IRS Build Install
LinkBack (3) Thread Tools
Old January 21st, 2011, 04:09 PM   3 links from elsewhere to this Post. Click to view. #1
jk_aktion's Avatar
jk_aktion will become famous soon enough
IRS Build Install
This is my build for an IRS (Independent Rear Suspension) in late 2009. My vehicle set-up is used for Road Racing/Open Track. Other mods to my car I'll post if interested.
Upgraded/Replaced Parts:
MM Delrin Upper Control Arm Bushings
MM Delrin Lower Control Arm Bushings
MM Urethane Differential Bushings
MM Urethane Subframe Bushings
MM Adjustable Rear Swaybar Endlinks
MM Low Profile IRS Subframe Bolts
MM IRS Crossmember
Motive 3.73 Ring/Pinion
Motive Bearing Kit
Detroit Locker (Eaton Truetrac) 31 Spline
Ford 31 Spline Half Shafts
Ford Aluminum Carrier
Steeda IRS Brace
MM Cross-Axis Joints (no pics/installed months after)
MM Solid Differential Bushings (no pics/installed months after)
MM Adjustable Tie-rods (no pics/installed months after)
I used the MM Specialty Tools for all the bushing removal and some persuasion from the hammer. Pictures start with the showing of the original frame and its bushings then to disassembly, upgraded build, to install. The original Drivetrain components were shattered in pieces so I only used the original frame and Control Arms.
Old January 21st, 2011, 04:10 PM   #2
jk_aktion's Avatar
Continued
Old January 21st, 2011, 05:25 PM   #3
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Thumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the roughThumbie is a jewel in the rough
Dude that is SICK! It's seeing pics like these that make me wish the previous owner didn't do the SRA swap and instead just upgraded the IRS. I'm jealous my friend. Was the install into the car hard or was it pretty basic/bolted right in. Also, did you need a different length driveshaft? Or is that one stock length (I'm wondering because if someday I got back to IRS if I will need a new driveshaft.)
Congrats
2001 Cobra with SRA swap, modded for twisties
MM Cobra Club Member #76
Old January 21st, 2011, 05:41 PM   #4
jk_aktion's Avatar
The install was very easy, jacked it up right into place. The driveshaft is the Ford Racing Aluminum 3.5" and yes it is the factory length. The hardest part was the removal of the oem rubber bushings and sleeves from the IRS frame and control arms.
Old January 21st, 2011, 05:43 PM   #5
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
that car looks Very Very loud lol
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old January 21st, 2011, 05:59 PM   #6
Thumbie's Avatar
2001 Cobra
14.2@102 (I suck)
Awesome, thanks a ton! Enjoy the ride
Old January 21st, 2011, 10:37 PM   #7
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
Looks awesome. Good to see someone else actually appreciates the IRS. IRS>SRA.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old January 22nd, 2011, 01:25 AM   #8
jk_aktion's Avatar
Thanks
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/200716-irs-build-install.html
Irs swap - Page 3 - SVTPerformance This thread Refback February 12th, 2012 07:05 PM
IRS vs SRA for the corner carver/street car...help me pick - Page 3 - SVTPerformance This thread Pingback January 22nd, 2011 11:51 PM
Irs swap - Page 3 - SVTPerformance This thread Pingback January 21st, 2011 07:14 PM
Threads Similar to: IRS Build Install
Another fox 4v build mtw002 4V / SVT 10 October 27th, 2010 02:28 PM
351w build and install kreil45 94-95 1 May 25th, 2009 12:50 PM
to build or not to build 07 STROKER 2005 - 2010 12 September 10th, 2008 06:50 PM
Build It Or Buy It mrgt 99-04 13 December 19th, 2007 05:35 AM
