Underground
2001 SVT Cobra
5.0 Stroker Question
Hello, I have the Eagle 4.9 flat top stroker kit for my 01 Cobra (teksid block). Upon tearing the motor down i found out the previous builder (done by previous owner) slightly over-bored the cylinders and my new builder says ill have to either keep it the same and deal with the little chatter its doing (compression checks fine) or re-sleeve it because as is, the sleeves supposedly wont hold to the boost and nitrous which I'm applying to it. My question is, I believe it would be easier/cheaper to find a replacement teksid block and just have it bored 20 over (to the right specs) and apply the stroker kit to it. do you all have any opinions on this or should i go with another block for this application. Ive read/heard of the teksid blocks holding up to a supposedly 1200hp. Looking forward to the responses
What size overbore are the pistons that you bought? 0.020"? What is your current bore size?
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
2003 gt
5.4 32v on the way
Yeah your best bet is to find a new block, you should be able to find one for a couple 100 bucks.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
these blocks will go +.030 if you were to change pistons
get a new block.. they go for dirt cheap on corral and what not
Underground
2001 SVT Cobra
The stroke is 3.750". At +.020" bore, with a rod length of 5.950". The compression is 10.8. If it would be safe to do so i could bore it .030 and just order the pistons and rings to match a .030 bore. Im stuck with the ever lasting decision of doing a high comp boost build or low comp with dished pistons.
mm's nitrous mod
2000 mustang gt
compression will only get into the 10's with off the shelf piston. you can boost a decent amount on pump gas. put some race gas in it, and boost as much as you desire.
Threads Similar to: 5.0 Stroker Question
| 347 stroker question | 95Pony | 5.0 Mustangs | 18 | November 7th, 2010 06:51 PM |
| stroker question | rxnodoze02 | 2005 - 2010 | 2 | February 7th, 2009 04:52 PM |
| Stroker Kit Question... | Traidmarx | 5.0 Mustangs | 12 | January 25th, 2009 09:20 AM |
| 4.6 Stroker Question | StuTheMusicEngineer | 99-04 | 29 | December 14th, 2007 04:22 PM |
| To Stroker or Not to Stroker? That is the Question! | 87StangLX | General Tech | 13 | October 20th, 2007 10:46 AM |
