E85 and big bore build
Old January 27th, 2011, 06:50 PM   #1
mach1soldier's Avatar
mach1soldier is on a distinguished road
Hey guys, need some thoughts on my build that I am getting parts together for. This is for an automatic mach1 that I don't want to shift past 7000 RPM. It will be run on e85.
Iron big bore block
Lightweight diamond or je pistons (flat top)
manley connecting rods
stock cast crank
Deck the block down to zero deck
Stock 03 mach1 heads or 9 thread heads
My questions are: What cams should I go with? I don't want to lose all my midrange torque but would like good power between 3000-7000 rpm max.
How high should I go on the compression since I'm running e85 12.5-1? or higher? I'm thinking 13-1 would be totally possible.
Ported short runner intake or stock ported intake?
This car is a 90 percent track car but I am not using a transbrake and I do drive it on the street occasionaly.
2003 mach 1 12.7x @103 4600 stall, 4:30, slicks & skinnies, ALUM DS, VMP tune.
1996 ford thunderbird (13.02 @104) pi block, all the bolt ons minus cams, 3.73, 3800 stall.
Old January 27th, 2011, 07:31 PM   #2
4v Know-it-all
na svt is on a distinguished road
Zero deck, .036" head gasket, flat top w/4cc valve relief, and a 46cc combustion chamber (.030" off the head) will result in a 11.8:1 CR, .060" off the head will give you 12.6:1
-8" short runner because stock runner length kills power at 6300
-no more than 230 deg intake duration, off the shelf cams won't work well because the LSAs are too wide, need custom grinds
-pistons need valve reliefs to allow for the most optimum intake lobe center
Could easily see 425rwhp/380rwtq. Stock runner length will increase torque but power will fall off after 6300, a short runner will peak a couple hundred RPM higher and power will not fall off more than 20rwhp by 7k and tq will be lower.
Old January 27th, 2011, 11:50 PM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
the 4.6's are almost 0 deck as it is, no need to really worry aboyt decking the block. you can take some off the heads, just make sure you have a way to adjust the cams in. depending how much you want to take off the heads, you may need to have the ports matched back up from intake to heads. if you wanting to go to the 7k mack, you will need a modified intake like stated above. another option is to look into an aviator intake, or aftermarket.
Old January 28th, 2011, 08:28 AM   #4
4v Know-it-all
You can cut the deck/heads a combined .030" without causing any alignment issues, any more and the the front cover will have to be cut and the heads/intake aligned.
Cloyes multiple keyway cam gears will put the cams where they need to be. They should be used to degree the cams anyway.
Avaitor intakes are terrible unless highly modified and the Sullivan is only good for 281ci engine seeing rpms over 7500 and larger cube engines. like a 324, going over 7k.
Old January 31st, 2011, 09:53 PM   #5
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
a modified aviator is fine, and not too terribly hard to modify. with him already having a 4v, i too suggest just having the stocker modified for the needs. as for the deciking, i didnt know what the intended outlook was for how much was going to be taken off.
Old February 1st, 2011, 07:08 AM   #6
4v Know-it-all
The aviator intake requires a lot of welding/modding on the upper in order to adapt a 4v throttle body, and the runners just flat suck. I've done two avitator lowers, they did work great but took many hours to complete, i can make an 8" c head intake in fewer hours for less money and make more power.
You can cut the heads .060" if you know how to get everything back into alignment.
Old February 1st, 2011, 12:36 PM   #7
My goal is to be close to 13-1 compression. I didn't think about the alignment issue though.
What are your thoughts on having the pistons above deck .010-015? I heard that it promotes better flame travel and a couple other things but I don't really understand that part too well.
Old February 1st, 2011, 01:15 PM   #8
4v Know-it-all
Having a negative deck clearance doesn't promote flame travel in itself. What does though is gaining compression through means other than domed piston.
Here is what it would take to get 13:1 with flat tops:
Piston to deck..........-0.011
Gasket thichness........0.038
Valve notches / Dish...4.000
Volume of head.........42.000
Compression ratio......13.000
This will require the front cover to be machined and the heads/intake to be machined so that their ports align.
Old June 18th, 2011, 02:03 PM   #9
Bumping this for a question since I am about ready to start buying parts. What all needs to be machined on the heads/intake so that the ports align? Is it widening the holes on the intake since the intake bolt spacing is being pushed further apart?
Threads Similar to: E85 and big bore build
Built Motor Blown Starting Big Bore Build 05mustang_TT_charged 2005 - 2010 161 March 29th, 2012 05:48 PM
bore seans mustang 5.0 Mustangs 5 November 5th, 2009 09:55 AM
bore?? Boostang 99-04 14 August 10th, 2009 06:34 PM
4.6 big bore? product1620 96-98 7 August 31st, 2008 12:39 AM
Short stroker, large bore/ Long Stroke, small bore 331STANG 5.0 Mustangs 20 July 23rd, 2008 05:28 PM
