Need help... fast!
Old January 23rd, 2011, 03:02 PM   #1
Because Racecar
Calogero6685's Avatar
2012 Mustang GT Premium
Calogero6685 will become famous soon enough
Need help... fast!
Just put on new brake pads in the rear. I used the kit from advance auto to compress and rotate the caliper's piston to help install the new pads (Wagner Thermo quiet ceramic). I just went to drive and its like these things are constantly engaged. I couldn't even go into reverse without giving it some decent amount or rpms without it wanting to bog down...
Old January 23rd, 2011, 04:50 PM   #2
gdl
99 Cobra, 03 Mach1, 07 CS
gdl has a spectacular aura aboutgdl has a spectacular aura about
I have two thoughts:
1. When you screwed the caliper pistons in, did you turn them all the way in until they wouldn't go any further? Did you have any problem getting the calipers with pads loaded to slide over the rotors? If the answers are yes an no then...
2. Take a look at the emergency brake cables where they connect to the calipers. I'd bet you have one or both of the cables kinked or the connection has slipped so that the e-brake is staying partially applied.
2007 Redfire California Special
http://i183.photobucket.com/albums/x...n/2007GTCS.jpg
2003 Dark Shadow Grey Mach 1
http://i183.photobucket.com/albums/x...born/Mach1.jpg
1999 Black Cobra Vert
Old January 23rd, 2011, 09:05 PM   #3
Because Racecar
The width of the pads were .664 and I got the Weavever semi metallic and they were .570. Anyways, long story short, they were the right product according to Wagner, but they're too big. Even on worn rotors.
Old January 24th, 2011, 02:37 PM   #4
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
Right. GTs and Cobras share the same calipers and what not. but what main difference is the thickness of the pad. Cobras use a thicker rotor to help with heat, and hence, being the calipers are the same...you need thinner pads...
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20
01 Bullitt-32v swapped
96 GT-Cammed E85
www.KPERacing.com
Old January 24th, 2011, 04:01 PM   #5
Because Racecar
I have a Mach 1, but advance auto AND Wagner's website said that the pads I bought were correct, but who knows...
Old January 24th, 2011, 04:50 PM   #6
97mustanggt's Avatar
97GT & 97Snake & 00L
T.B.A
97mustanggt will become famous soon enough
ok heres ur problem i had same problem, there are two slider pins on each caliper u need to grease those up so the can slide freely one is probly all rusty and seized so it aint letting the caliiper open and close
97 Cobra & 00 Lightning
Beauty & The Beast
I rev next to hybrids so they can hear me kill the environment
MM Cobra Club Member #77
MM Lightning Club Founder
Old January 24th, 2011, 07:59 PM   #7
Because Racecar
Trust me, we (Master Technician neighbor and I) tightened and loosened the hell out of those bastereds, I don't see how those pads would work anyways, because the clearance between both of them put together was more than .15" difference between the Wagner and the Wearever. They just didn't fit. Is a .664" pad supposed to fit my factory rear brakes? My cheapy Haynes manual said .71 Cobra and .55 all other models.
Threads Similar to: Need help... fast!
The fast and the furious: Fast 5 NorCalWhtHrse The Clubhouse 50 October 8th, 2010 01:07 PM
how fast is fast to you? 2006greyGT 2005 - 2010 186 May 8th, 2009 12:43 AM
how fast can we go? Steve O 99-04 8 October 3rd, 2007 07:52 AM
Need Help fast please mikerm125 96-98 5 August 12th, 2007 07:10 PM
