4.6 4v swap need help with upgrades, etc... - Page 2
Old February 17th, 2011, 06:26 AM   #21
Because Racecar
Calogero6685's Avatar
2012 Mustang GT Premium
Calogero6685 will become famous soon enough
What do you mean, the transmismission won't shift?
Old February 17th, 2011, 06:31 AM   #22
4v Know-it-all
na svt is on a distinguished road
Originally Posted by SWEET2KSTANG View Post
400 to the ground does n/a not require spinning it that high, 7300 or so on the correct set up will get it.
comparison of a stock and ported stocker show's no peak gains. auto's mostly have seen some mid range gain over uported version. this goes for 2v's as well as 4v's. i have never seen n/a motor be retricted from the t/b at 370. obviously there is a benefit to going to a larger t/b at that power level, but as you said only minimal gains.
the full C&L set up i find favorable, not to mention the 95mm option for 6 pin MAF cars.. stock with K&N does fine, but as with the t/b leaves a couple left to get. not to mention the stocker looks like shit.
as for headers, there are differences. this has been tested by several guys and shops. n/a isnt going to have as big of differences as fi cars, but differences are there.
um, the inlet of the top hat is shit. period. a little work and its fixed. the lower manifold obviously needs work, and is done by plenty of people inculding myself.
good aftermarket coils show no gains until power adders are used, and even then a boost-a-spark or dual dis-4s can take care of that issue as well. as for less reliable, wrong. i have my gms hot street coils for few years now, never had any issue, on a freinds harley right now till my car is up and going again, then back on my car.
i have seen 9.8:1 compression stock for these cars. i have heard of a few that says 10.0, but not an arguement worth even thinking about joining. as for flat tops, 10.2-10.4:1, whatever, still not shit of a gain.
Sure, you can make over 400rwhp at 7300, but since you don't shift where peak power occurs you will need to spin it higher.
Ported TBS are shit, plain and simple and stock TBs are a restriction if they reduce power even 1rwhp. Like I saud, an aftermarket TB is beneficial once you hit 370rwhp.
The only difference maker in headers is the primary diameter, but seriously, there are no difference between all of them. Also, spending over 1k for long tubes is ridiculous.
The upper intake on the 99/01 and mach 1s does not present a constraint to making power at all, there are no mods that can be done to it that will make it more efficieint. Tell us one thing that can be done to them that will increase power. I say add a spacer and be done with it.
Old February 17th, 2011, 07:51 AM   #23
majorownage is on a distinguished road
tremecs dont like being spun that high
1998 Gt full pi swap -Dead and gone
1998 Mark VIII 4.30s, 125 shot, 93 d/s-Daily Driver
1998 BAB Cobra-Project
Old February 17th, 2011, 08:04 AM   #24
4v Know-it-all
stock transmissions don't like to be shifted at 7500rpm and the same goes for TKOs.
Old February 17th, 2011, 12:04 PM   #25
Because Racecar
A TKO 600 was my alternative to building my 3650, but I guess it doesn't really matter since I think I'm going to leave mine all stock. Ill probably stick with 3.55 once I get the money.
Old February 17th, 2011, 02:45 PM   #26
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
depends who's driving and what your doing when you are spinning it that high. the stock trans and tko both will shift that rpm as well, i have a couple cars doing it. more than that, then upgrades in the trans need to be done. the 3650 gets to be a challenge at 7300. a built 3650 will do 7300 fine, a redone tko will do that and more easy.
ported t/b's are good mod, plain and simple especially if an auto car. no matter what anyone says or proves, you will hold your opinion.
primary diameter and length (depending on design) are factors as well. but seriously, there is a difference. spending a grand on headers is crazy unless its needed.
you can say as you will with the upper intake, and thats your choice. i personally like to go in and do work on them while i do my lower. if i am doing it, then thats me. if you arent, then thats your choice.
you hold your opinion on how you do stuff, and i will on mine. i have done several 4v's both n/a and boosted, plenty of 2v's as well; i'm not just saying this shit just to say it.
Old February 17th, 2011, 10:19 PM   #27
4v Know-it-all
how much hp can be gained from a ported TB, or an modded upper?
There are a lot of mods that can be done, some are even very inexpensive like a ported TB. However, those that know me are very aware that I'm all about bang for the buck and doing no mod that adds zero hp. If it takes time or money and doesn't contribute to power production it's not on my mod list.
Old February 18th, 2011, 11:19 AM   #28
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
how much power added depends on other mods as well. porting doesnt cost me anything since i do it already. when i do customer cylinder head and lower intake porting, i will do the t/b and manifold top free since i am already there.
i am very well aware of who you are, but doesnt change my mind about how i go about modding my vehicles or my customers vehicles.
Old February 18th, 2011, 11:23 AM   #29
how do you advise degreeing cams?
Old February 18th, 2011, 12:18 PM   #30
4v Know-it-all
Depends on the combo, n/a or fi, manual or automatic trans, LTs or manifolds, etc.
Old February 18th, 2011, 01:44 PM   #31
lol, ok I was reall specific. What I was wondering the technique. There are several differing methods out there. And also, how much advance do I need in my intake cams
Old February 18th, 2011, 02:46 PM   #32
4v Know-it-all
Use the centerline method and for an automatic trans, heavy car like a Mark 8 set the cams at 106/114. Send me an email and I'll send you directions on how to do it. nasvt at yahoo
Threads Similar to: 4.6 4v swap need help with upgrades, etc...
4.6 upgrades v. 5.4 upgrades (Cheaper?) ralph30 96-98 16 March 26th, 2010 10:07 AM
95' gt upgrades usmc95gt 94-95 13 October 8th, 2008 01:49 PM
Upgrades? jgreaves V6 Mustangs 10 December 18th, 2007 06:53 PM
94 V6 Hp upgrades Phatthwag V6 Mustangs 16 May 22nd, 2007 08:22 PM
Upgrades? venomm 94-95 6 October 30th, 2006 11:39 AM
