does anyone know what this code means? help please..
LinkBack (1) Thread Tools
Old January 11th, 2011, 06:49 PM   1 links from elsewhere to this Post. Click to view. #1
Mroman27's Avatar
1997 Mustang Cobra
Mroman27 is on a distinguished road
Send a message via AIM to Mroman27
My check engine light turned on, checked for the code. and it was
P0411-Secondary Air Injection System Flow Improper
thanks for the help
Old January 11th, 2011, 07:43 PM   #2
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
Description: The secondary air injection system does not detect the presence of air in the exhaust when introduced by the secondary air injection system
What to check:
Electric AIR Pump
Hose from AIR pump leak
AIR bypass solenoid leak/blocked
Hose from AIR pump blocked
AIR bypass solenoid stuck open/closed
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old January 13th, 2011, 08:38 PM   #3
Mroman27's Avatar
1997 Mustang Cobra
thanks..
Is there a way to delete the air pump?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/199448-does-anyone-know-what-code-means-help-please.html
Thread P1151 and P1152 code..anyone had them? | Forums at Modded Mustangs | BoardReader This thread Refback December 28th, 2011 09:15 AM
Threads Similar to: does anyone know what this code means? help please..
RedfireGT This Means YOU!!! TheUNZippee! 2005 - 2010 8 January 13th, 2008 12:29 PM
WilltheThrill, This Means You! :D TheUNZippee! The Clubhouse 11 December 10th, 2007 05:16 PM
NamelessLiar!! This means You!! TheUNZippee! 2005 - 2010 34 July 29th, 2007 11:31 PM
in english this means ? terribleonexx88 Videos 10 January 3rd, 2007 02:38 PM
