MACH 1 blowing black smoke at full throttle
Old February 17th, 2011, 02:27 PM   #1
2003 Mach 1
12.87@ 109
2003MACHWON is on a distinguished road
OK so i was racing one of my friends last night and obviously i smoked him and we stopped and he said that i was blowing out black smoke from under my car, so i check under the car and there is a brown fluid on my catted x back but nothing on up towards my manifold from the x pipe... im thinkin that its leaking from my tranny... 3rd gear syncros are gone as well in my car... i was racing from a 40 starting in 2 and as soon as i hit 4th he said it stopped...
PLZ help im hoping its just the tranny cuz replacment is one its way
Old February 17th, 2011, 03:05 PM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
if its was the trans, it should leak at all times not stop when you get to a different gear. if its a small leak, then the fluid may of burned off by the time you got to 4th. if its coming from under the car and not tail pipes, its more than likely a leak instead of an internals engine/trans issue.
Old February 17th, 2011, 03:28 PM   #3
2003 Mach 1
12.87@ 109
well thats good news i hope, i knew that i was leaking gear fluid from when i had my gears installed but it had stopped
Old February 17th, 2011, 03:28 PM   #4
jk_aktion's Avatar
jk_aktion will become famous soon enough
you were WOT (wide open throttle), blowing out all that carbon build up out of the engine..
Old February 17th, 2011, 03:40 PM   #5
2003 Mach 1
12.87@ 109
ya what im hoping.. he said it was straight black until i was at higher speeds and it did it three times.. im try pooring injector cleaners in it to see if it clears it out
Old February 17th, 2011, 03:40 PM   #6
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
but he is saying from underneath the car, not tail pipes. well, thats the way i interperted it.
Old February 17th, 2011, 03:49 PM   #7
2003 Mach 1
12.87@ 109
ya thats what my freinds thinks it was at 130 in the mourning so who knows, all i know was that there was a brown fluid on my x pipe but not my manifolds
Old February 17th, 2011, 03:56 PM   #8
jk_aktion's Avatar
well he checked it out, only black smoke left would be wot. since there is no damage to anything and the motor runs fine.. his friend is probably not used to seeing that, and might have over reacted making it a big deal.
Old February 17th, 2011, 04:31 PM   #9
2003 Mach 1
12.87@ 109
ya we just had like 25 inches of snow like a week ago and its been 65 for the past 5 days so there is alot of salt on the roads, but the srt4 neon that i was racing said it was black and there was 2 different people that said the same thing
Old February 17th, 2011, 04:33 PM   #10
2003 Mach 1
12.87@ 109
the car only has 38,000 miles on it, and tranny is going out and has been raced many times and im a pretty good driver so........ i think i replace plugs and run injector cleaner then wait till my t56 gets here and hopefully it willl stop, but hopefully some more people will have advice
Old February 17th, 2011, 04:43 PM   #11
majorownage is on a distinguished road
damn that trans must have been beaten to death
do you miss a shift ever time you shift it?
=P
1998 Gt full pi swap -Dead and gone
1998 Mark VIII 4.30s, 125 shot, 93 d/s-Daily Driver
1998 BAB Cobra-Project
Old February 17th, 2011, 06:20 PM   #12
2003 Mach 1
12.87@ 109
see thats why i had to put the note in there that im not a scrub of a driver, ya i have missed a shift here and there but who hasnt, and i should state that the car is my daily driver and i go from 2nd to 4th
Old February 17th, 2011, 06:24 PM   #13
2003 Mach 1
12.87@ 109
who know ill get on it during day light and see if i can see it, i personally thing its just salt on the roads
Old February 18th, 2011, 11:25 AM   #14
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
lol, you got the snow too huh? i got 24ish inches here at my place.
Old February 18th, 2011, 02:42 PM   #15
2003 Mach 1
12.87@ 109
alright so i found out what it is...... there is a seal were my driveshaft goes into the tranny and been torn apart.. so my t56 doesnt get here for about another weekand a half so im going to drop the driveshaft and replace the sael and replace the tranny fluid that was lost
Threads Similar to: MACH 1 blowing black smoke at full throttle
fuse #26 blowing on full throttle, when loaded! izo 99-04 62 February 24th, 2011 11:43 PM
New Mustang! Blowing some smoke. BrianNV 5.0 Mustangs 4 April 24th, 2007 11:03 PM
