PM   #9
scp616's Avatar
scp616 is on a distinguished road
sounds like you got everything you need. Let me know what you think of the sniper tuning, I'll probably be using that for my engine swap as well
02 GT --> long tube headers w/ x pipe and flow masters, throttle body w/ intake plenum, cold air intake, short throw, 255 nitto 555's all around, 373 diff gears, 2 inch lowering kit w/caster camber plates, sony radio working with stock system
Old January 4th, 2011, 07:05 PM   #10
rst1523's Avatar
2003 Mach 1
rst1523 is on a distinguished road
can a 210hp v6 use the same fuel pump as a 320hp cobra? Not so sure about that, but i havent put any research into it. Just doesn't seem right. IMO
Old January 4th, 2011, 07:33 PM   #11
Moderator
89StangGT's Avatar
SVT Cobra Mustang
89StangGT has a spectacular aura about89StangGT has a spectacular aura about
Send a message via AIM to 89StangGT
I thought the same thing..weird.
There's a reason Ford codenamed them the Terminator
Old January 4th, 2011, 07:36 PM   #12
Moderator
89StangGT's Avatar
SVT Cobra Mustang
PS..
Please don't add ANY of this bullshit to the exterior of your car. They look so much better with a stock body, lowered, with a nice set of wheels.
"this is what the outside will look like after im done..minus the chic"
Old January 4th, 2011, 08:24 PM   #13
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
Speed Concepts - CBRAPMP9801 - OEM fuel pump for 1998-2001 Cobra/2001 bullitt/2003-2004 Mach1
Motorcraft part # PFS200
Pump module is also OEM on these applications:
FORD F-250 SUPER DUTY PICKUP (1999 - 2004)
FORD F-350 SUPER DUTY PICKUP (1999 - 2004)
FORD F-450 SUPER DUTY PICKUP (1999 - 2004)
FORD F-550 SUPER DUTY PICKUP (1999 - 2004)
FORD MUSTANG (2001 - 2004)
FORD MUSTANG BULLITT 2001
FORD MUSTANG COBRA (1998 - 2001)
FORD MUSTANG GT (1998 - 2004)
FORD MUSTANG MACH 1 (2003 - 2004)
according to this the 99-00 v6 pump must be a bit different, but if this is OEM on the 01-04 v6 than the op's stock pump should still be fine as there is only a 3 hp difference between the 99-00 and 01-04 v6 motors.
H/C/I V6
BMC Member: 12521
Old January 4th, 2011, 08:46 PM   #14
2004 mustang
yeah I checked what the fuel pressure is supposed to be for the 99 cobra and its the same as my v6. plus the part number is the same for the pump and even the fuel pump driver module is the same. So I should be good to go. I have a fuel pressure guage to put on the fuel line just to make sure im getting the correct pressure.
89StangGT-...I did like the look of the black mustang above but I dont care for the rear window scoops. The ONLY thing im doing to the exterior is putting on a 03-04 cobra rear bumper cover and a cobra-R front cover. I've been considering getting the rear window louvers but im still not sure. I like my stock hood which my car has the gt hood (came on the 40th anniv. edition) I've also changed my mind about the side exhaust as well. I also have lowering springs for it. I think the are 1 1/2"
Thanks for all the replies..
Old January 4th, 2011, 09:04 PM   #15
2004 mustang
I definetly wouldnt be doing this swap if I had not come across the CRAZY deals I been finding...some people just dont know what they have. For example...the 99 cobra engine-$1k w/ 22k miles on it from a trusted guy I know, T-45 $250 w/ 28k miles on it (another trusted friend), all but new bbk long tubes $75 bucs!(MPS) ALL the wires- $400(ebay). A PERFECT CONDITION 03-04 cobra rear bumper cover $150! very nice leather seats-$250 (same guy I got the engine from). Hyrdroboost-$75. Everything else I bought new so I didnt save too much on the other stuff.
It all adds up but like I keep telling people that ask why,- I cant get back the money I spent on my v6 so I might as well put some cash in my car instead of selling it for maybe 3500 and loosing 4k. so I take another 4k and build a cobra I can say "I" built..So you can say I spent about....12k TOTAL for what is going to be a bad ass car that I know inside and out.
.Just some food for thought
Oh, next year depending on the funds...motor rebuild with forged internals and yes the good ol' S/C
Old January 4th, 2011, 09:11 PM   #16
2004 mustang
How do you guys have a pic on your profile?? I just have "NEWBIE"
Old January 4th, 2011, 09:47 PM   #17
brett22's Avatar
2004 Mustang V6
heart of a 4V
brett22 will become famous soon enough
I am also doing the swap but in a month after I finish building my turbo 4V, I'd say your list of parts is decent. There are some other parts I think you are missing but can't think of them off the top of my head
Turboed 4.6 4V build in progress
Milwaukee School of Engineering
Class of 2015, BA in Mechanical Engineering
2004 Terminator 100% Stock 5000 Miles
Red 2004 V6 (swapping in a turboed 4.6)
Old January 4th, 2011, 09:53 PM   #18
Moderator
89StangGT's Avatar
SVT Cobra Mustang
If that's your V6 car in your sig, you have the best looking sixxer I've ever seen, props.
Coming from a V6 to a N/A 32v will be plenty fun for a while, especially if you do some gears with it as well. The S/C swap down the road will be even funner.
Glad to hear that! I'm not a huge fan of the Cobra R front cover, but it's better than some I've seen!
Old January 4th, 2011, 10:54 PM   #19
brett22's Avatar
2004 Mustang V6
heart of a 4V
Yep thats the V6 and THANKS. Actually love this car more than the termi I have lol
Old January 4th, 2011, 11:04 PM   #20
1999cobra92's Avatar
1999 mustang cobra
1999cobra92 will become famous soon enough
i would also swap out the brakes... you know just in case you dont have enough stopping power
Black and White Crew
Crew Member # 5
Check garage for mods and pics
if you Los Angeles and want to ride send me a text (323) 270-6827
0% Wheel hop, 0% broken parts, 100% wheel spin
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/198112-3-8-4-6-dohc-swap-making-sure-i-have-everything.html
Thread 3.8 to 4.6 DOHC swap (making sure I have everything) | Forums at Modded Mustangs | BoardReader This thread Refback August 12th, 2011 09:19 AM
Threads Similar to: 3.8 to 4.6 DOHC swap (making sure I have everything)
3.8L to 4.6L DOHC swap? DarkAbsolution88 V6 Mustangs 27 October 19th, 2010 03:39 PM
Q's on possible 5.4 dohc swap Black18Ice 99-04 17 June 1st, 2010 06:43 AM
DOHC swap questions busaonboost 96-98 25 December 24th, 2009 10:09 PM
5.4 Dohc Swap Into 97 Mustang Smoking mustang Modular Mustangs 4 April 6th, 2009 11:17 PM
dohc swap? BoostHard1210 99-04 6 December 3rd, 2008 08:18 PM
