Looking for some answers
Old February 11th, 2011, 09:44 AM   #1
1996 Cobra
BlackSnake135 is on a distinguished road
Exclamation
ok i have a 1996 cobra, i blew the headgaskets a while ago and decided i was gonna pull the motor out to replace the headgaskets and put some headstuds in while i was there so hopefully it does not happen again. since i am doing all of this in my driveway with the car on jackstands pulling the transmission out was.. difficult. my question is for when the time comes to put everything back in the car is it possible to connect the transmission to the motor and slide everything in at once or would i have to put the motor in and then the transmission. i do have a engine crane with an engine angler so i dont think angling the two will be a problem. i wanted to know to see if i can make my life a little easier and get the cobra back on the road so i can keep showing them hondas what a real car is.
Old February 11th, 2011, 12:44 PM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
dunno how difficult it would be to pull it out with trans still attached, i never seen a point in it. personally i drop out the front suspension, lower engine and trans together, take trans and headers off (makes access to everything a breeze), and either lift engine striat up and out or roll it out from under car (engine dolly)
Old February 11th, 2011, 03:56 PM   #3
mustang3194's Avatar
1996 Mustang Cobra
mustang3194 is on a distinguished road
Send a message via AIM to mustang3194
I would advise bolting the engine and tranny together, and remove your k member along with the suspension, and bolt the engine down to that. Once you have that done take the rear end of the car off the jack stands to raise the front up higher. Slide the engine in below the car and use the engine lift to raise it up. Bolt the k member back in and plug in some lines/wires and you should be good. This is how i did it for my engine swap. Heres a link of photos when i put the engine back in.
1995 Mustang Engine Swap
95 Mustang swapped to a 96 Cobra Drivetrain
Old February 11th, 2011, 06:25 PM   #4
4v Know-it-all
na svt is on a distinguished road
Not everyone has the capability to lift the car high enough to drop the engin on the K. You can pull the engine with the trans attached and even with long tubes still installed.
Forget the head studs, they aren't needed unless you're pushing over 20psi of boost.
Old February 11th, 2011, 11:00 PM   #5
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
a small set of stands will allow plenty of room to drop the k, engine, and trans. that will allow to have access to everything easy, and able to lift strait up and out of the engine compartment. not everyone has capability to lift car high enough to pull engine out from the bottom. i have done it with a smaller set of acdelco stands from the parts house a couple times.
Old February 11th, 2011, 11:19 PM   #6
majorownage is on a distinguished road
if you pull it "up" you cannot pull the engine/trans together.
Don't ask me how I know
1998 Gt full pi swap -Dead and gone
1998 Mark VIII 4.30s, 125 shot, 93 d/s-Daily Driver
1998 BAB Cobra-Project
Old February 12th, 2011, 12:26 AM   #7
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
there have been a couple guys on here that say they have. radiator, condenser, resivor, etc all has to come out obviously, but they said they have done it. if i remember right, one guy had pics of him doing it
Old February 12th, 2011, 02:54 AM   #8
jk_aktion's Avatar
jk_aktion will become famous soon enough
easy to remove and easy to install motor w/trans (stock), for longtubes you will have to drop the k-member a couple of inches to install motor w/trans and get the motor extremely vertical. and i suggest to remove/install motor w/trans than installing trans after, pain to get those top trani bolts threaded in.
Old February 12th, 2011, 09:51 AM   #9
1996 Mustang Cobra
I was able to drop it out the bottom no problem with a standard set of jack stands. Also you can pull the tranny with it also. When you raise it up the tranny will fall right into place once you get the k member bolted in.
Old February 12th, 2011, 10:31 AM   #10
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
not too big of a deal to get to top trans bolts as long as you have the stuff to do it with.
Old February 27th, 2011, 10:39 AM   #11
1999 Mustang Cobra
jamiehatch is on a distinguished road
Ive only done it seperately, Pull the motor, and tranny from the bottom. In my driveway can be done takes time.
Old February 27th, 2011, 11:08 AM   #12
0949er's Avatar
12.85 @ 114
0949er is a jewel in the rough0949er is a jewel in the rough0949er is a jewel in the rough0949er is a jewel in the rough
I think it all depends on if you can get the front of the car high enough to angle the tranny and motor back into the car.
MODS:
Vortech V1 T-Trim @ 7.5 PSI (tuned down)
Comp Cam Stage 2's
+ more
432 rwhp / 396 rwtq 02/27/2011
NEW VIDEOS!
**It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math
C2H5OH on the horizon
Threads Similar to: Looking for some answers
Need some answers... SC3 99-04 7 May 28th, 2010 08:27 PM
someone help please...need some answers!!!! 94pacecarSVT 99-04 14 April 17th, 2008 04:53 PM
need some answers please !!! 1quickstang02 99-04 3 February 29th, 2008 02:31 AM
looking for some answers 88Hatch331 5.0 Mustangs 14 January 15th, 2008 12:22 PM
Need answers Buck01 99-04 0 November 8th, 2007 02:27 PM
