1999 SVT Cobra Saleen
Possible causes for zero compression on one side
I don't think the engine is blown. The mufflers were collapsed due to scraping from the former owner. I think it plugged the engine. It had new cats installed and ran for a short time. Then there were a couple loud pops and it quit running. They took the mufflers off and it runs, really erratic, but runs. It is a 4.6 DOHC. No smoke or steam from the exhaust.
2003 Mach 1
You might have four dead hamsters on one side.....hit up petsmart
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
rob had that happen on his mach and it was a broken secondary timing chain.
1997 Mustang GT
You ran a compression check on all 4 cylinders on the bank and they came up zero? I would assumne if the timing chain failed you may have possible have valve damage on all 4 of those cylinders due to the pistons hitting into the valves.
97 GT, 4v swap,procharged,longtubes,tubular front suspension, team z rear suspension,4.10s moser 31s, to much to list.
would the timing chain fall into the oil pan or pieces of it if it broke? id say pull the oil pan.. but on these cars gotta pull the K member or the engine...or..... lift the engine high enough up to slide it off.. thats whatd id do tho
mm's nitrous mod
2000 mustang gt
depending on how it breaks, it might or might not fall. but the timing tensioner will more than likely come apart and parts from it will fall into pan. its a lot easier to drop the k, than it is to lift and tryto get to pan.
agreed with sweet.. drop the k and pull the pan bro and see what u find.. might even be able to drain the oil and some might come out with it
I know nothing about these modular motors. The mechanics that looked at it felt that the valves were probably damaged, and pieces most likely did fall into the cylinders, causing damage. They are saying that it would be easier and safer to replace the motor, about $4k for the motor, and $1k for the labor. Thanks for the responses. Good info.
mm's nitrous mod
2000 mustang gt
4 G's? damn, thats expensive. you can get a hell of a built engine for that. as for the valves, more than likely they are all hurt if the timing chain broke. at the same time the guides will need replaced as well. the valves will leave little dimples on the pistons, but shouldnt hurt the pistons at all.
#10 | |
1997 Mustang GT
Just guessing. That's what made me start looking around, checking into the forum scene. I figured the car owners themselves would know best. I thought $4k for an engine was pricey, but that seems to be the average. They are running more than that on eBay for used engines. This is crazy. I just want to get the car on the road.
mm's nitrous mod
2000 mustang gt
no way man. that price better include installation and warranty.
A Shop in Sacramento wanted $2k for labor alone to r & r the engine, plus $4,500 for the engine, plus any belts, hoses, fluids. If anybody out there knows of better prices, it would be appreciated.
mm's nitrous mod
2000 mustang gt
i dont charge that, but you are quiet a distance as well.
man yall's shops are ripping yall a new one.. thats a hell of a price for a simple pull and replace of an engine.. id say o it yourself.. half the ppl on here could walk u thru it if u have the tools
I decided to do this alone. Screw the mechanics. I am having a tough time getting the valve cover off on the drivers side. Any suggestions is appreciated. I did notice that the inside chain under the cover is broken. Is that a bitch to replace? Is it doable without tearing the engine down?
i have a 97 cobra engine and when it was in my sn95 i had to remove the upper intake and disconnect the clutch cable from the tranny and pull it up to give more room for the valve cover to come up...
but as for the chain.. theyre pretty simple to replace... but...... its ever good when a chain breaks.. usually when that happens valves start bending and what not.. i'd do one of 2 things.. 1. pull he head that the chain broke on and check out valves.. 2. replace chain and do a cylinder leak down test too see if there is any loss is compression thru the valves.. |
#18 | |
4v Know-it-all
To answer your question, the chains can be replaced without tearing down the engine. |
#19 | |
MM's Orangest
2004 Mach 1 Mustang
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
Threads Similar to: Possible causes for zero compression on one side
| stright pipe on one side and keep the flowmaster on the other side? | Garrett | 96-98 | 24 | May 24th, 2010 10:51 PM |
| WTB Side Scoop Insert 2000 mustang Drivers side | bushden | V6 Mustangs | 1 | February 28th, 2009 07:45 AM |
| the mach 1 & the v6 side by side...check it out! | supermachone | The Clubhouse | 38 | August 17th, 2008 09:45 PM |
| Holy Crap One side of axle is centered, one side is not | OTreborO | 5.0 Mustangs | 6 | June 6th, 2007 12:04 PM |
