Mach 1 oil change for 109,000 mile mark question.
Old February 13th, 2011, 08:58 AM   #1
Because Racecar
Calogero6685's Avatar
2012 Mustang GT Premium
Calogero6685 will become famous soon enough
I've changed it twice since I've owned her. Both times with full synthetic. The first time, I noticed dramatic increase in in mileage with Castrol (?). The next time she got Royal Purple, and continued up with better mileage and start-ups. I recall getting a little heavier weight (I think 10W-20 instead of the factory 5W-20). Should I stick with the 10W-20 even though the Florida heat is right around the corner, also, like I said in the Topic, this is 109K miles.
Answer... fast! I'm headed to Advance in a few.
Old February 14th, 2011, 11:22 PM   #2
jk_aktion's Avatar
jk_aktion will become famous soon enough
i only use 5m-20 mobil 1 enhanced for daily driving and on the road course. never any problems in ny winter or fl summer as i go back and forth often. 113k miles on it as well.
Old February 14th, 2011, 11:34 PM   #3
Fill's Avatar
Fill is on a distinguished road
Stay with 5W-20, due to the tighter clearances of the Mod Motor. Especially if you drive in colder weather.
Phil
PRB Machining, LLC
http://www.prbmachining-absdeletemanifolds.com/
2003 Mach 1
NX 175 shot
10.73 @ 128.63 (Oct 2007) factory motor
Old February 15th, 2011, 06:39 AM   #4
Because Racecar
Florida heat... not cold. All right, well I picked up the 5W-20 so that's going in as soon as I can. They say Royal Purple is good for 7,000 miles, but I've always done it every 3,000 even with my 2006 F-150.
Old February 15th, 2011, 08:37 AM   #5
All Homo All The Time
Nightmare69's Avatar
2003 Mustang GT
Whatever you run plus 5 seconds
Nightmare69 will become famous soon enoughNightmare69 will become famous soon enough
Ive always used 10w-30 full synthetic due to the texas heat,never had any issues running the thinker oil.
BLACK STANG CREW MEMBER #30
Old February 15th, 2011, 04:50 PM   #6
Fill's Avatar
What does a quart of 5w-20 Royal Purple cost in Florida? It's about $6.99 here in Ohio.
Phil
PRB Machining, LLC
2003 Mach 1
NX 175 shot
Old February 15th, 2011, 09:50 PM   #7
Because Racecar
$8.36 if I remember correctly.
Old February 16th, 2011, 02:04 PM   #8
clutchitup83 is on a distinguished road
yep your right just bought 5 quarts today
Threads Similar to: Mach 1 oil change for 109,000 mile mark question.
Mach 1/8 mile help 04MachOne Drag 3 April 27th, 2010 03:21 AM
mach 1 1/8 mile help 04MachOne 4V / SVT 20 April 25th, 2010 02:39 PM
36,000 mile mark... Iconoclast107 The Clubhouse 14 April 18th, 2010 08:45 PM
Finally Broke Outta the 10 flat Mark @ 1/8th Mile :D XxViSiOnxX Drag 2 August 30th, 2008 07:34 PM
change in 1/4 mile ET? texasd18e 99-04 41 March 29th, 2008 11:16 PM
