What belt size? (2.76, 2lb lower, BF snub/idlers)
Hey guys... I have looked on BF's site, and my combo doesn't have a size listed, and I can't seem to make much sense of the chart on Metco's site... So. What size belt (round-about) should I be running with my setup?
I am currently running a Gates K080745 with a BF 2.76" upper, 4 piece BF idler set with snub idler, and a 2lb Metco lower will be going on next. Any insight into what I need to run would be much appreciated. I looked under the hood today and the tensioner is a bit off of the center mark, to the right, towards the raised side. I'm not sure if I should check that when the car is running or not. It has sat since last night when I checked it today. Thank you for the help. |
zippeewannabee
i got ya man, cobra bob on svtp has a pretty good belt guide.
with BF's new snub idler he says gates K080785, old style is K080780
![]() Cobb SRI | Eibach ProKit | JBR Short Shift Plate | JBR Rear Motor Mount |
Oh snap, thanks man! I have the new style. Looks like I'll be orderin' that up tomorrow.
![]() Rep'd! Never thought of Cobra Bob's site.. |
zippeewannabee
no problem brosephine
Bought the belt. Went with a Gatorback since that's what was readily available, and from what I've read on SVTP, both Gates and Gatorback are equally good belts.
Will be putting the lower on this weekend. Should be fun.... :/ |
Ok so it looks like the guide is just a little off, at least in my case.
With the Billetflow 4 piece idler set (snub idler with new design bracket), 2lb Metco lower and a BF 2.76" upper, a K080780 fits PERFECTLY. The K080785 was just a bit too long when looking at the tensioner marks. Now with the 78.0 belt, the idler is RIGHT in the middle where it should be. Which is odd since I have the new style bracket... Anywho. Just a heads up.
Threads Similar to: What belt size? (2.76, 2lb lower, BF snub/idlers)
| What belt size would you need | JerseyTrueBlue | 99-04 | 8 | August 24th, 2010 07:01 PM |
| belt size ? | tutman900 | 5.0 Mustangs | 20 | January 7th, 2010 11:25 PM |
| ? what size belt | onefast89stang | 5.0 Mustangs | 2 | December 16th, 2009 12:07 PM |
| need belt size for a 2-80 upper and 2lb lower w/upr idler | 03snakeminated | 4V / SVT | 4 | October 1st, 2008 07:36 PM |
| belt size | silvergtstang99 | 99-04 | 2 | March 19th, 2008 07:56 PM |
