#21 | |
![]() the older castings had bad water flow through them newer 03's and all 04's are good to go. a valveguide wouldn't fall off unless it cracked into pieces. i would double check the crank and rods to make sure they are not bent/out of spec; just in case he is right about something dropping into the combustion chamber.
1998 Gt full pi swap -Dead and gone 1998 Mark VIII 4.30s, 125 shot, 93 d/s-Daily Driver 1998 BAB Cobra-Project |
#22 | |
03 Cobra
![]() iTrader: 1 reviews
MM Cobra Club #86 2003 Mineral Grey Cobra 2004 True Blue F-150 FX4 |
#23 |
Hi guys - is there a thread somewhere that shows how you could do an engine swap on a 01 Cobra and bolt in a 03/04 setup? Not looking at anything too modified just yet, but thinking of buying/swapping a setup. Any pointers would be greatly appreciated.
Thanks |
#24 |
MM's king of Neon's
404 - car not found
17.81@87
That seems like an awful lot of effort for very little change, but who am I to judge?
Check out the eaton swap thread. They swap an eaton setup onto an 01 Cobra, but you can use it for information you'll need. If you do use a 03/04 liftout, all you'll have to sweat is hooking up the intercooler arrangement, maybe some power steering lines. You could conceivably keep the same transmission and fuel system so there would be no issues there. There may be a few kinks in the way of splicing your harness for the COP's, alternator, IAT sensor if you keep your harness. If not it's all plug and play.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
#25 |
MM's king of Neon's
404 - car not found
17.81@87
Hate to bring up an old thread-
But here's the update. Since that one in Georgia I haven't been able to locate a single one, despite prowling multiple forums, classifieds, and having a dealer scouting multiple auctions. What I have seen is a number of WTB: wrecked Cobra threads, where guys just part them out. They end up buying a dozen of them throughout the thread. It angers me terribly. All I need is one, and I've got the cash... But enough of my angry rant. Bottom line is that if this crap keeps up, I'm going to be forced to go another route. For less than it'd be for the 03/04 Cobra motor with that damned accessory drive, I could go with a forged 4.6/5.4 DOHC, and just run a turbo already. No longer a terminator clone, not the same low end torque, but I guess I'll have to settle for the power for less. Oh well. ...or just say to hell with it all and instead of the brand new diesel Ram, get a new Mustang GT. Either way, these wrecks are elusive.
#26 |
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
or go LSx
#27 |
MM's king of Neon's
404 - car not found
17.81@87
Not quite as easy as a 4.6 or 5.4 modular motor but...
...find me a decent price on a forged one and I will. ![]() ...provided my car doesn't burst into flame from trying to put its archrival powerplant in it.
#28 |
Because Racecar
2012 Mustang GT Premium
Don't... or else the right hand of Lord Ford shall strike you down.
#29 | |
MM's king of Neon's
404 - car not found
17.81@87
![]() I shall not anger the gods. Instead here's what I'm going with if I continue to have no damn luck with the wreck/Eaton swap. Plan B: on3 76mm turbo kit. Should be good for 550hp easy, and comparitively cheap. I know a guy who was running a 97 Cobra with a similar setup who was pushing out 780rwhp. Plan C(omplete and total f*cking overkill): Switching to 5.4L DOHC forged, custom fabricate a twin 65mm turbo setup. It'll give me a chance to hone those TIG skills, and put down absolutely obscene numbers. I'm sure the Lord Ford would approve of this. For both I'll have to check and see if I can get a company discount on Holset turbochargers. I think a Holset VGT would be phenomenal.
#30 |
1999 Mustang Cobra
What is the weight differance with the teksid block and the terminator block?
Threads Similar to: Engine Swap Thoughts?
| 2005 V6 engine swap to 2002 saleen engine | MCLARK | V6 Mustangs | 7 | May 14th, 2010 06:02 PM |
| engine swap ideas. thoughts? | graygoose | 96-98 | 1 | April 29th, 2010 11:08 PM |
| 2005 V6 engine swap to 2002 saleen engine help? | MCLARK | 2005 - 2010 | 7 | January 11th, 2010 09:27 AM |
| thoughts on a 5.4 swap | SWEET2KSTANG | 99-04 | 27 | April 6th, 2008 10:29 AM |
| 98 v-6 swap for 5.0L Sleeper...any thoughts? | MIKE_DIEZEL | 5.0 Mustangs | 5 | December 6th, 2006 04:52 PM |
