![]() iTrader: 2 reviews
DOHC Head/Intake / Tech
DOHC Cylinder Head 96-04:
B/Swirl Port: (93-98 Lincoln Mark VIII, pre 99 Lincoln Continental, 96-98 Cobra). The first and only production Ford head with two (square primary, round secondary) intake ports per cylinder, these swirl port castings arrived first in the ’93 Lincoln Mark VIII. Aptly named, due to the way they promoted the incoming air to swirl into the combustion chambers, much like water running down the drain of a once full sink. Through the years these heads have proven themselves to be excellent high rpm (8000rpm+) performers—mainly in power adder applications--since their tremendous combined intake port cross sectional area and volume (when combined, a full 55cc more than any other 4.6L head design) provide for exceptional power production in the upper regions of the tach. Ironically, it’s those same big, beautiful, twin ports that also prove to be the B head’s largest inherent design flaw. The extra intake port size has a tendency to kill low/mid rpm intake port velocity and power production—hence the use of Ford’s first IMRC (intake manifold runner control) intake on the 96-98 Cobra. By allowing air to reach only one of a B head’s twin intake valves, velocity, and therefore low/mid range torque production was restored in situations under 3250rpm. Later head designs are clearly superior in this regard, which happens to be the one of the most important considerations for those wanting a stout street motor. There is also some controversy over the single fuel injector/dual intake port setup. Some claim insufficient air/fuel mixing because of the compromised design, however, others contest that the ability to make 1000+rwhp with only minor porting and some form of power adder is testament to the contrary. Whoever you believe, there is little doubt that even after as little as 8,000 miles, carbon and other deposits tend to form on the secondary ports, causing a major airflow impedance, as there is no fuel present to clean them. B heads feature a somewhat small stock exhaust port that really hinders flow in power adder applications. Major gains from porting come with a quality valve job, some pocket and lots of exhaust work. There really isn’t a lot of material to remove from the intake ports themselves. The Bottom Line: B heads aren’t the best choice for a naturally aspirated street motor. In order to really shine, they need to be paired with a power adder and a short block that can sustain high horsepower and rpm levels. These, the oldest heads, may still be a great choice for full race applications. Stock Intake Choices: ‘93-‘98 Lincoln Mark VIII, ‘96-‘98 Cobra. Aftermarket/Modified Stock Intake Choices: HCI, SSR, PHP. B head dimensions: Combustion Chamber: 52cc, Intake Port Vol.: 107cc primary (square), 115cc secondary (round). Intake Port Entrance: 1.500x1.300” primary (square), 1.660x1.400” secondary (round), Valves: 37mm Int., 30mm Exh. C/Tumble Port: (99/01 Cobra, 99 Lincoln Continental). These second-generation Ford DOHC heads feature a single intake port per cylinder with a smaller cross sectional area that boosts incoming airflow velocity compared to previous years. To understand how C heads earn their “tumble port” designation, try to imagine an Olympic high diver doing repetitive front somersaults before cleanly entering a pool at the bottom. This controlled tumble allows for better air/fuel mixing than in the earlier swirl port heads. The new port design allowed for both substantial increases in midrange torque, and superior horsepower production under 8000rpm when compared with earlier heads. Combustion chamber size is also up 2cc. The design downfall of C heads, and their larger (5.4L Navigator) cousins, is the relatively flat floor and utter lack of a short turn radius in the throat of the intake port. As such, the incoming air tends to overshoot the valves, making the port think the valves are smaller than they actually are. Some ‘99/’01 Cobra owners reported a “ticking/pinging” noise coming from the drivers side head of their cars. This is due to insufficient cooling around the #6, 7, and 8 cylinders that allowed the valves to overheat and therefore seat improperly. Ford remedied the situation by issuing a TSB to remove and replace the affected heads with a version that featured altered coolant flow. C heads feature a small exhaust port much like Ford’s earlier swirl port heads, but unlike in B heads, both the intake (throat region) and exhaust ports can see extensive porting work. However, removing too much material from the intake port (mouth region) of a tumble port head will kill velocity very quickly, so make sure your head porter knows what they are doing! The Bottom Line: C heads remain a viable performance upgrade for those looking for more punch in their street driven 4.6L four valve, without having to pay new part prices for the ’03 DOHC or FR500 versions. The increased midrange torque production and greater overall area under the power curve (when compared to swirl port heads) will enhance the performance of a street/strip driven (8,000rpm and under) modular regardless of application. Stock Intake Choices: ‘99/’01 Cobra, ‘03/’04 Mach 1 & Aviator, ’03 Marauder, FR500. Aftermarket /Modified Stock Intake Choices: Al Papitto short runner/ported ‘99/’01 Cobra, MP carb/Sullivan intake, FR500, Aviator C head dimensions: Combustion Chamber: 54cc, Intake Port Vol.: 177cc, Intake Port Entrance: 1.960”x1.350”, Valves: 37mm Int., 30mm Exh. Navigator: (98+ Lincoln Navigator) These 5.4L DOHC heads feature essentially the same intake port design as C heads, however they have a much larger intake port volume than 4.6L castings. Despite the fact these heads feature a relatively small exhaust port, the extra intake port volume could be very beneficial in helping fill a motor of greater displacement—think 5.4L. Expect slightly better midrange torque, and sub 8000rpm horsepower production than even C heads, however the larger intake port size leaves a slim selection of intakes to choose from when utilized on a 4.6L block. Forced induction fans take note, Navigator exhaust ports feature a thicker exhaust divider (while keeping the same overall exhaust port size as B,C, and FR500 heads) that allows coolant to circulate through this vital area. Conversely however, the larger divider can also hurt flow by utilizing additional space in the port. The real downside to Navigator heads, when used on a 4.6L based motor, is the severe limitation they impose on intake selection. The physically larger 5.4L heads don’t leave a lot of room (when installed on a 4.6L block) between them for an intake plenum to sit—though they do bolt right up. Remember that since Navigator intake ports are essentially clones of those of C heads (just on a larger scale), they too suffer from the same intake port flaws that plague the earlier tumble port design--no short turn or floor in the throat of the intake port. The Bottom Line: The extra port volume the Navi’s possess could be very beneficial in filling a motor with greater than 281 cubic inches of displacement, or in high rpm N/A street/strip or boosted combinations. Fans of boost should remember the cooled exhaust port divider. Lack of intake availability is the real downfall of this otherwise wonderful casting. Stock Intake Choices: None (4.6L), 98+ Navigator (5.4L) Aftermarket/Modified Stock Intake Choices: Al Papitto short runner 99 Cobra (4.6L), sheet metal Navigator head dimensions: Combustion Chamber: 53cc, Intake Port Vol.: 184cc, Intake Port Entrance: 2.290”x1.400”, Valves: 37mm Int., 30mm Exh. ’00 Cobra R: (’00 Cobra R) Cobra R heads are bar none the best Modular heads available today. However, their extremely scare supply makes them both ridiculously hard to find, and unbelievably expensive. Initial performance results are understandably hard to obtain, however Al Papitto reports that with only 25hrs of port work into the his new ‘00R heads, they have already eclipsed the performance of his old Navigator heads with months of labor in them. These heads feature larger intake and exhaust ports, +1mm larger exhaust valves, and a dry exhaust port divider. Cobra R heads also require the use of a specific valvetrain not shared with any other modular application due mainly to their overall physically larger size. Al also claims R heads have too much port volume for a street/strip 4.6L application; only consider them with a larger 5.4L motor or a serious 4.6L race application paired with some form of power adder. The Bottom Line: The best heads you can or can’t find for a Modular four valve motor. You are as likely to come across a set of these Modular “Godfather” heads as you are to be Brittany Spears’ next uterus masseuse. Though based on their performance abilities, you may want to start saving, just in case… Stock Intake Choices: None (4.6L), ’00 Cobra R (5.4L) Aftermarket/Modified Stock Intake Choices: Sheet metal ’00 Cobra R head dimensions: Combustion Chamber: N/A , Intake Port Vol.: N/A , Intake Port Entrance: 2.370”x1.300”, Valves: 37mm Int. 31mm Exh. Stock Intake Choices: ‘00R Aftermarket Intake Choices: Sheetmetal. FR500: (FRPP) The sole “aftermarket” offering of the bunch, these high flow heads feature a modified C head intake port combined with the smallest port volume of the group—it seems Ford meant to design these heads for high performance naturally aspirated applications. With the same small standard exhaust port as most other DOHC heads you will still have to remove a decent amount of material from the exhaust ports. Port entrance shape/size remains identical to C heads so finding an intake isn’t hard. These heads are capable of producing power beyond 8000rpm, where earlier versions of the tumble port castings begin to lose their luster. FR500 heads are prone to the #6,7, and 8 cylinder cooling problems as well. Major intake port differences between these and earlier tumble port heads include a raised intake port roof, and a real short turn radius that better directs the incoming air into the combustion chamber; not over the valves like in earlier versions of tumble port heads. These heads also feature a dry divider in the exhaust port, which allows for greater flow, but also higher temperatures. Though improved, the heads can still use some TLC from a quality porter to smooth the roughly finished and newly implemented short turn radius, and the standard exhaust treatment. The Bottom Line: Outstanding performance heads, with exceptional low and mid lift flow capability. The FR500s only real fault is that the newer ’03 DOHC heads provide near identical performance capability (much better on the exhaust side) paired with a cost differential that is approximately two-thirds less than the FRPP castings. Still a great choice for any application, the heads readily pair to a wide variety of stock and aftermarket intakes. Stock Intake Choices: ‘99/’01 Cobra, ‘03/’04 Mach 1 & Aviator, ’03 Marauder, FR500. Aftermarket /Modified Stock Intake Choices: Al Papitto short runner/ported ‘99/’01 Cobra, MP/Sullivan carb intake, FR500, Aviator. FR500 head dimensions: Combustion Chamber: 53cc, Intake Port Vol.: 160cc, Intake Port Entrance: 1.960”x1.350”, Valves: 37mm Int., 30mm Exh. ‘03 DOHC head: (‘03+ Aviator, Marauder, Cobra, Mach 1, Australian Boss 260/290) Featuring a nearly identical (though 17cc larger in volume due to the fact that they are also used on the much larger Australian Boss 260/290 5.4L DOHCs) intake port to the FR500 head, but combining it with a newly designed, larger and more rectangular exhaust port, these may be the best all around DOHC Ford heads ever manufactured. The improvements made to the intake port shape over previous years include a raised port roof and the introduction of a short radius turn in the throat of the intake port that helps assure the incoming air charge finds the combustion chamber. For those with a forced induction street/strip motor, these are without question the best heads available, and as with the FR500s, they should produce great power up to and beyond 8000rpm regardless of application. ’03 DOHC heads also feature higher quality head castings from the supplier, which is at least partially responsible for the modest increase in flow vs. earlier castings--chalk that up to Ford’s revised quality control standards. Early runs of the ’03 DOHC head fell victim to the same #6,7,8 cylinder coolant flow problems as earlier tumble port castings. In mid ’03 Ford made a running revision to the ’03 DOHC heads that allowed for more coolant to circulate through the affected areas. A blue mark on the driver’s side head indicates an updated casting, and there are no additional revisions to the ’04 version of this design. The Bottom Line: On all accounts these are the best modular four valve heads currently available. They combine the exceptional flow of a slightly larger FR500 intake port with a gigantic new rectangular exhaust port. Stock Intake Choices: ‘99/’01 Cobra, ‘03/’04 Mach 1 & Aviator, ’03 Marauder, FR500. Aftermarket/Modified Stock Intake Choices: Al Papitto short runner/ported ‘99/’01 Cobra, MP/Sullivan carb intake, FR500, Aviator. ’03 DOHC head dimensions: Combustion Chamber: 52cc, Intake Port Vol.: 177cc, Intake Port Entrance: 1.960”x1.350”, Valves: 37mm Int., 30mm Exh. ![]() In Conclusion Our panel of experts surmised that aside from the nearly unobtainable ‘00R heads, the ’03 DOHC heads are without question the right choice for your Modular four-valve performance application . The combination of a slightly larger FR500 intake port and modified throat region, coupled with a new larger rectangular exhaust port, and a relatively low price (due to it’s widespread use in the Ford organization) makes the ’03 DOHC casting the current head stud of Ford’s Modular stable. After porting, the relatively small stock valves/seats become the most serious flow limitation; as such aftermarket replacements should be a serious consideration for those looking to squeeze every last drop of performance from their DOHC heads. DOHC Intake Manifolds 96-04: 4V cars have many options out there for complete intake manifolds. Both the 96-98 intakes and the 99-04 intakes can be customized to suit just about any need you have. If you must have the best, sheet metal intakes can be made. 1996-1998 Cobras have an aluminum, side-entry throttle body intake manifold with long runners. The runners curve 180 degrees into the cylinder head ports and in between them are things called “IMRCs” or Intake Manifold Runner Controllers. The job of these is to maintain torque by only opening one intake valve and one exhaust valve until a given RPM (which Ford set at 3250 RPMs stock). The 1996 and most of 1997 IMRCs are made of metal which get gummed up quite a bit from the carbon that is found after engine combustion. Some late model 1997s and1998s have a ceramic style IMRC plate that doesn’t get nearly as dirty as the 1996-1997s do. IMRC deletes are out there but unless you have a poweradder that is constant like a turbocharger or supercharger, you will lose torque and have significant driveability issues under and until 3200 RPMs. Eric Duncan did some tests and found that you can actually gain quite a bit of torque by making the IMRCs open up at close to 4000 RPMs. This intake manifold will only fit on B style heads. The 1999/2001 Cobra intake manifold is a long-runner design, just like that of the 1996-1998, but it no longer has IMRCs. These intake manifolds flow significant better over the 1996-1998 and that’s one of the reasons the 1999/2001 gets its HP difference from the older Cobras. This intake manifold will fit on any tumble port style head. The 2003/2004 Mach 1 has a unique intake manifold that is similar to the 1999/2001 intake manifold. It is a long runner intake in that the air travels between the runners, then down the opening and back up again to the cylinder head ports. This intake seems to make great torque but isn’t too great at high RPMs. This is one reason why the Mach 1s perform better when shifting around 6000 RPMs instead of 7000. The FR500 intake manifold is the most unique design of an intake I’ve ever seen. It is not a short runner, it is not a long runner – it’s BOTH. The FR500 intake manifold has short runners that are controlled by throttle blades that are closed until they are needed. The long runners are used until 3500 RPMs, which then the short runners open up at. Unlike the other intake manifolds, this intake is made of magnesium. This intake manifold will fit any tumble port style head. Gains have been known to reach 40 rwhp and beyond with the FR500 heads and cams to compliment them. Last edited by jk_aktion; February 9th, 2011 at 12:17 AM. |
plagiarism!
1998 Gt full pi swap -Dead and gone 1998 Mark VIII 4.30s, 125 shot, 93 d/s-Daily Driver 1998 BAB Cobra-Project |
03 Cobra
![]() iTrader: 1 reviews
99 and 01s with the tick? Believe it was the 03 and 04 c heads known for this.
MM Cobra Club #86 2003 Mineral Grey Cobra 2004 True Blue F-150 FX4 |
i only put it here cuz everyone keeps asking, maybe they will sticky it. good knowledge to pass on.
i keed
2003 gt
5.4 32v on the way
thats old, and has probably been posted a few times a year
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
duh...
MM's Orangest
2004 Mach 1 Mustang
It's still nice to put the original author in. I'm pretty sure this has been posted already in this forum and it definitely was posted on other forums.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
4v Know-it-all
Here's the original article:
Ford Four-Valve Head Information Guide - 5.0 Mustang & Super Fords |
#11 | |||
4v Know-it-all
#12 | |
Thanks for your help! |
#13 | |
4v Know-it-all
It is hard to pinpoint exactly. I seems like its on the driver side for sure. A friend used a stethoscope and we noticed that the sound was stronger when we listened near the middle pully on the front of the engine. The ticking is not coming from the top. It sounds horrible but after the engine warms up, it goes away. It also does not speed up when revving the engine, it seems to be the worst at low rpms and idle.
Because Racecar
2012 Mustang GT Premium
So I just read what the imrcs do and now I know why my car acts funky intermittently when I get around those rpms. So when people delete these they experience more bottom end power pretty much? What's the worst side affects of getting rid of them?
Threads Similar to: DOHC Head/Intake / Tech
| wondering where i can get an aftermarket intake for my dohc | p1sc98stang | 4V / SVT | 10 | January 28th, 2011 10:08 PM |
| Which Head Gasket Is Best For DOHC | BigEag205 | 4V / SVT | 3 | December 21st, 2010 01:42 PM |
| SOHC to DOHC head swap | WickedSnake00 | 99-04 | 11 | August 26th, 2010 09:19 PM |
| TECH! - Help with head swap - Noisy engine... | 96gt226410 | 96-98 | 12 | July 14th, 2008 03:23 PM |
