LinkBack (1) | Thread Tools |
#1
MSTRB8N & MDR8N
2021 Mustang V15
Quad Turbo with nawz
IMRC questions
i threw a code (P1405) saying that my IMRCs aren't working properly in my 1997 cobra. took it to a shop to have the code pulled, and the mechanic told me they weren't opening like they should or something. what does this mean exactly?
i've heard of IMRC deletes, what is that? according to him, this is something that will cause me to fail emissions, and it's a very expensive fix. what are my options here? thanks.
MM 1 am boner crew Cars and mod list in garage i like veiny meat sliding between my buttcheeks |
#2 | |
Most likely, they are clogged up with carbon. Take off your intake manifold remove the IMRC's and clean. They will most likely work after that. You could also get 98 IMRCs these were designed better and are a direct swap. They don't plug up like the previous ones.
1998 Gt full pi swap -Dead and gone 1998 Mark VIII 4.30s, 125 shot, 93 d/s-Daily Driver 1998 BAB Cobra-Project |
MSTRB8N & MDR8N
2021 Mustang V15
thanks, that pretty much answers my question.
do you think running gas treatment over a few tanks will do anything?
MSTRB8N & MDR8N
2021 Mustang V15
nevermind, dumb question lol
#5 | |
If you want you could try seafoam. Add ALL of it directly through a vacuum hose. Idle the engine and pour in. Do not let it stall or pour too fast, because you could hydrolock. They say to add to your fuel and oil, but F that... adding it to your fuel will not clean what you need cleaned, and adding it to your oil is just plain stupid
MSTRB8N & MDR8N
2021 Mustang V15
thanks for the help. repped.
2009 Mustang GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
i vote for the IMRC deletes. even though this isn't a poll
MSTRB8N & MDR8N
2021 Mustang V15
what is that exactly?
Assistant to the Manager
Its like alt+f4 on your keyboard.....but on a car....
Join The MM Facebook: Modded Mustangs Facebook Vote For Modded Mustangs Ride of the Month Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal, 101Fng |
IMRC deletes are overrated.
You don't gain hp, and you have a soggy lower end until you tune (more money) Just clean them, and they will perform just fine. My DD is a mark viii, and at 113k miles, i do not any problems with the imrc's not opening up. More than likely its because I floor it every chance i get
4V swapped '02 GT
(2v) 13.9@101
![]() ![]() ![]() ![]() iTrader: 10 reviews
X2.
no more headaches once they are gone. only thing is you will need a custom on a XCal to keep any codes from comming up and you will need some more timing in your tune to make up for the low-end power loss. i deleted my IMRC's on my Mark VIII swapped GT, it was very easy to do (i made my own delete plates out of the plastic ones my motor came with) i have no low end power loss but i have 26* of timing down low in my tune. but like said before, if money is tight, they can be cleaned up and put back on and they should work they way they are supposed to afterward.
![]() BSD 100MPH Club YMR #8975 4v Swap and a little Purple Bottle ![]() MM Nitrous Club #7 MM Cobra Club #87 |
#12 | |
That is way too much 20 degrees is about the most you ever need at max rpm/load
I'm at 34* from idle to 4000 then its pulled a little the higher I go.
![]() -Mark- 98' N/A Cobra (Stock longblock) 11.79 at 114.64 (1.62 60ft) |
#14 | |
4V swapped '02 GT
(2v) 13.9@101
i have 26* down low and 30* up top in my tune so mine is set up very similar to yours just with a few less degrees. i am very pleased with the way mine runs. &&btw, that you for the help you gave me a few months back man!
#15 | |||
4v Know-it-all
You only run mid 11s, what do you know? Last edited by na svt; February 15th, 2011 at 07:19 PM. |
isn't that alot more than stock? I've used a timing light on mine, and there is not near as much timing; like 22max. Maybe running 87 octane was setting of the knock sensors
4v Know-it-all
Well i did the the imrc runner delete on my 96 cobra id say its about the same either way if your runners are hesitating. I added mine back after cleaning them up and gasket matching them feel the car runs much better. who has the deltes with tune is it a big diff? Well not to change the subject but you guys running that high of a timing on our year cobras with just bolt-on? if so what should i try with jlt cai, steeda pullies, ngk plugs(.52 gapping), accufabb full flat tb, steeda timing adjuster, alum drive shaft, sct tune? Thanks gary
#19 | |
OP: You prolly have some build up in them...remove intake and run some brake cleaner over them and the actuator...you'll be all right. |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/203919-imrc-questions.html
| Thread IMRC questions | Forums at Modded Mustangs | BoardReader | This thread | Refback | June 13th, 2011 10:04 PM | |
Threads Similar to: IMRC questions
| Imrc help!! Asap! | Keasbey | 4V / SVT | 4 | October 26th, 2010 02:37 AM |
| IMRC troubles??? | yfz162 | 96-98 | 1 | October 24th, 2009 11:57 AM |
| School me on IMRC | 83Bronco | V6 Mustangs | 5 | June 23rd, 2009 04:39 PM |
| IMRC | Lt_Crazy | V6 Mustangs | 20 | November 8th, 2007 06:08 PM |
| IMRC | cobraglenn | 96-98 | 0 | March 25th, 2007 09:45 PM |
